<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Office 365 calendar issues]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I’m trying to add my private calendar feed from the office 365 calendar of my job. I successfully added my google calendar but with the office 365 from work I ran in to some issues.</p>
<p dir="auto">If I try to load in my main calendar named “agenda” the MagicMirror is constantly displaying loading. Then I added a new agenda and put in one appointment to test if this will work. The answers is not quite: It displayed the appointment but it says its ending within an Invalid date (see attached picture)<br />
<img src="/assets/uploads/files/1492462113816-test1.jpeg" alt="0_1492462116526_test1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">The question is if there is something wrong with the ics generated by Office 365 for business? Does anyone managed to get his work-agenda up and running? Here is he code from my config file:</p>
<pre><code>{
position: "bottom_left",
// url: 'https://calendar.google.com/calendar/ical/mailadres@gmail.com/private-string/basic.ics'
symbol: 'calendar',
url: 'https://outlook.office365.com/owa/calendar/string@work.com/private-string/calendar.ics'
symbol: 'calendar',
]]></description><link>https://forum.magicmirror.builders/topic/2347/office-365-calendar-issues</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 07:44:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2347.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Apr 2017 21:01:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Office 365 calendar issues on Sun, 18 Mar 2018 04:29:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi all, I had the same problems with my calendar and Timezone (Amsterdam, Berlin…)</p>
<p dir="auto">The fix resoled my problems with outlook365 calendar<br />
<a href="https://github.com/MichMich/MagicMirror/pull/875/commits/4c702eaaad525c0b549ba02cf3ceb1a2f79b5ebc" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/pull/875/commits/4c702eaaad525c0b549ba02cf3ceb1a2f79b5ebc</a></p>
<p dir="auto">… after installing the fix I had to delete 2 old calendar entries and reboot my mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/37153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37153</guid><dc:creator><![CDATA[schwoediauer]]></dc:creator><pubDate>Sun, 18 Mar 2018 04:29:11 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Thu, 03 Aug 2017 16:14:27 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here with the ordinary Outlook calendar.<br />
[Edit] Got it working, I already updated the scripts but after deleting 2 appointments from history and rebooting it worked!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/26164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26164</guid><dc:creator><![CDATA[B4ttleduck]]></dc:creator><pubDate>Thu, 03 Aug 2017 16:14:27 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Tue, 20 Jun 2017 16:30:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a> Will do. I’ll try to get that file to you this evening. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/24304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24304</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 20 Jun 2017 16:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Mon, 19 Jun 2017 06:20:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Oke first off all, sorry for my late reaction I was luckily enough to have a long vacation… :) I finally finished the housing of the mirror and planning to fasten it in my bedroom today. The last time I checked (3 days ago) my office 365 calendar runs just fine. Maybe you cant make an test appointment in your agenda and DM me the Ical file so I can check how my MM response to your generated Ical file.</p>
]]></description><link>https://forum.magicmirror.builders/post/24217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24217</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Mon, 19 Jun 2017 06:20:28 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Fri, 02 Jun 2017 14:17:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a> Curious. I dropped those changes into my mirror and it didn’t resolve the problem at all. Hrm.</p>
]]></description><link>https://forum.magicmirror.builders/post/22287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22287</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 02 Jun 2017 14:17:24 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Mon, 08 May 2017 10:31:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cohron" aria-label="Profile: cohron">@<bdi>cohron</bdi></a> Everything works fine now thanks to: <a href="https://github.com/MichMich/MagicMirror/pull/875" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/pull/875</a></p>
<p dir="auto">cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/21301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21301</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Mon, 08 May 2017 10:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Fri, 21 Apr 2017 18:57:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a> said in <a href="/post/20112">Office 365 calendar issues</a>:</p>
<p dir="auto">is a problem we/they need to fix in MM</p>
<p dir="auto">I’m going to guess MM is going to have to fix their parsing, it appears to be a well formed ics file (or at least the portion you and i looked at), I doubt we are going to get Microsoft to change.</p>
]]></description><link>https://forum.magicmirror.builders/post/20118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20118</guid><dc:creator><![CDATA[cohron]]></dc:creator><pubDate>Fri, 21 Apr 2017 18:57:19 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Fri, 21 Apr 2017 17:58:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cohron" aria-label="Profile: cohron">@<bdi>cohron</bdi></a> (#*$&amp;,. I just figured out that this only happens when you set to a time zone with multiple cities… So i can set the timezone to a same one as I live in with only one name like: “UTC+01:00 Windhoek”. I ask if this is a problem we/they need to fix in MM or that our big friend from Microsoft had to set up there ical files right. I keep you updated ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/20112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20112</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Fri, 21 Apr 2017 17:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Fri, 21 Apr 2017 16:12:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cohron" aria-label="Profile: cohron">@<bdi>cohron</bdi></a> Oke, I will do that. I just checked my own calendar again and only if I save the appointment in timezone “Coordinated Universal Time” it works. Or if I set my overall timezone to UTC… But that’s not a solution because then everything is set to that time and I’m living in the UTC+1 zone.</p>
]]></description><link>https://forum.magicmirror.builders/post/20098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20098</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Fri, 21 Apr 2017 16:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Thu, 20 Apr 2017 19:33:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a><br />
Well i checked my calendar and everything looked fine. I havent been able to get the invalid date to show up again (even with timezones enabled/showing). I’d say open a bug report and send them your ICS file.</p>
<p dir="auto">should be fine really.</p>
]]></description><link>https://forum.magicmirror.builders/post/20034</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20034</guid><dc:creator><![CDATA[cohron]]></dc:creator><pubDate>Thu, 20 Apr 2017 19:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Wed, 19 Apr 2017 18:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a></p>
<p dir="auto">Oh, yes some of my tasks had the invalid date error, only 4 or 5 tasks though. It was only occurring on appointments that had the timezone showing. Unfortunately I already fixed it by removing the (show) timezones and resaving the appointment. Sorry didnt catch that earlier. I set up a test appointment and will look at the MM when I get home. I havent picked apart the Calendar MMM but im guessing you found the same bug i had. Wont know if i recreated the error until i get him and look at MM.</p>
<p dir="auto">Keep your “bad” ICS file for the programmers (or you) to test, recreate, and fix if you submit a bug report.</p>
<p dir="auto"><img src="/assets/uploads/files/1492625514777-upload-34952624-9688-450d-8dd1-228c1a1e4996.png" alt="0_1492625512666_upload-34952624-9688-450d-8dd1-228c1a1e4996" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1492626002499-upload-b53fa3a9-eb5a-4678-abe3-c9a1afa4d953.png" alt="0_1492626000390_upload-b53fa3a9-eb5a-4678-abe3-c9a1afa4d953" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1492626081075-upload-e7bc8dc2-946f-46fa-a163-a11fe089a2d2.png" alt="0_1492626080044_upload-e7bc8dc2-946f-46fa-a163-a11fe089a2d2" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/19965</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19965</guid><dc:creator><![CDATA[cohron]]></dc:creator><pubDate>Wed, 19 Apr 2017 18:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Wed, 19 Apr 2017 17:03:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cohron" aria-label="Profile: cohron">@<bdi>cohron</bdi></a> I just start up my PI and yes the calendar works partially… I don’t know if the reason is the deleting of the re-announcing tasks or there was something wrong with the server Sunday night. De strange thing is that most of my tasks show a invalid date error. Only the tasks that have the “whole day” option checked are displaying correctly. I don’t know if you familiar with ICS files but I think it has to do with these line of codes:</p>
<pre><code>// This works (Whole day checked)
DTSTART;VALUE=DATE:20170421
DTEND;VALUE=DATE:20170423
// This gives invalid date error
DTSTART;TZID="(UTC+01:00) Amsterdam, Berlijn, Bern, Rome, Stockholm, Wenen":2
 0170412T080000
DTEND;TZID="(UTC+01:00) Amsterdam, Berlijn, Bern, Rome, Stockholm, Wenen":201
 70412T090000
<p dir="auto">Could you check what is set for DTSTART and DTEND in your ICS file?</p>
]]></description><link>https://forum.magicmirror.builders/post/19963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19963</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Wed, 19 Apr 2017 17:03:54 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Wed, 19 Apr 2017 11:22:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hermpi" aria-label="Profile: hermpi">@<bdi>hermpi</bdi></a> I have a few weekly and monthly and annual re-occurring meetings with no end date, they show up fine, I wouldnt think that is the issue. I notice your config is not populated, probably not neccessary but different than mine. Here is mine:</p>
<p dir="auto">config: {<br />
colored: true,<br />
maxTitleLength: 25,<br />
warpEvents: true,<br />
maximumEntries: 30,<br />
getRelative: 0,<br />
dateFormat: “ddd, MMM Do h:mm A”,<br />
timeFormat: “absolute”,<br />
urgency: 0,<br />
calendars: [<br />
{<br />
symbol: “bank”,<br />
color: “#00e5ee”, //work ical<br />
url: "<a href="https://outlook.office365.com/owa/" target="_blank" rel="noopener noreferrer nofollow ugc">https://outlook.office365.com/owa/</a>…<br />
},<br />
{<br />
symbol: “heartbeat”,<br />
color: “#fa4616”, //Shelby UF ical<br />
url: "<a href="http://p07-calendarws.icloud.com/ca/" target="_blank" rel="noopener noreferrer nofollow ugc">http://p07-calendarws.icloud.com/ca/</a>…</p>
]]></description><link>https://forum.magicmirror.builders/post/19944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19944</guid><dc:creator><![CDATA[cohron]]></dc:creator><pubDate>Wed, 19 Apr 2017 11:22:12 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Wed, 19 Apr 2017 07:17:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cohron" aria-label="Profile: cohron">@<bdi>cohron</bdi></a> Yeah that’s exactly the page were i generated my ICS with Full details in the permissions ;) Maybe it has something to do with the tasks in my agenda that returns weekly and are scheduled till infinity in the calendar.? This weekend I will troubleshoot the problem again and maybe i come to a answer why my calendar won’t load…</p>
]]></description><link>https://forum.magicmirror.builders/post/19935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19935</guid><dc:creator><![CDATA[hermpi]]></dc:creator><pubDate>Wed, 19 Apr 2017 07:17:16 GMT</pubDate></item><item><title><![CDATA[Reply to Office 365 calendar issues on Tue, 18 Apr 2017 16:43:41 GMT]]></title><description><![CDATA[<p dir="auto">I have my work calendar functioning properly. I believe this is where I got my link from. also make sure permissions are good.<br />
<img src="/assets/uploads/files/1492533745791-upload-1b76a225-5e5e-4f64-933a-9fb1e3546671.png" alt="0_1492533744284_upload-1b76a225-5e5e-4f64-933a-9fb1e3546671" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/19882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19882</guid><dc:creator><![CDATA[cohron]]></dc:creator><pubDate>Tue, 18 Apr 2017 16:43:41 GMT</pubDate></item></channel></rss>
