<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar_Monthly - not updates]]></title><description><![CDATA[<p dir="auto">Dears<br />
yesterday I found out, that even it was 2nd May, on the Calendar_Monthly module I still have 30rd April. What´s wrong? I needed to update another module, so I´ve restarted MM - thank it works. Any idea? Thx, Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/topic/2480/calendar_monthly-not-updates</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 05:58:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2480.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 May 2017 03:37:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar_Monthly - not updates on Wed, 03 May 2017 08:25:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> thx for the tip. Next time I´ll do. I didn´t know about the the console. I thought I´ve to run MM with parametr -dev to be able see dev console. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/21047</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21047</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Wed, 03 May 2017 08:25:18 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar_Monthly - not updates on Wed, 03 May 2017 08:17:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zdenek" aria-label="Profile: zdenek">@<bdi>zdenek</bdi></a> next time if it is not updating you should open the dev console with ctrl+shift+i and check for errors before restarting so people can investigate.</p>
]]></description><link>https://forum.magicmirror.builders/post/21042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21042</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 03 May 2017 08:17:57 GMT</pubDate></item></channel></rss>
