<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multiple Pages of Modules using CSS]]></title><description><![CDATA[<h3>Update 21-May-17</h3>
<p dir="auto">I was able to fork and tweak <a class="plugin-mentions-user plugin-mentions-a" href="/user/barnabycolby" aria-label="Profile: barnabycolby">@<bdi>barnabycolby</bdi></a>’s MMM-Carousel to manually switch between slides and show the page dots and navigation arrows without touching any core code.  I also added the ability to move or change appearances of each module on a per-slide basis.</p>
<p dir="auto">If anyone is interested my fork w/ navigation enabled is here:</p>
<p dir="auto">[card:shbatm/MMM-Carousel]</p>
<p dir="auto">The navigation uses my module <a href="https://github.com/shbatm/MMM-KeyBindings" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-KeyBindings</a>, which isn’t necessary if you just want to use a mouse or touchscreen.</p>
<p dir="auto"><img src="/assets/uploads/files/1495391254722-20170520_201316.jpeg" alt="0_1495391253670_20170520_201316.jpg" class=" img-fluid img-markdown" /></p>
<h3>Original Post Below:</h3>
<p dir="auto">After a bit of searching for the best way to manage multiple sets of modules on a screen with fairly limited real-estate, I decided to try my hand at rolling my own solution. I wanted to have multiple screens of modules that I could page through and see different information (eventually via remote control).  This isn’t a stand-alone module yet and there are probably cleaner / easier ways of doing this, but I wanted to share my progress in case anyone else was interested.</p>
<p dir="auto">My Mirror uses a pure-CSS3 solution to create multiple “pages” of modules using full screen sliders without relying on any JavaScript–although JS can be used to change the page by simply updating which radio button is checked programmatically.</p>
<p dir="auto">Notice the small faint arrows and dots along the bottom of the screen in the attached images.  The original source for the CSS is from <a href="https://www.htmllion.com/pure-css-based-fullscreen-slider.html" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
<p dir="auto"><img src="/assets/uploads/files/1494366230567-page1.png" alt="0_1494366227199_Page1.PNG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1494366268847-page2.png" alt="0_1494366269398_Page2.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The basic principle is to duplicate the containers in <code>index.html</code> onto up to 4 different “sliders”; then depending on which page you want a particular module to appear on, you modify the position in <code>config.js</code>, appending <code>slideXmods_</code> to the beginning.</p>
<p dir="auto">For example, to show a clock on Slide 2, the config now looks like:</p>
<pre><code>        {
            module: "clock",
            position: "slide2mods_top_left",
            	displayType: "both"
<p dir="auto">The modified versions of <code>index.html</code> and my <code>css/custom.css</code> can be found in the attached zip.  The reason I haven’t made this into a Module yet is because I also needed to modify <code>js/main.js</code> to account for the changes to the position names.</p>
<p dir="auto">The changes required in <code>js/main.js</code> are:</p>
<ul>
<li>Modify the first line of <code>selectWrapper</code> (Line ~65) to use RegEx and replace <em>all</em> instances of “_” in the <code>position</code> variable.</li>
</ul>
<pre><code>var classes = position.replace(/_/g," ");
<ul>
<li>Modify the first line of <code>updateWrapperStates</code> (Line ~275) to account for the rest of the new position names.</li>
</ul>
<pre><code>var positions = ["slide1mods_top_bar", "slide1mods_top_left", "slide1mods_top_center", "slide1mods_top_right", "slide1mods_upper_third", "slide1mods_middle_center", "slide1mods_lower_third", "slide1mods_bottom_left", "slide1mods_bottom_center", "slide1mods_bottom_right", "slide1mods_bottom_bar", "slide1mods_fullscreen_above", "slide1mods_fullscreen_below", "slide2mods_top_bar", "slide2mods_top_left", "slide2mods_top_center", "slide2mods_top_right", "slide2mods_upper_third", "slide2mods_middle_center", "slide2mods_lower_third",  "slide2mods_bottom_left", "slide2mods_bottom_center", "slide2mods_bottom_right", "slide2mods_bottom_bar", "slide2mods_fullscreen_above", "slide2mods_fullscreen_below"
 /* Uncomment lines below to add more slides
 , "slide3mods_top_bar", "slide3mods_top_left", "slide3mods_top_center", "slide3mods_top_right",  "slide3mods_upper_third", "slide3mods_middle_center", "slide3mods_lower_third",  "slide3mods_bottom_left", "slide3mods_bottom_center", "slide3mods_bottom_right", "slide3mods_bottom_bar", "slide3mods_fullscreen_above", "slide3mods_fullscreen_below",  "slide4mods_top_bar", "slide4mods_top_left", "slide4mods_top_center", "slide4mods_top_right",  "slide4mods_upper_third", "slide4mods_middle_center", "slide4mods_lower_third",  "slide4mods_bottom_left", "slide4mods_bottom_center", "slide4mods_bottom_right", "slide4mods_bottom_bar", "slide4mods_fullscreen_above", "slide4mods_fullscreen_below" */
<p dir="auto"><a href="https://www.dropbox.com/s/y4qtfz7rzamtxgi/MagicMirrorCustomizations.rar?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">Download Modified Files</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/2530/multiple-pages-of-modules-using-css</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 02:32:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2530.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 May 2017 21:47:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multiple Pages of Modules using CSS on Fri, 17 Nov 2017 18:41:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I installed your fork and it works just fine.<br />
That was what I was looking for with a touchscreen: D<br />
But now I have a problem.<br />
If I take the comment to activate other pages and check to a widget, the reference to page 3 is not displayed and the points to touch are just two.</p>
<p dir="auto">Is there anything else to modify in the main.js file?</p>
<p dir="auto">Thank you, Alberto</p>
]]></description><link>https://forum.magicmirror.builders/post/31289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31289</guid><dc:creator><![CDATA[alverman]]></dc:creator><pubDate>Fri, 17 Nov 2017 18:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Pages of Modules using CSS on Mon, 22 May 2017 04:15:17 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 <a class="plugin-mentions-user plugin-mentions-a" href="/user/anhalter42" aria-label="Profile: Anhalter42">@<bdi>Anhalter42</bdi></a>  – Wanted to thank you both for the suggestions.</p>
<p dir="auto">If anyone is interested my fork w/ navigation enabled is here: <a href="https://github.com/shbatm/MMM-Carousel" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Carousel w/ Navigation &amp; Moveable Modules</a> – the navigation uses my module <a href="https://github.com/shbatm/MMM-KeyBindings" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-KeyBindings</a>, which isn’t necessary if you just want to use a mouse or touchscreen.</p>
]]></description><link>https://forum.magicmirror.builders/post/21887</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21887</guid><dc:creator><![CDATA[shbatm]]></dc:creator><pubDate>Mon, 22 May 2017 04:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Pages of Modules using CSS on Wed, 10 May 2017 12:19:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> another possibility to do something similar is <a href="https://github.com/tosti007/MMM-ProfileSwitcher" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-ProfileSwitcher</a> + <a href="https://github.com/Jopyth/MMM-Remote-Control" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Remote-Control</a>. I’ve used this to imitate “pages” and it worked quite well.</p>
<p dir="auto">Both alternatives don’t naturally come with those fancy arrows and dots, though.</p>
]]></description><link>https://forum.magicmirror.builders/post/21388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21388</guid><dc:creator><![CDATA[Anhalter42]]></dc:creator><pubDate>Wed, 10 May 2017 12:19:09 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Pages of Modules using CSS on Tue, 09 May 2017 22:39:20 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 - Thanks for the suggestion!</p>
<p dir="auto">I had looked at it briefly, but saw it used timers to rotate automatically and I was looking for something semi-static that I could use to ‘page through’ with a remote when I got one set-up.  Looking more closely, it wouldn’t be too hard to fork and replace the timers with notifications.</p>
]]></description><link>https://forum.magicmirror.builders/post/21365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21365</guid><dc:creator><![CDATA[shbatm]]></dc:creator><pubDate>Tue, 09 May 2017 22:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Pages of Modules using CSS on Tue, 09 May 2017 22:15:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shbatm" aria-label="Profile: shbatm">@<bdi>shbatm</bdi></a> did you try the module carousel? That should do the trick without modifying files and can help you to implement your solution</p>
]]></description><link>https://forum.magicmirror.builders/post/21364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21364</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 09 May 2017 22:15:14 GMT</pubDate></item></channel></rss>
