<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Recommended mirror specs]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">do you have any recommendations for the best mirror-experience?</p>
<p dir="auto">I could get a mirror glas with<br />
transmission 3% and 4mm thickness. Or better 6mm?</p>
<p dir="auto">The mirror should be hanging in the corridor. Most of the time it is artificial lighted. What do you think about the specs?</p>
<p dir="auto">pauabaer</p>
]]></description><link>https://forum.magicmirror.builders/topic/2474/recommended-mirror-specs</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:31:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2474.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 May 2017 17:54:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:53:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pauabaer" aria-label="Profile: pauabaer">@<bdi>pauabaer</bdi></a> yeah a couple of kg, but not overwhelmingly heavy :)</p>
]]></description><link>https://forum.magicmirror.builders/post/21004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21004</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 19:53:44 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:42:43 GMT]]></title><description><![CDATA[<p dir="auto">wow. enormous weight!? :D<br />
mine should be only 50x30</p>
]]></description><link>https://forum.magicmirror.builders/post/21001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21001</guid><dc:creator><![CDATA[pauabaer]]></dc:creator><pubDate>Tue, 02 May 2017 19:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:28:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pauabaer" aria-label="Profile: pauabaer">@<bdi>pauabaer</bdi></a> yeah basically,<br />
I would probably go with a thicker mirror if making a large one piece mirror. (mine is 120x60cm and 6mm thick)</p>
]]></description><link>https://forum.magicmirror.builders/post/21000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21000</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 19:28:53 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:19:42 GMT]]></title><description><![CDATA[<p dir="auto">Thats obvious. Thought perhaps it has any influence. So the thinner the better because of light weight?</p>
]]></description><link>https://forum.magicmirror.builders/post/20999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20999</guid><dc:creator><![CDATA[pauabaer]]></dc:creator><pubDate>Tue, 02 May 2017 19:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pauabaer" aria-label="Profile: pauabaer">@<bdi>pauabaer</bdi></a> the thickness does not change anything (the reflective coating is usually only applied to one side of the glass).</p>
]]></description><link>https://forum.magicmirror.builders/post/20997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20997</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 19:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> thanks for the pictures. now i have an idea of the possible result.<br />
how does the thickness influence the effect?</p>
]]></description><link>https://forum.magicmirror.builders/post/20995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20995</guid><dc:creator><![CDATA[pauabaer]]></dc:creator><pubDate>Tue, 02 May 2017 19:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 19:06:58 GMT]]></title><description><![CDATA[<p dir="auto">I took a picture of the mirror running, light and dark</p>
<p dir="auto">Notice the thin text at the top, that’s the standard text-size of the MagicMirror.<br />
The clock and weather forecast are in a bolder font.</p>
<p dir="auto"><img src="/assets/uploads/files/1493751818389-img_20170502_205317.jpeg" alt="0_1493751819328_IMG_20170502_205317.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/20994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20994</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 19:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 18:52:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pauabaer" aria-label="Profile: pauabaer">@<bdi>pauabaer</bdi></a> one ceiling light, no windows.<br />
It’s visible, but not really good enough, you have to use a big text size to see it clearly.</p>
<p dir="auto">It works good with minimal light (i.e dark room with only monitors to light it up).</p>
]]></description><link>https://forum.magicmirror.builders/post/20993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20993</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 18:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 18:29:55 GMT]]></title><description><![CDATA[<p dir="auto">Same place of action?</p>
]]></description><link>https://forum.magicmirror.builders/post/20990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20990</guid><dc:creator><![CDATA[pauabaer]]></dc:creator><pubDate>Tue, 02 May 2017 18:29:55 GMT</pubDate></item><item><title><![CDATA[Reply to Recommended mirror specs on Tue, 02 May 2017 18:08:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pauabaer" aria-label="Profile: pauabaer">@<bdi>pauabaer</bdi></a> 3% is to little, I know, mine is 3%. I would suggest minimum 10% light transmission.</p>
]]></description><link>https://forum.magicmirror.builders/post/20986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20986</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 02 May 2017 18:08:48 GMT</pubDate></item></channel></rss>
