<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-DailyQuote]]></title><description><![CDATA[<h1>Description:</h1>
<p dir="auto">Shows a random quote everyday on your MM.  With or without header.</p>
<h1>Screenshots:</h1>
<p dir="auto"><img src="/assets/uploads/files/1492911408488-capture2.png" alt="0_1492911409249_Capture2.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Without header:<br />
<img src="/assets/uploads/files/1492911450823-capture.png" alt="0_1492911449432_Capture.PNG" class=" img-fluid img-markdown" /></p>
<h1>Download:</h1>
<p dir="auto">[card:cowboysdude/MMM-DailyQuote]</p>
<hr />
<h2>Version 1.0.1</h2>
]]></description><link>https://forum.magicmirror.builders/topic/2385/mmm-dailyquote</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 21:58:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2385.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Apr 2017 01:37:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 27 Jan 2019 14:01:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surger13" aria-label="Profile: surger13">@<bdi>surger13</bdi></a> You can also use this one I made, quotes but JUST in German :)  I never advertised it much but made it at the same time as I made the other quote module.</p>
<p dir="auto"><a href="https://github.com/cowboysdude/MMM-GQuotes" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/MMM-GQuotes</a></p>
]]></description><link>https://forum.magicmirror.builders/post/50905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50905</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 27 Jan 2019 14:01:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 27 Jan 2019 13:53:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surger13" aria-label="Profile: surger13">@<bdi>surger13</bdi></a></p>
<p dir="auto"><a href="https://github.com/cowboysdude/MMM-DailyQuote/commits/master" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/MMM-DailyQuote/commits/master</a></p>
]]></description><link>https://forum.magicmirror.builders/post/50903</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50903</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 27 Jan 2019 13:53:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 27 Jan 2019 09:31:36 GMT]]></title><description><![CDATA[<p dir="auto">Is there a way to return to the previous version?</p>
]]></description><link>https://forum.magicmirror.builders/post/50895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50895</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Sun, 27 Jan 2019 09:31:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sat, 12 Jan 2019 08:24:04 GMT]]></title><description><![CDATA[<p dir="auto">german / de</p>
]]></description><link>https://forum.magicmirror.builders/post/49984</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49984</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Sat, 12 Jan 2019 08:24:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Fri, 11 Jan 2019 19:11:42 GMT]]></title><description><![CDATA[<p dir="auto">What language are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/49962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49962</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 11 Jan 2019 19:11:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Fri, 11 Jan 2019 07:07:18 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for this module cowboysdude.<br />
I’ve been using it for some time. Now I updated it, since then it shows only “undefined”.<br />
What’s wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/49940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49940</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Fri, 11 Jan 2019 07:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Mon, 07 Jan 2019 02:56:38 GMT]]></title><description><![CDATA[<h1>Description:</h1>
<h1>Updated for 2019!!</h1>
<p dir="auto">Used to only support English and German now supports your native language.<br />
Reads language from your config.js and uses that to translate the quote.</p>
<p dir="auto">Shows a random quote everyday on your MM.</p>
<p dir="auto">SEE README</p>
<p dir="auto">None</p>
<h1>Download:</h1>
<hr />
<h2>Version 2.0.0</h2>
]]></description><link>https://forum.magicmirror.builders/post/49578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49578</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 07 Jan 2019 02:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Wed, 11 Oct 2017 14:04:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goprojojo" aria-label="Profile: goprojojo">@<bdi>goprojojo</bdi></a> You can customize with <code>css/custom.css</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/29409</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29409</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 11 Oct 2017 14:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Wed, 11 Oct 2017 13:44:05 GMT]]></title><description><![CDATA[<p dir="auto">Thnx for this one! How can I change the font to match with MagicMirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/29408</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29408</guid><dc:creator><![CDATA[goprojojo]]></dc:creator><pubDate>Wed, 11 Oct 2017 13:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 14 May 2017 04:34:31 GMT]]></title><description><![CDATA[<h1>Description:</h1>
<p dir="auto">Shows a random quote everyday on your MM.  With or without header.<br />
In either German or English</p>
<p dir="auto">Rewritten by Strawberry</p>
<p dir="auto"><img src="/assets/uploads/files/1494736318551-german.png" alt="0_1494736317080_german.PNG" class=" img-fluid img-markdown" /></p>
<h1>Download:</h1>
<hr />
<h2>Version 1.0.4</h2>
]]></description><link>https://forum.magicmirror.builders/post/21572</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21572</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 14 May 2017 04:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Tue, 25 Apr 2017 01:05:44 GMT]]></title><description><![CDATA[<p dir="auto">But I don’t know why… even I didn’t look but there is already a module for this ------&gt;</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/1899/mmm-quotes-random-quote-from-online-services/2">https://forum.magicmirror.builders/topic/1899/mmm-quotes-random-quote-from-online-services/2</a></p>
]]></description><link>https://forum.magicmirror.builders/post/20395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20395</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 25 Apr 2017 01:05:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 23 Apr 2017 01:54:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks.  Someone requested it so why not…</p>
]]></description><link>https://forum.magicmirror.builders/post/20214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20214</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 23 Apr 2017 01:54:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DailyQuote on Sun, 23 Apr 2017 01:51:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a></p>
<p dir="auto">Dude, you’re a Juggernaut!  I applaud you! :clap_tone1:</p>
]]></description><link>https://forum.magicmirror.builders/post/20213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20213</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 23 Apr 2017 01:51:49 GMT</pubDate></item></channel></rss>
