<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Making Frame Question?]]></title><description><![CDATA[<p dir="auto">So, I am looking into making a frame, and have figured the best option for me would be to but a custom made picture frame with plexiglass, and swap the glass for the two way mirror.  Would that work? If it would, do I glue or nail it to the shell that contains the monitor?  If it wouldn’t, what should I do instead?</p>
]]></description><link>https://forum.magicmirror.builders/topic/2488/making-frame-question</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 12:47:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2488.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 May 2017 03:17:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Making Frame Question? on Thu, 04 May 2017 11:14:18 GMT]]></title><description><![CDATA[<p dir="auto">This is a carpentry question really and a matter of choice.</p>
<p dir="auto">IF you have glue that is very good like Titebond glue for wood then yes you could glue and clamp it.<br />
This is a preferred method for those who do not want screw or nail holes to show…BUT if you don’t get it perfectly square that could be a problem…</p>
<p dir="auto">You could also screw your frame together… or nail.</p>
<p dir="auto">You could also do both…glue and screw/nail it.</p>
<p dir="auto">Any of those combinations would work…</p>
]]></description><link>https://forum.magicmirror.builders/post/21129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21129</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 04 May 2017 11:14:18 GMT</pubDate></item></channel></rss>
