<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-awesome-alexa]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/dolanmiu/MMM-awesome-alexa" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/dolanmiu/MMM-awesome-alexa</a></p>
<p>
   <img src="https://images-na.ssl-images-amazon.com/images/G/01/mobile-apps/dex/alexa/agencies/logo_alexa._CB520978690_.png" height="300" />
</p><p>
</p><p dir="auto"><a href="https://gitter.im/awesome-alexa/Lobby" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="https://badges.gitter.im/dolanmiu/awesome-alexa.svg" alt="Chat on Gitter" class=" img-fluid img-markdown" /></a> <a href="https://david-dm.org/dolanmiu/MMM-awesome-alexa" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="https://david-dm.org/dolanmiu/MMM-awesome-alexa/status.svg" alt="dependencies Status" class=" img-fluid img-markdown" /></a> <a href="https://travis-ci.org/dolanmiu/MMM-awesome-alexa" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="https://travis-ci.org/dolanmiu/MMM-awesome-alexa.svg?branch=master" alt="Build Status" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><img src="https://media.giphy.com/media/9P6WN3Pi4mM1mqA8RK/giphy.gif" alt="Demo GIF" class=" img-fluid img-markdown" /></p>
<h1>MMM-awesome-alexa</h1>
<p dir="auto">A hands free Alexa module for the Magic Mirror, which is activated when you say ‘Alexa’.<br />
At the moment, this only works for MacOS and Ubuntu. Raspberry Pi has experimental support, it works when I tried it, but please try yourself and let us know on Gitter!</p>
<h2>Installation</h2>
<p dir="auto">Refer to the official documentation on how to install the module: <a href="https://awesome-alexa.js.org" target="_blank" rel="noopener noreferrer nofollow ugc">https://awesome-alexa.js.org</a></p>
<h2>Usage</h2>
<p dir="auto">Boot up <code>Magic Mirror</code> and say “Alexa, what time is it?”, or “Alexa, tell me a joke” 😊.</p>
<p dir="auto"><strong>Note:</strong> If you are using Raspberry Pi, you most likely will experience a <code>snowboy</code> issue. Please go to the <a href="#troubleshoot">Troubleshoot</a> section down below</p>
<h1>Features</h1>
<ul>
<li>Wake Word support</li>
<li>Custom Wake Word</li>
<li>Very easy set up</li>
<li>Easy config tool</li>
<li>All-in-one solution.</li>
<li>Visualisation</li>
</ul>
<h2>Supported Wake Words</h2>
<ul>
<li>Alexa</li>
<li>Smart Mirror</li>
<li>Snowboy</li>
<li>Jarvis</li>
<li>Computer</li>
</ul>
<h1>Troubleshoot</h1>
<p dir="auto">First check if your mic works by typing in:</p>
<pre><code class="language-bash">rec t.wav
<p dir="auto">If the above command doesn’t work, please fix that before continuing. <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=13088&amp;p=332703" target="_blank" rel="noopener noreferrer nofollow ugc">Here is a link to help you (Raspberry pi)</a></p>
<h2>PM2 problems</h2>
<p dir="auto">For some reason, running MagicMirror on <code>PM2</code> with this module doesn’t seem to work on Raspberry Pi. The mic does not pick up. If anyone has a solution or cause for this, it would be greatly appreciated. I would recommend to start the MagicMirror the traditional way of <code>npm start</code>.</p>
<h2>Snowboy problems</h2>
<p dir="auto">Make sure you followed the install steps correctly. It involves manually downloading snowboy and manually building snowboy:</p>
<p dir="auto"><a href="https://awesome-alexa.js.org/#/installation?id=step-2-install-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://awesome-alexa.js.org/#/installation?id=step-2-install-module</a></p>
<p dir="auto">Follow <code>snowboy</code>’s official guide on how to recompile their package:<br />
<a href="https://github.com/Kitt-AI/snowboy#compile-a-node-addon" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Kitt-AI/snowboy#compile-a-node-addon</a></p>
<hr />
<p dir="auto">Made with 💖 by Dolan</p>
]]></description><link>https://forum.magicmirror.builders/topic/2487/mmm-awesome-alexa</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:43:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2487.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 May 2017 00:57:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-awesome-alexa on Sat, 29 May 2021 15:40:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cq0q" aria-label="Profile: cq0q">@<bdi>cq0q</bdi></a> the author is no longer here and the module has   not been updated in quite a while.</p>
]]></description><link>https://forum.magicmirror.builders/post/91803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91803</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 29 May 2021 15:40:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Sat, 29 May 2021 15:10:37 GMT]]></title><description><![CDATA[<p dir="auto">hey guys, i have a problem with this module and i’d really be glad if someone could help me with it …<br />
I tried to install this module in my raspberry pi 4 (Awesome Alexa) … after i installed it and all … after i finished i tried it … and said: Alexa hide all (to hide the modules… for privacy and save power) it hided all the modules (including this module) but then i wanted to say: Alexa show modules (to show them again) but it didn’t respond to me … i had to restart the magic mirror … so what should i do after i hide the modules how can i show them again without restarting the magic mirror ? And how can i make Alexa hide particular modules but not all of them and if it’s possible, how can i make a custom responds (for example when i say: Alexa do you love me? … she responds to me with: yes my love 😅)</p>
]]></description><link>https://forum.magicmirror.builders/post/91801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91801</guid><dc:creator><![CDATA[cq0q]]></dc:creator><pubDate>Sat, 29 May 2021 15:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 17 Dec 2020 03:19:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks, i’m not sure what i did wrong, but it helps to know that it should be quick</p>
]]></description><link>https://forum.magicmirror.builders/post/85823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85823</guid><dc:creator><![CDATA[stalker401]]></dc:creator><pubDate>Thu, 17 Dec 2020 03:19:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 17 Dec 2020 02:37:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stalker401" aria-label="Profile: stalker401">@<bdi>stalker401</bdi></a> should be fairly instant.</p>
]]></description><link>https://forum.magicmirror.builders/post/85822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85822</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 17 Dec 2020 02:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 17 Dec 2020 02:21:47 GMT]]></title><description><![CDATA[<p dir="auto">So i’m at the point in the set pu where it’s saying “Getting response from Amazon…”, but it’s been going for like 30 mins. Any ideas on how long this should take, or did i probably make a mistake above?</p>
]]></description><link>https://forum.magicmirror.builders/post/85821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85821</guid><dc:creator><![CDATA[stalker401]]></dc:creator><pubDate>Thu, 17 Dec 2020 02:21:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Fri, 27 Nov 2020 17:03:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rguardaya2008" aria-label="Profile: rguardaya2008">@<bdi>rguardaya2008</bdi></a> sorry. I do not know.</p>
]]></description><link>https://forum.magicmirror.builders/post/85228</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85228</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Nov 2020 17:03:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Fri, 27 Nov 2020 06:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for guiding me so far… i was able to record and play using the codes you gave me, the mic seems to be fine. however, still i cannot open alexa on my MM. what did i miss?</p>
]]></description><link>https://forum.magicmirror.builders/post/85203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85203</guid><dc:creator><![CDATA[rguardaya2008]]></dc:creator><pubDate>Fri, 27 Nov 2020 06:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Fri, 27 Nov 2020 03:20:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rguardaya2008" aria-label="Profile: rguardaya2008">@<bdi>rguardaya2008</bdi></a> arecord -l<br />
will list the devices</p>
<p dir="auto">arecord -D  plughw:card#:0 test.wav<br />
speak some words<br />
ctrl-c to end record<br />
aplay test.wav, do you hear your words?</p>
<p dir="auto">but if the mic is bad, nothing software can do to fix it…</p>
]]></description><link>https://forum.magicmirror.builders/post/85202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85202</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Nov 2020 03:20:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Fri, 27 Nov 2020 02:58:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  i think i have a problem with my mic… i tried troubleshooting but i get the same reply “rec WARN alsa: can’t encode 0-bit Unknown or not applicable<br />
rec FAIL formats: can’t open input  `default’: snd_pcm_open error: No such file or directory” when i record…</p>
]]></description><link>https://forum.magicmirror.builders/post/85201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85201</guid><dc:creator><![CDATA[rguardaya2008]]></dc:creator><pubDate>Fri, 27 Nov 2020 02:58:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 26 Nov 2020 12:38:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rguardaya2008" aria-label="Profile: rguardaya2008">@<bdi>rguardaya2008</bdi></a> u have to speak, alexa…</p>
]]></description><link>https://forum.magicmirror.builders/post/85163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85163</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Nov 2020 12:38:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 26 Nov 2020 05:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thank you! i did the step by step process you showed me and when i run it magic mirror was just running fine not like the black/blank screen like before. however i cannot find the alexa on it.</p>
]]></description><link>https://forum.magicmirror.builders/post/85142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85142</guid><dc:creator><![CDATA[rguardaya2008]]></dc:creator><pubDate>Thu, 26 Nov 2020 05:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 26 Nov 2020 02:57:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rguardaya2008" aria-label="Profile: rguardaya2008">@<bdi>rguardaya2008</bdi></a> look in the console window were u  start magic mirror , npm start or pm2,<br />
if pm2, use the pm2 logs --lines=???  command  (??? is 15 by default)</p>
<p dir="auto">also, open the developers window, ctrl-shift-i,<br />
and select the console tab and scroll up…</p>
<p dir="auto">I made a script of the steps for the install , and there as a  missing piece, which the scrip corrects<br />
u can download it, make it executable, and it will do the whole install steps… (but not the auth step u just did, so keep that)</p>
<p dir="auto"><a href="https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0</a></p>
]]></description><link>https://forum.magicmirror.builders/post/85129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Nov 2020 02:57:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 26 Nov 2020 02:53:39 GMT]]></title><description><![CDATA[<p dir="auto">Guys can somebody help me…</p>
<p dir="auto">i tried installing this module into my magic mirror and i have been following the step by step process and i am already in the part were i already received the full config with  refreshToken. However, when i tried to encode it in the config and restarts the magic mirror it only shows black/blank screen. please somebody help me what to do next…</p>
]]></description><link>https://forum.magicmirror.builders/post/85128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85128</guid><dc:creator><![CDATA[rguardaya2008]]></dc:creator><pubDate>Thu, 26 Nov 2020 02:53:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Tue, 17 Nov 2020 18:28:24 GMT]]></title><description><![CDATA[<p dir="auto">After many attempts, I managed to install MMM-awesome-alexa, but I have a problem, no device from my account appears. I have tried saying “Alexa, search devices” it says it will search but then it says nothing.</p>
<p dir="auto">If I try to run routines they don’t exist either, however from the Alexa application for my mobile, I can run routines, control devices and also, in the list of devices I see that “Jonatan’s Magic_Mirror_Alexa” appears although as offline.</p>
<p dir="auto">It is as if it were an account with another profile, since it does not show devices or routines. But it works fine for the rest like asking the time and other information.<br />
I tried creating a new amazon account but the same thing happens.</p>
<p dir="auto">Does anyone know what can I do? 😔</p>
]]></description><link>https://forum.magicmirror.builders/post/84780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84780</guid><dc:creator><![CDATA[JonatanPN]]></dc:creator><pubDate>Tue, 17 Nov 2020 18:28:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Sun, 01 Nov 2020 15:21:57 GMT]]></title><description><![CDATA[<p dir="auto">For some reason the wake word “Jarvis” will not work for me.  Both “Alexa” and “Smart Mirror” do work when changed in the config file.  Anyone else had this problem and know how to fix it?  Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/84162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84162</guid><dc:creator><![CDATA[bsisco95]]></dc:creator><pubDate>Sun, 01 Nov 2020 15:21:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Mon, 19 Oct 2020 22:48:07 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1603147676909-photo_2020-10-20_00-47-50.jpg" alt="photo_2020-10-20_00-47-50.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/83739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83739</guid><dc:creator><![CDATA[Ghost2000]]></dc:creator><pubDate>Mon, 19 Oct 2020 22:48:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Mon, 19 Oct 2020 21:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ghost2000" aria-label="Profile: Ghost2000">@<bdi>Ghost2000</bdi></a> the code is valid for 24 hours… MM has to be running all the time so it can fresh the  token</p>
]]></description><link>https://forum.magicmirror.builders/post/83738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83738</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 19 Oct 2020 21:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Mon, 19 Oct 2020 21:58:43 GMT]]></title><description><![CDATA[<p dir="auto">O<br />
How can I prevent this?</p>
<p dir="auto">How long is the code valid?</p>
]]></description><link>https://forum.magicmirror.builders/post/83737</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83737</guid><dc:creator><![CDATA[Ghost2000]]></dc:creator><pubDate>Mon, 19 Oct 2020 21:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Mon, 19 Oct 2020 21:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ghost2000" aria-label="Profile: Ghost2000">@<bdi>Ghost2000</bdi></a> you will have to redo the code process as it as expired</p>
]]></description><link>https://forum.magicmirror.builders/post/83735</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83735</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 19 Oct 2020 21:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Mon, 19 Oct 2020 21:55:15 GMT]]></title><description><![CDATA[<pre><code>/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | [2020-10-19 14:17:29.092] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
0|MagicMir | [2020-10-19 14:17:29.093] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
0|MagicMir | [2020-10-19 14:17:29.939] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
0|MagicMir | [2020-10-19 14:17:29.940] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
0|MagicMir | [2020-10-19 14:17:29.941] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
0|MagicMir | [2020-10-19 14:17:29.943] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
0|MagicMir | [2020-10-19 23:45:02.464] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
0|MagicMir | [2020-10-19 23:45:10.761] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
0|MagicMir | [2020-10-19 23:45:18.513] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
]]></description><link>https://forum.magicmirror.builders/post/83734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83734</guid><dc:creator><![CDATA[Ghost2000]]></dc:creator><pubDate>Mon, 19 Oct 2020 21:55:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 15 Oct 2020 12:45:23 GMT]]></title><description><![CDATA[<p dir="auto">BTW is this new alexa instance will appear in my alexa app ? as a dot or something very similar ?</p>
<p dir="auto">The idea is to know if I could control this new alexa as usual with my homeAssistant and nodered :)</p>
]]></description><link>https://forum.magicmirror.builders/post/83424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83424</guid><dc:creator><![CDATA[aclertant]]></dc:creator><pubDate>Thu, 15 Oct 2020 12:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 15 Oct 2020 12:42:21 GMT]]></title><description><![CDATA[<p dir="auto">Yes I know ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/83423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83423</guid><dc:creator><![CDATA[aclertant]]></dc:creator><pubDate>Thu, 15 Oct 2020 12:42:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 15 Oct 2020 11:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aclertant" aria-label="Profile: aclertant">@<bdi>aclertant</bdi></a> so it would seem. the code is very hard to work with. I am not the author, just trying to help</p>
]]></description><link>https://forum.magicmirror.builders/post/83419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83419</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Oct 2020 11:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa on Thu, 15 Oct 2020 11:26:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/ghost2000" aria-label="Profile: Ghost2000">@<bdi>Ghost2000</bdi></a> ,</p>
<p dir="auto">You are fighting hard :o) Thanks a lot this is usefull !<br />
To distract you lol is there a way to command a blue led ribbon like seen in some videos ? Of course the best way for a noob like me would be a gpio pin to choose in the config… but as the git module is dead, looks impossible right ?</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/post/83417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83417</guid><dc:creator><![CDATA[aclertant]]></dc:creator><pubDate>Thu, 15 Oct 2020 11:26:45 GMT</pubDate></item></channel></rss>
