<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What Monitor did you use?]]></title><description><![CDATA[<p dir="auto">Since my monitor seems to get a bit dim after 2 years of full-time running (yes I know, I should use a PIR sensor), my mirror monitor seems to become a bit dim.</p>
<p dir="auto">I’m looking for a extremely bright, super flat, affordable monitor. Preferable 24". Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/25/what-monitor-did-you-use</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 03:58:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/25.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 May 2016 19:02:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What Monitor did you use? on Wed, 20 Jan 2021 07:42:27 GMT]]></title><description><![CDATA[<p dir="auto">I think you can consider kiperlline, which is moderate in size and cheap, which is perfect for you.<br />
[<a href="https://jp.kiperline.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://jp.kiperline.com/</a>](link url)</p>
]]></description><link>https://forum.magicmirror.builders/post/87547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87547</guid><dc:creator><![CDATA[tomy]]></dc:creator><pubDate>Wed, 20 Jan 2021 07:42:27 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Tue, 24 Nov 2020 15:41:28 GMT]]></title><description><![CDATA[<p dir="auto">Thank You for your manual :-)</p>
<p dir="auto">Greetings</p>
<p dir="auto">Markus</p>
]]></description><link>https://forum.magicmirror.builders/post/85030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85030</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Tue, 24 Nov 2020 15:41:28 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Tue, 24 Nov 2020 04:47:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kusselin" aria-label="Profile: kusselin">@<bdi>kusselin</bdi></a> : Hello freiend.</p>
<p dir="auto">Like i wrote in this post here “15” Panel from an old laptop found in the trash with a separate Controller (from Amazon).<br />
HDMI+DVI+VGA+Audio LCD Controller Kit for 15.6" B156XW02 V.2 LED Panel 1366x768"</p>
<ol>
<li>
<p dir="auto">Disassemble your laptop.<br />
<img src="/assets/uploads/files/1606159674055-img_0869-small.jpg" alt="IMG_0869 (Small).JPG" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">Search for Panel manufacturer (like this one)<br />
<img src="/assets/uploads/files/1606162300226-img_0134-small.jpg" alt="IMG_0134 (Small).JPG" class=" img-fluid img-markdown" /><br />
and</p>
</li>
</ol>
<p dir="auto"><img src="/assets/uploads/files/1606162321856-img_0138-small.jpg" alt="IMG_0138 (Small).JPG" class=" img-fluid img-markdown" /></p>
<ol start="3">
<li>search on ebay, amazon or other supplier for a  LCD drive controller board of your panel manufacturerer. In my case i has found this for the lenovo…<br />
<img src="/assets/uploads/files/1606161790478-img_0749-small.jpg" alt="IMG_0749 (Small).JPG" class=" img-fluid img-markdown" /><br />
and this one for the packard bell<br />
<a href="https://www.amazon.de/HDMI-Eingang-Controller-LP156WH2-TL-LP156WH4-TL-LCD-Panel/dp/B0786HZHNJ/ref=sr_1_1?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&amp;dchild=1&amp;keywords=driver+board+B156xw02&amp;qid=1606161972&amp;sr=8-1" target="_blank" rel="noopener noreferrer nofollow ugc"> packard bell driver board for panel B156xw02 </a></li>
</ol>
<p dir="auto">hope you have some helpfull informations for your search.</p>
<p dir="auto">at least it looks like this</p>
<p dir="auto"><img src="/assets/uploads/files/1606162565482-img_0882-small.jpg" alt="IMG_0882 (Small).JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">or this</p>
<p dir="auto"><img src="/assets/uploads/files/1606162662845-img_0854-small.jpg" alt="IMG_0854 (Small).JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/85009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85009</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Nov 2020 04:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Sun, 22 Nov 2020 17:49:04 GMT]]></title><description><![CDATA[<p dir="auto">how did you do that with the display panel? I have the DELL 19 "1905FPV and would like to use it as a mirror. Do I need an extra panel for the connection …?</p>
]]></description><link>https://forum.magicmirror.builders/post/84938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84938</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Sun, 22 Nov 2020 17:49:04 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Thu, 11 Jan 2018 15:39:58 GMT]]></title><description><![CDATA[<p dir="auto">Anybody gone 55"+ ?</p>
<p dir="auto">I want to do this install in my bathroom but my OCD won’t allow the modules not to be perfectly lined up in each corner!</p>
]]></description><link>https://forum.magicmirror.builders/post/33809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33809</guid><dc:creator><![CDATA[JSBhopal]]></dc:creator><pubDate>Thu, 11 Jan 2018 15:39:58 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Sat, 02 Dec 2017 13:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto">Thank you ! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/31829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31829</guid><dc:creator><![CDATA[h0schi]]></dc:creator><pubDate>Sat, 02 Dec 2017 13:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Sat, 02 Dec 2017 13:43:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/h0schi" aria-label="Profile: h0schi">@<bdi>h0schi</bdi></a> said in <a href="/post/31827">What Monitor did you use?</a>:</p>
<p dir="auto">Is that a problem ?</p>
<p dir="auto">That’ll do. Virtually any display will work.</p>
]]></description><link>https://forum.magicmirror.builders/post/31828</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31828</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 02 Dec 2017 13:43:24 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Sat, 02 Dec 2017 12:50:56 GMT]]></title><description><![CDATA[<p dir="auto">I will use an old HP2448hc.<br />
This monitor got a glossy panel.</p>
]]></description><link>https://forum.magicmirror.builders/post/31827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31827</guid><dc:creator><![CDATA[h0schi]]></dc:creator><pubDate>Sat, 02 Dec 2017 12:50:56 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Thu, 08 Dec 2016 09:32:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sakuwa" aria-label="Profile: sakuwa">@<bdi>sakuwa</bdi></a> i would not recommend this monitor! IPS Panel is good but the brightness is just 250cd/m2 - better go for one with 300cd/m2<br />
price sounds good but resolution is not that fine for 27", also the connections are upright what makes it hard to build a slim mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/9048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9048</guid><dc:creator><![CDATA[cpramhofer]]></dc:creator><pubDate>Thu, 08 Dec 2016 09:32:41 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Fri, 02 Dec 2016 10:47:34 GMT]]></title><description><![CDATA[<p dir="auto">15" Panel from an old laptop found in the trash with a separate Controller.<br />
HDMI+DVI+VGA+Audio LCD Controller Kit for 15.6" B156XW02 V.2 LED Panel 1366x768</p>
]]></description><link>https://forum.magicmirror.builders/post/8822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8822</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Fri, 02 Dec 2016 10:47:34 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Fri, 02 Dec 2016 10:26:17 GMT]]></title><description><![CDATA[<p dir="auto">Hey :)<br />
i am searching for a monitor and my favorite in the moment is this one: <a href="https://www.amazon.de/HP-T3M86AA-Monitor-Reaktionszeit-schwarz/dp/B01G1M5B2C/ref=sr_1_3?s=computers&amp;ie=UTF8&amp;qid=1480673385&amp;sr=1-3" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/HP-T3M86AA-Monitor-Reaktionszeit-schwarz/dp/B01G1M5B2C/ref=sr_1_3?s=computers&amp;ie=UTF8&amp;qid=1480673385&amp;sr=1-3</a></p>
<p dir="auto">What do you think about this one?</p>
]]></description><link>https://forum.magicmirror.builders/post/8820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8820</guid><dc:creator><![CDATA[sakuwa]]></dc:creator><pubDate>Fri, 02 Dec 2016 10:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 28 Nov 2016 13:09:58 GMT]]></title><description><![CDATA[<p dir="auto">I have a three screen setup in front of me right now, one IPS in the middle and two TN besides it.<br />
the TN panels are crap in comparison (yes they where cheaper ofc) the viewing angle and colors are the most obvious things that stands out.<br />
If adjusted to extremes the contrast on the ips is much higher.</p>
<p dir="auto">And if you planning on using the screen on it’s side I would pretty much exclude tn panels, it just looks weird and the viewing angles from the side usually aren’t good enough.</p>
]]></description><link>https://forum.magicmirror.builders/post/8628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8628</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Mon, 28 Nov 2016 13:09:58 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 28 Nov 2016 12:39:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kobie" aria-label="Profile: Kobie">@<bdi>Kobie</bdi></a></p>
<p dir="auto">you are absoluty right, the bleeding in the dark is not the thing which worries me most.</p>
<p dir="auto">currently the position is not optimal, i´m still waiting for the hanging pads. if i go down a bit to improve the angel things get better.</p>
<p dir="auto">has anyone ever tried both: TN and IPS Panel? I will switch over to IPS and hope that things will improve once more.</p>
]]></description><link>https://forum.magicmirror.builders/post/8625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8625</guid><dc:creator><![CDATA[cpramhofer]]></dc:creator><pubDate>Mon, 28 Nov 2016 12:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 28 Nov 2016 11:09:33 GMT]]></title><description><![CDATA[<p dir="auto">I think it’s quite normal for them to bleed light in darkness - the one-way-mirror needs light on the ‘outside’ in order to overpower the light from the monitor.</p>
<p dir="auto">If you’re not seeing much when the lights are on, then you can try moving the mirror into a different position - the angle of teh light can make a difference.</p>
<p dir="auto">Also, have you tried playing around with the backlight settings, contrast  etc on the monitor?</p>
]]></description><link>https://forum.magicmirror.builders/post/8620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8620</guid><dc:creator><![CDATA[Kobie]]></dc:creator><pubDate>Mon, 28 Nov 2016 11:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 28 Nov 2016 10:55:30 GMT]]></title><description><![CDATA[<p dir="auto">i recently bought a ViewSonic (<a href="http://geizhals.at/viewsonic-vx2757-mhd-a1411094.html?hloc=at" target="_blank" rel="noopener noreferrer nofollow ugc">http://geizhals.at/viewsonic-vx2757-mhd-a1411094.html?hloc=at</a>) but it´s very poor!</p>
<p dir="auto">in a dark envirenment its bleeding and switched the main lights on i can´t hardly see anything (Mirror with 1:7 transmission)</p>
<p dir="auto">seems that TN panels are not the best choice.</p>
<p dir="auto">any other ideas for high quality displays below a 350€ pricetag?</p>
]]></description><link>https://forum.magicmirror.builders/post/8619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8619</guid><dc:creator><![CDATA[cpramhofer]]></dc:creator><pubDate>Mon, 28 Nov 2016 10:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Tue, 30 Aug 2016 10:33:15 GMT]]></title><description><![CDATA[<p dir="auto">I live in the US but this is what I used…</p>
<p dir="auto"><a href="http://www.newegg.com/Product/Product.aspx?Item=N82E16824009627" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.newegg.com/Product/Product.aspx?Item=N82E16824009627</a></p>
]]></description><link>https://forum.magicmirror.builders/post/4138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4138</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 30 Aug 2016 10:33:15 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Tue, 30 Aug 2016 09:22:48 GMT]]></title><description><![CDATA[<p dir="auto">I use a old Asus laptop X53 screen witch I unmounted (read: Destroyd) from the bezel and added direcly on the glas. Then I added a custom LCD Controller from amazon. Not the best light (bleeds abit) but smal and works great!</p>
]]></description><link>https://forum.magicmirror.builders/post/4137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4137</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Tue, 30 Aug 2016 09:22:48 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 29 Aug 2016 23:05:15 GMT]]></title><description><![CDATA[<p dir="auto">Maybe not the best solution for you but well. I bought a cheap 17 inch Laptop screen from ebay  LTN170X2-L02 17inch (1€ +6€ shipment) and then i bought a controller from ebay as well TV T.VST59  (21€ suggested price). Just search for nearly ending auctions with no bids on it, but first look if there is a working controller. Its pretty easy to set up everything is plug and play.</p>
]]></description><link>https://forum.magicmirror.builders/post/4132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4132</guid><dc:creator><![CDATA[astronauti]]></dc:creator><pubDate>Mon, 29 Aug 2016 23:05:15 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Wed, 03 Aug 2016 19:19:04 GMT]]></title><description><![CDATA[<p dir="auto">@neuzehie They, unfortunately, go by a lot of names: Confrontatiespiegel, observatieglas/spiegel, halfdoorlatende spiegel…</p>
]]></description><link>https://forum.magicmirror.builders/post/3374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3374</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Wed, 03 Aug 2016 19:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Wed, 03 Aug 2016 18:10:09 GMT]]></title><description><![CDATA[<p dir="auto">Would the iiyama ProLite X2483HSU-B2 be a good kandidate? Together with a 70% reflective 30% pass-through mirror?<br />
Or are there better options on the market for a setup like this mirror (24 inch, with usb to power the pi).</p>
<p dir="auto">En voor de Nederlands sprekenden: hoe heet zo’n spiegel in het Nederlands (two-way mirror)</p>
]]></description><link>https://forum.magicmirror.builders/post/3326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3326</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 03 Aug 2016 18:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Fri, 29 Jul 2016 14:06:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sero" aria-label="Profile: sero">@<bdi>sero</bdi></a> That’s a sexy monitor! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/3141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3141</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Fri, 29 Jul 2016 14:06:49 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Fri, 29 Jul 2016 05:29:33 GMT]]></title><description><![CDATA[<p dir="auto">I used an Asus MB169B+ which is an external USB C monitor. It’s extremely thin, but I had to get a controller on eBay, since the included controller has only the USB-port (and uses DisplayLink).</p>
<p dir="auto"><a href="https://www.asus.com/Monitors/MB169C-plus/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.asus.com/Monitors/MB169C-plus/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3110</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3110</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Fri, 29 Jul 2016 05:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Fri, 29 Jul 2016 04:05:45 GMT]]></title><description><![CDATA[<p dir="auto">I also used a ViewSonic, this 24 inch:<br />
<a href="https://www.amazon.com/Viewsonic-VA2446M-LED-24-Inch-1080p-Monitor/dp/B00D601UC8" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.com/Viewsonic-VA2446M-LED-24-Inch-1080p-Monitor/dp/B00D601UC8</a><br />
Like Eric said, the bezel came off fairly easily and it’s slim. Plus it’s only $129.99 right now!</p>
]]></description><link>https://forum.magicmirror.builders/post/3107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3107</guid><dc:creator><![CDATA[dmcinnes]]></dc:creator><pubDate>Fri, 29 Jul 2016 04:05:45 GMT</pubDate></item><item><title><![CDATA[Reply to What Monitor did you use? on Mon, 13 Jun 2016 13:48:16 GMT]]></title><description><![CDATA[<p dir="auto">I can advise to use use ViewSonic!<br />
e.g.:<br />
<a href="https://www.amazon.de/gp/product/B00K6E8ACU/ref=oh_aui_detailpage_o07_s00?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/gp/product/B00K6E8ACU/ref=oh_aui_detailpage_o07_s00?ie=UTF8&amp;psc=1</a><br />
I used now two of them for both: it’s not too difficult to get rid of the bezel, they are very slim, and all connectors showing down</p>
<p dir="auto">br!</p>
]]></description><link>https://forum.magicmirror.builders/post/1623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1623</guid><dc:creator><![CDATA[eric]]></dc:creator><pubDate>Mon, 13 Jun 2016 13:48:16 GMT</pubDate></item></channel></rss>
