<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2 way mirror parameters]]></title><description><![CDATA[<p dir="auto">what is optimal parameters for 2 way mirror?</p>
<p dir="auto">thank you for answers</p>
]]></description><link>https://forum.magicmirror.builders/topic/2373/2-way-mirror-parameters</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 18:42:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2373.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Apr 2017 14:51:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2 way mirror parameters on Sun, 23 Apr 2017 19:38:58 GMT]]></title><description><![CDATA[<p dir="auto">thank you all for your answers… was very helpfull</p>
]]></description><link>https://forum.magicmirror.builders/post/20280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20280</guid><dc:creator><![CDATA[BlackPawn]]></dc:creator><pubDate>Sun, 23 Apr 2017 19:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to 2 way mirror parameters on Sat, 22 Apr 2017 14:54:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpawn" aria-label="Profile: BlackPawn">@<bdi>BlackPawn</bdi></a> thickness rarely impact the numbers that much, it’s the mirrors coating that decides what numbers you get. It all depends o. The manufacturer what they offer for different thickness. Thickness is more a question of weight and thougness.<br />
Large Mirror with no supporting frame I would suggest a 6-8mm one, if you are building a smaller mirror with support take a 3-6mm mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/20176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20176</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 22 Apr 2017 14:54:35 GMT</pubDate></item><item><title><![CDATA[Reply to 2 way mirror parameters on Sat, 22 Apr 2017 09:07:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> it is not depend on quality of the mirror?<br />
and what about depth of mirror? 8mm or 4mm?</p>
]]></description><link>https://forum.magicmirror.builders/post/20151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20151</guid><dc:creator><![CDATA[BlackPawn]]></dc:creator><pubDate>Sat, 22 Apr 2017 09:07:37 GMT</pubDate></item><item><title><![CDATA[Reply to 2 way mirror parameters on Fri, 21 Apr 2017 16:30:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpawn" aria-label="Profile: BlackPawn">@<bdi>BlackPawn</bdi></a> as high reflection % you can get, light transmission between 10-30%. It mostlu depends on where the mirror will be put.</p>
<p dir="auto">Daylight = 30-40% light transmission<br />
Dark room = 10-20% light transmission</p>
]]></description><link>https://forum.magicmirror.builders/post/20100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20100</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 21 Apr 2017 16:30:06 GMT</pubDate></item><item><title><![CDATA[Reply to 2 way mirror parameters on Fri, 21 Apr 2017 14:55:50 GMT]]></title><description><![CDATA[<p dir="auto">what is the techniquies make more reflective?<br />
did the 8mm is too much?</p>
]]></description><link>https://forum.magicmirror.builders/post/20095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20095</guid><dc:creator><![CDATA[BlackPawn]]></dc:creator><pubDate>Fri, 21 Apr 2017 14:55:50 GMT</pubDate></item></channel></rss>
