<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble with default Weather Module]]></title><description><![CDATA[<p dir="auto">Hi guys! Noobie here…<br />
I am having some troubles with the original Weather Module and its position.<br />
First of all, I live in Funchal, PT and it is getting me really close Maximum and Minimum temperatures, as you see in the picture. I guess that’s OpenWeather’s fault, but if you know something about it, let me know.<br />
Then, I would like to know how can I resize or just change the module’s position of Lisbon one so it fits right under the Funchal’s.<br />
Plus, I can’t get my Magic Mirror to stay on all the time, the screen just gets black. I’ve tried many tutorials and it doesn’t make any difference…</p>
<p dir="auto">Thanks in advance!<img src="/assets/uploads/files/1494171188942-cf141fc9-0751-4955-b90c-d403ae76019e.jpeg" alt="0_1494171181397_cf141fc9-0751-4955-b90c-d403ae76019e.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2514/trouble-with-default-weather-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 05:10:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2514.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 May 2017 15:33:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble with default Weather Module on Sun, 07 May 2017 15:59:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/estuga" aria-label="Profile: estuga">@<bdi>estuga</bdi></a> said in <a href="/post/21258">Trouble with default Weather Module</a>:</p>
<p dir="auto">Plus, I can’t get my Magic Mirror to stay on all the time, the screen just gets black. I’ve tried many tutorials and it doesn’t make any difference…</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8">https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8</a></p>
]]></description><link>https://forum.magicmirror.builders/post/21260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21260</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 07 May 2017 15:59:42 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with default Weather Module on Sun, 07 May 2017 15:53:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/estuga" aria-label="Profile: estuga">@<bdi>estuga</bdi></a> said in <a href="/post/21258">Trouble with default Weather Module</a>:</p>
<p dir="auto">Then, I would like to know how can I resize or just change the module’s position of Lisbon one so it fits right under the Funchal’s.</p>
<p dir="auto">In your config.js, change the <code>position</code> of the Lisbon weather to top_right so it looks like this: <code>position: 'top_right',</code>  If the Lisbon weather appears first in your config.js then it will be above Funchal. If it appears after Funchal in the config.js it will be below.</p>
]]></description><link>https://forum.magicmirror.builders/post/21259</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21259</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 07 May 2017 15:53:13 GMT</pubDate></item></channel></rss>
