<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Question about building the mirror frame]]></title><description><![CDATA[<p dir="auto">Hey guys, I had a simple question for which I have not been able to find an answer in the forum or the internet. Everyone I see builds the frame with 2 parts. The first part (outer frame) is the one that is polished and the one that you see. The second part (inner frame) is the one that is used to hold the monitor and other components.<br />
My question is cant I build a frame with just one part? Can I take 1.5" x 1.5" wooden piece and make an L shape groove and join them together so that I dont have an inner and outer frame?</p>
<p dir="auto">Here is an example of the two frames. Inner frame, outer frame and a curious doggo. <img src="http://i.imgur.com/sZgDysO.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here is an example of what I am trying to achieve with a single piece of wood . <img src="http://i.imgur.com/A1OmfPm.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Would it work? Would it have issues supporting the mirror and the monitor?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/2469/question-about-building-the-mirror-frame</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 01:45:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2469.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 May 2017 02:09:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Question about building the mirror frame on Wed, 03 May 2017 09:39:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Yes…So you mean the holes for adding the L shaped latch?</p>
]]></description><link>https://forum.magicmirror.builders/post/21057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21057</guid><dc:creator><![CDATA[monk]]></dc:creator><pubDate>Wed, 03 May 2017 09:39:40 GMT</pubDate></item><item><title><![CDATA[Reply to Question about building the mirror frame on Tue, 02 May 2017 11:39:36 GMT]]></title><description><![CDATA[<p dir="auto">I’m assuming that you are using it on the back side of your frame to hold everything in…</p>
]]></description><link>https://forum.magicmirror.builders/post/20966</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20966</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 02 May 2017 11:39:36 GMT</pubDate></item><item><title><![CDATA[Reply to Question about building the mirror frame on Tue, 02 May 2017 02:28:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Holes for? Sorry not much of a handyman :(</p>
]]></description><link>https://forum.magicmirror.builders/post/20946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20946</guid><dc:creator><![CDATA[monk]]></dc:creator><pubDate>Tue, 02 May 2017 02:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to Question about building the mirror frame on Tue, 02 May 2017 02:27:25 GMT]]></title><description><![CDATA[<p dir="auto">Pre-drill your holes first! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/20944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20944</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 02 May 2017 02:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to Question about building the mirror frame on Tue, 02 May 2017 02:26:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/20943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20943</guid><dc:creator><![CDATA[monk]]></dc:creator><pubDate>Tue, 02 May 2017 02:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to Question about building the mirror frame on Tue, 02 May 2017 02:21:06 GMT]]></title><description><![CDATA[<p dir="auto">I use two pieces of 3/4 pine to hold in the mirror and monitor so you should be fine using those.</p>
]]></description><link>https://forum.magicmirror.builders/post/20942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20942</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 02 May 2017 02:21:06 GMT</pubDate></item></channel></rss>
