<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Globe]]></title><description><![CDATA[<h2>MMM-Globe</h2>
<h4>Description</h4>
<p dir="auto">The Magic Mirror Globe (MMM-Globe) Module is a utility module I’ve created, that displays a live, rotating globe, and has been designed to look absolutely incredible on your Magic Mirror. The module can be configured to show default destinations, or you can customise it to highlight customised locations.</p>
<p dir="auto">Feedback and improvement suggestions are welcomed.</p>
<p dir="auto"><strong>(UPDATE) IMPORTANT NOTE: Due to the intensive calculations needed to construct the objects, and the computational ability needed, <em><strong>I do not recommend using this module if your Mirror uses a Raspberry Pi.</strong></em> Please only use this module if you have something a little more powerful driving your mirror. I don’t want my work to be responsible for any mishaps with your devices.</strong></p>
<p dir="auto"><a href="https://youtu.be/6KSCDIaIgdA" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/6KSCDIaIgdA</a></p>
<h4>Screenshots</h4>
<p dir="auto"><img src="http://i.imgur.com/oF3mxBC.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i.imgur.com/3VAToUR.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<h4>Download</h4>
<p dir="auto">Download Link available on <a href="https://github.com/Eunanibus/MMM-Globe" target="_blank" rel="noopener noreferrer nofollow ugc">Github Page</a></p>
<h4>Version 1.0</h4>
<ul>
<li>Initial Commit. Globe stable. ReadMe Added.</li>
</ul>
<h4>Version 1.1</h4>
<ul>
<li>Adjusted size translations to fit varying size monitors based on user feedback</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/2553/mmm-globe</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 15:32:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2553.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 May 2017 19:55:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 23:06:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/post/120554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120554</guid><dc:creator><![CDATA[greedyvegan]]></dc:creator><pubDate>Thu, 10 Oct 2024 23:06:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 22:58:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greedyvegan" aria-label="Profile: greedyvegan">@<bdi>greedyvegan</bdi></a> yep, that’s why you run my script. lots of things to do</p>
]]></description><link>https://forum.magicmirror.builders/post/120553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120553</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 10 Oct 2024 22:58:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 22:44:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i accidently ran pm2 start instead of pm2 start mm<br />
then it returned</p>
<p dir="auto">[PM2][ERROR] File ecosystem.config.js not found</p>
<p dir="auto">then i ran pm2 start mm<br />
<p dir="auto">[PM2][ERROR] Script not found: /home/thecastle/MagicMirror/mm</p>
<p dir="auto">status<br />
<img src="/assets/uploads/files/1728599874971-screenshot-2024-10-10-at-6.37.50-pm.png" alt="Screenshot 2024-10-10 at 6.37.50 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">after pm2 delete 0<br />
<img src="/assets/uploads/files/1728599942332-screenshot-2024-10-10-at-6.38.56-pm.png" alt="Screenshot 2024-10-10 at 6.38.56 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">after pm2 save</p>
<p dir="auto"><img src="/assets/uploads/files/1728599993687-screenshot-2024-10-10-at-6.39.49-pm.png" alt="Screenshot 2024-10-10 at 6.39.49 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">update -<br />
it’s currently running (it was always running, it just had a weird error)<br />
and told me to copy/paste</p>
<p dir="auto">sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi</p>
]]></description><link>https://forum.magicmirror.builders/post/120552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120552</guid><dc:creator><![CDATA[greedyvegan]]></dc:creator><pubDate>Thu, 10 Oct 2024 22:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 22:13:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greedyvegan" aria-label="Profile: greedyvegan">@<bdi>greedyvegan</bdi></a> that pm2 error is usually caused by using sudo sometime when you shouldn’t</p>
<p dir="auto">what happened before that? is that the first time w pm2</p>
<p dir="auto">maybe</p>
<p dir="auto">pm2 status<br />
pm2 delete xxx<br />
where xxx is the name or number on the MagicMirror line</p>
<p dir="auto">then run my fixuppm2 script</p>
<p dir="auto">pm2 seems fragile recently.  not sure why</p>
]]></description><link>https://forum.magicmirror.builders/post/120551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120551</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 10 Oct 2024 22:13:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 21:51:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">like this?<br />
<img src="/assets/uploads/files/1728596983127-screenshot-2024-10-10-at-5.49.34-pm.png" alt="Screenshot 2024-10-10 at 5.49.34 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I got this error<br />
]]></description><link>https://forum.magicmirror.builders/post/120550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120550</guid><dc:creator><![CDATA[greedyvegan]]></dc:creator><pubDate>Thu, 10 Oct 2024 21:51:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 01:09:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greedyvegan" aria-label="Profile: greedyvegan">@<bdi>greedyvegan</bdi></a> you will need to enable the gpu in the system boot.txt</p>
<p dir="auto">AND</p>
<p dir="auto">tell MagicMirror electron to use it</p>
<pre><code>export ELECTRON_ENABLE_GPU=1
<p dir="auto">in the script before</p>
<pre><code>npm  start
<p dir="auto">if you used my script to install MagicMirror ,  that is ~/MagicMirror/installers/mm.sh</p>
]]></description><link>https://forum.magicmirror.builders/post/120528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120528</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 10 Oct 2024 01:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 10 Oct 2024 01:11:46 GMT]]></title><description><![CDATA[<p dir="auto">@hiro-nguyen sure, css</p>
<p dir="auto">google search css transparent background</p>
]]></description><link>https://forum.magicmirror.builders/post/120527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120527</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 10 Oct 2024 01:11:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 09 Oct 2024 23:18:08 GMT]]></title><description><![CDATA[<p dir="auto">in the beginning of this post from 2021, it was recommended NOT to use this with a raspberry pi<br />
today, in 2024, I have a raspberry pi 5, does that matter? lol</p>
<p dir="auto">anyway,  the left is on my pi 5 and the right is viewing it on a browser on my computer</p>
<p dir="auto"><img src="/assets/uploads/files/1728515776968-screenshot-2024-10-09-at-7.16.10-pm.png" alt="Screenshot 2024-10-09 at 7.16.10 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">is there an update on a lite version?</p>
]]></description><link>https://forum.magicmirror.builders/post/120526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120526</guid><dc:creator><![CDATA[greedyvegan]]></dc:creator><pubDate>Wed, 09 Oct 2024 23:18:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 28 Jul 2021 01:50:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi, may i ask if it is possible to change background to transparent ?<br />
Thanks,</p>
]]></description><link>https://forum.magicmirror.builders/post/93212</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93212</guid><dc:creator><![CDATA[hiro.nguyen]]></dc:creator><pubDate>Wed, 28 Jul 2021 01:50:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 07 May 2021 09:44:28 GMT]]></title><description><![CDATA[<p dir="auto">HI</p>
<p dir="auto">here is my working config:</p>
<p dir="auto">Greetings Torsten</p>
<pre><code>{
		module: 'MMM-Globe',
		position: 'fullscreen_below',	// This can be any of the regions. Best results in lower_third
                size:"medium", // Globe size. See configuration options below for more options
                dayLength: 43, // (Optional) Rotation speed. See configuration options below
                viewAngle: 15, // (Optional) Globe tilt. See configuration options below.
                locations: [
                    // Fill with location Objects if desired
                    // e.g.
                    // {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                    // {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                    // Individual values must be seperated by a comma.
                    // You can look up the latitude and longitude for a specific location on Google Maps.
                    {lat:49.6294791,lng:7.8252699, label: "Rockenhausen" },
                    {lat:40.7223507,lng:-73.9901943, label: "New York" },
                    {lat:36.1047739,lng:-115.1421297, label: "Las Vegas" },
                    {lat:13.7544142,lng:100.5020575, label: "Bangkok" },
]]></description><link>https://forum.magicmirror.builders/post/91310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91310</guid><dc:creator><![CDATA[Foxy25]]></dc:creator><pubDate>Fri, 07 May 2021 09:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 06 May 2021 16:25:13 GMT]]></title><description><![CDATA[<p dir="auto">hi guys… my GLOBE is woking fine… but there is a problem with City NAMES, i won’t  display…, config is ok… can anyone help me …?</p>
<p dir="auto">{<br />
module: ‘MMM-Globe’,<br />
position: ‘lower_third’,	// This can be any of the regions. Best results in lower_third<br />
config: {<br />
size:“x-large”, // Globe size. See configuration options below for more options<br />
dayLength: 38, // (Optional) Rotation speed. See configuration options below<br />
viewAngle: 15, // (Optional) Globe tilt. See configuration options below.<br />
introLinesDuration: 2000,<br />
receiveExternalLocations: 0,<br />
locations: [<br />
// Fill with location Objects if desired<br />
// e.g.<br />
{lat:37.77493,lng:-122.41942, label:“San Francisco”},<br />
{lat:7.58403,lng:80.78798, label:“Sri Lanka”},<br />
{lat:-23.5475,lng:-46.63611, label:“Sao Paulo”}</p>
<pre><code>                // Individual values must be seperated by a comma.
]]></description><link>https://forum.magicmirror.builders/post/91297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91297</guid><dc:creator><![CDATA[damith]]></dc:creator><pubDate>Thu, 06 May 2021 16:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sun, 02 May 2021 12:58:59 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you very much for your reply… you are the NUMBER ONE… it works fine… Thanks again.</p>
<p dir="auto">i have done NPM INSTALL… its worked fine…:face_savoring_food: :face_savoring_food:</p>
]]></description><link>https://forum.magicmirror.builders/post/91218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91218</guid><dc:creator><![CDATA[damith]]></dc:creator><pubDate>Sun, 02 May 2021 12:58:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sun, 02 May 2021 11:32:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/damith" aria-label="Profile: damith">@<bdi>damith</bdi></a> did u do the npm install in the module folder after git clone?</p>
<p dir="auto">if u look at the startup messages, where u start mm<br />
npm start<br />
or pm2 logs --lines=100</p>
<p dir="auto">you might see a message, module not found.<br />
this is the number 1 clue you didn’t do the npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/91216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91216</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 May 2021 11:32:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sun, 02 May 2021 10:27:45 GMT]]></title><description><![CDATA[<p dir="auto">hi@thgmirror<br />
Thank you very much for you reply, I’ve checked with built in check but no errors …!!</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm run config:check</p>
<p dir="auto">magicmirror@2.15.0 config:check /home/pi/MagicMirror<br />
node js/check_config.js</p>
<p dir="auto">[02.05.2021 12:20.01.503] [INFO]  Checking file…  /home/pi/MagicMirror/config/config.js<br />
[02.05.2021 12:20.01.719] [INFO]  Your configuration file doesn’t contain syntax errors :)<br />
pi@raspberrypi:~/MagicMirror $</p>
]]></description><link>https://forum.magicmirror.builders/post/91215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91215</guid><dc:creator><![CDATA[damith]]></dc:creator><pubDate>Sun, 02 May 2021 10:27:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sun, 02 May 2021 10:00:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/damith" aria-label="Profile: damith">@<bdi>damith</bdi></a>,</p>
<p dir="auto">May be, you have an issue in the config.js.<br />
You can use the built-in check-tool from within the MagicMirror folder named<br />
<p dir="auto">Or use an external Website (I use <a href="https://esprima.org/demo/validate.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://esprima.org/demo/validate.html</a>) to see if it is valed.</p>
<p dir="auto">Greetings from Germany<br />
Thomas</p>
]]></description><link>https://forum.magicmirror.builders/post/91213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91213</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Sun, 02 May 2021 10:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sun, 02 May 2021 09:45:49 GMT]]></title><description><![CDATA[<p dir="auto">hi everyone, I’ve tried to install on my PI but it won’t work…am getting black screen, here is my config file… any HELP…?<br />
modules: [</p>
<pre><code>	{
		module: "alert",
		module: "updatenotification",
		position: "top_bar"
		module: "clock",
		position: "top_left"
		header: "Italy Holidays",
					symbol: "calendar-check",
					url: "webcal://www.calendarlabs.com/ical-calendar/ics/53/Italy_Holidays.ics"					}
		module: "compliments",
		position: "top_center"
		module: "weather",
			type: "current",
			locationID: "3169070", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
			apiKey: "492da6299f48937482d3c321215289b0"
		module: "weather",
		header: "Weather Forecast",
			type: "forecast",
		module: "newsfeed",
		position: "bottom_bar",
			feeds: [
					title: "REPUBBLICA",
					url: "https://www.repubblica.it/rss/homepage/rss2.0.xml"
			showSourceTitle: true,
			showPublishDate: true,
			broadcastNewsFeeds: true,
			broadcastNewsUpdates: true
	position: 'lower_third',	// This can be any of the regions. Best results in lower_third
            size:"x-small", // Globe size. See configuration options below for more options
            locations: [
                // e.g.
<p dir="auto">};</p>
<p dir="auto">/*************** DO NOT EDIT THE LINE BELOW ***************/<br />
if (typeof module !== “undefined”) {module.exports = config;}</p>
]]></description><link>https://forum.magicmirror.builders/post/91211</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91211</guid><dc:creator><![CDATA[damith]]></dc:creator><pubDate>Sun, 02 May 2021 09:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 04 Mar 2021 07:37:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/foxy25" aria-label="Profile: foxy25">@<bdi>foxy25</bdi></a> you are welcome :)</p>
]]></description><link>https://forum.magicmirror.builders/post/89106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89106</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Thu, 04 Mar 2021 07:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 03 Mar 2021 17:51:15 GMT]]></title><description><![CDATA[<p dir="auto">It works perfect!!!</p>
<p dir="auto">Thank you so much for you support!!!</p>
<p dir="auto">Greetings from Germany</p>
<p dir="auto">Foxy</p>
]]></description><link>https://forum.magicmirror.builders/post/89104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89104</guid><dc:creator><![CDATA[Foxy25]]></dc:creator><pubDate>Wed, 03 Mar 2021 17:51:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 03 Mar 2021 17:06:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/foxy25" aria-label="Profile: foxy25">@<bdi>foxy25</bdi></a> to make globe transparent there are two changes required.</p>
<ul>
<li>Module div’s background color</li>
<li>Globe canvas itself have black color as background.</li>
</ul>
<p dir="auto">First one can be easily doable with css but to make globe transparent you will need to change the code as well. Do below to make globe transperent.</p>
<ul>
<li>In custom.css add below css</li>
</ul>
<pre><code>.globe
	background-color: unset;
<ul>
<li>in modules\MMM-Globe\encom-globe.js file find below line and change it to.</li>
</ul>
<p dir="auto">from</p>
<pre><code>this.renderer = new THREE.WebGLRenderer( { antialias: true } );
<p dir="auto">to</p>
<pre><code>this.renderer = new THREE.WebGLRenderer( { antialias: true, alpha: true } );
<hr />
<p dir="auto">below is output</p>
<p dir="auto">Before</p>
<p dir="auto"><img src="/assets/uploads/files/1614791107241-dde6476f-f02b-48b9-aa2c-f60c4bead58a-image.png" alt="dde6476f-f02b-48b9-aa2c-f60c4bead58a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">After<br />
<img src="/assets/uploads/files/1614791187382-0214ddbf-09fe-4ba8-9528-ea96ed28ea7c-image.png" alt="0214ddbf-09fe-4ba8-9528-ea96ed28ea7c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Let me know how/if it works for you.</p>
]]></description><link>https://forum.magicmirror.builders/post/89103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89103</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Wed, 03 Mar 2021 17:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 03 Mar 2021 06:49:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wenike" aria-label="Profile: wenike">@<bdi>wenike</bdi></a><br />
Hi,</p>
<p dir="auto">i use the command in the styles.css of the modul, not in the custom.css.</p>
<p dir="auto">It works, but it makes the complete module invisible, not only the background behind the globe.</p>
<p dir="auto">Thank you for your support.</p>
]]></description><link>https://forum.magicmirror.builders/post/89092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89092</guid><dc:creator><![CDATA[Foxy25]]></dc:creator><pubDate>Wed, 03 Mar 2021 06:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 03 Mar 2021 01:17:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/foxy25" aria-label="Profile: foxy25">@<bdi>foxy25</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/foxy25" aria-label="Profile: foxy25">@<bdi>foxy25</bdi></a> In your custom.css file, see if adding:</p>
<pre><code>.globe { opacity: 0.0; }
<p dir="auto">Fixes the issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/89088</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89088</guid><dc:creator><![CDATA[Wenike]]></dc:creator><pubDate>Wed, 03 Mar 2021 01:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Tue, 02 Mar 2021 20:38:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have a question about the module:</p>
<p dir="auto">I would like to make the background transparent, is that possible? At the moment it is black.</p>
<p dir="auto">That would help me, because I have a slideshow running in the background and the black background behind the globe doesn’t look so nice …</p>
<p dir="auto">Would be very grateful if someone could help.</p>
<p dir="auto"><img src="/assets/uploads/files/1614717495792-20210302_204736.jpg" alt="20210302_204736.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/89081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89081</guid><dc:creator><![CDATA[Foxy25]]></dc:creator><pubDate>Tue, 02 Mar 2021 20:38:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Mon, 15 Feb 2021 09:17:50 GMT]]></title><description><![CDATA[<p dir="auto">What a beautiful modul! Any chance to change the font size to be able to fit more destinations next to each others? I did try to find it in the .css but had no luck yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/88490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88490</guid><dc:creator><![CDATA[oli28]]></dc:creator><pubDate>Mon, 15 Feb 2021 09:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Mon, 15 Feb 2021 00:04:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idea215" aria-label="Profile: idea215">@<bdi>idea215</bdi></a> Did you go to the github link from the first post or just Googled for MMM-Globe? Yours looks like mine which is from <a href="https://github.com/LukeSkywalker92/MMM-Globe" target="_blank" rel="noopener noreferrer nofollow ugc">a different MMM-Globe</a></p>
]]></description><link>https://forum.magicmirror.builders/post/88487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88487</guid><dc:creator><![CDATA[Wenike]]></dc:creator><pubDate>Mon, 15 Feb 2021 00:04:34 GMT</pubDate></item></channel></rss>
