<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[$9 C.H.I.P.]]></title><description><![CDATA[<p dir="auto">I received my <a href="https://getchip.com/pages/store" target="_blank" rel="noopener noreferrer nofollow ugc">$9 C.H.I.P. computer</a> today, with the HDMI module that I added to the Kickstarter campaign. So naturally, I wanted to see if it would run MM. Being that it runs Debian, I figured why not.</p>
<p dir="auto">The positives:<br />
Hardware is ARM7l …<br />
Installing node v6+: no problem.<br />
Installing the necessary node modules: no problem<br />
Installing electron: no issues</p>
<p dir="auto">The negative: Electron won’t run. It’s saying it’s missing one of the prebuilt files. I need to figure out what that is and why. But, it DOES run as a server only setup. I can load it up just fine through a browser. This is actually kinda fun for a tiny little thing. And I do mean tiny, it’s smaller than a Raspberry Pi.</p>
]]></description><link>https://forum.magicmirror.builders/topic/235/9-c-h-i-p</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 10:10:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/235.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jun 2016 01:51:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to $9 C.H.I.P. on Mon, 30 Jan 2017 18:09:30 GMT]]></title><description><![CDATA[<p dir="auto">If folks find it helpful. I can copy contents of that gist here. Just let me know.</p>
]]></description><link>https://forum.magicmirror.builders/post/13054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13054</guid><dc:creator><![CDATA[morozgrafix]]></dc:creator><pubDate>Mon, 30 Jan 2017 18:09:30 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Mon, 30 Jan 2017 17:19:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morozgrafix" aria-label="Profile: morozgrafix">@<bdi>morozgrafix</bdi></a> So cool.</p>
]]></description><link>https://forum.magicmirror.builders/post/13045</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13045</guid><dc:creator><![CDATA[roramirez]]></dc:creator><pubDate>Mon, 30 Jan 2017 17:19:54 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Mon, 30 Jan 2017 16:35:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morozgrafix" aria-label="Profile: morozgrafix">@<bdi>morozgrafix</bdi></a> Nonetheless, it’s still pretty exciting</p>
]]></description><link>https://forum.magicmirror.builders/post/13036</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13036</guid><dc:creator><![CDATA[simongaviria1]]></dc:creator><pubDate>Mon, 30 Jan 2017 16:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Mon, 30 Jan 2017 16:06:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simongaviria1" aria-label="Profile: simongaviria1">@<bdi>simongaviria1</bdi></a> there are still a few limitations that I haven’t solved. It was more of an experiment to see if it would run.</p>
]]></description><link>https://forum.magicmirror.builders/post/13029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13029</guid><dc:creator><![CDATA[morozgrafix]]></dc:creator><pubDate>Mon, 30 Jan 2017 16:06:45 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Mon, 30 Jan 2017 15:13:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morozgrafix" aria-label="Profile: morozgrafix">@<bdi>morozgrafix</bdi></a> sick! Can’t wait to try this out tonight. I’ve been trying to run MM on the chip for a bit now</p>
]]></description><link>https://forum.magicmirror.builders/post/13022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13022</guid><dc:creator><![CDATA[simongaviria1]]></dc:creator><pubDate>Mon, 30 Jan 2017 15:13:15 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Sat, 28 Jan 2017 08:52:18 GMT]]></title><description><![CDATA[<p dir="auto">I dug up the CHIP that was sitting and collecting dust to see if I can run MM on it. It was almost successful. I documented my installation and setup path here <a href="https://gist.github.com/morozgrafix/db069203ac4d8635a0f27e3dfa52f532" target="_blank" rel="noopener noreferrer nofollow ugc">https://gist.github.com/morozgrafix/db069203ac4d8635a0f27e3dfa52f532</a></p>
]]></description><link>https://forum.magicmirror.builders/post/12763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12763</guid><dc:creator><![CDATA[morozgrafix]]></dc:creator><pubDate>Sat, 28 Jan 2017 08:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Tue, 12 Jul 2016 18:00:25 GMT]]></title><description><![CDATA[<p dir="auto">The blanking out is the screen saver kicking in, I think. You should be able to disable that. I’d have to go back and load mine up to see what I did, but I do remember running it for a while without it blanking out on me.</p>
]]></description><link>https://forum.magicmirror.builders/post/2491</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2491</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 12 Jul 2016 18:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Tue, 12 Jul 2016 17:17:23 GMT]]></title><description><![CDATA[<p dir="auto">I ran the manual install and once you’ve installed whatever it is to make it recognise npm it installed fine.</p>
<p dir="auto">I then installed the declutter function to get rid of the curser and followed the auto start instructions and seemingly it all works well with a couple of issues:</p>
<ul>
<li>
<p dir="auto">i’m running through composite so it is very cluttered in terms of resolution</p>
</li>
<li>
<p dir="auto">i can seem to stop CHIP from blanking out after 10 mins</p>
</li>
</ul>
<p dir="auto">i’m running the most recent GUI for CHIP, so yes it does work but it’ll need some playing around with to make it look nice.</p>
]]></description><link>https://forum.magicmirror.builders/post/2488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2488</guid><dc:creator><![CDATA[mikmonken]]></dc:creator><pubDate>Tue, 12 Jul 2016 17:17:23 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Sat, 25 Jun 2016 16:52:17 GMT]]></title><description><![CDATA[<p dir="auto">No, it’s not something I’m actively doing. It was more of a fun evening thing and that’s it. I have other things I need to be doing.</p>
]]></description><link>https://forum.magicmirror.builders/post/1974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1974</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Sat, 25 Jun 2016 16:52:17 GMT</pubDate></item><item><title><![CDATA[Reply to $9 C.H.I.P. on Sat, 25 Jun 2016 16:49:49 GMT]]></title><description><![CDATA[<p dir="auto">Hey, have you figured it out yet? I’m having issues installing electron</p>
]]></description><link>https://forum.magicmirror.builders/post/1973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1973</guid><dc:creator><![CDATA[simongaviria1]]></dc:creator><pubDate>Sat, 25 Jun 2016 16:49:49 GMT</pubDate></item></channel></rss>
