<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyCalendar]]></title><description><![CDATA[<p dir="auto">[card:jclarke0000/MMM-MyCalendar]</p>
<p dir="auto"><strong>UPDATE: v2.0 released – requires MagicMirror v 2.2.0</strong><br />
See below for details.</p>
<p dir="auto">This is based on the default calendar module, and is functionally exactly the same.  The difference is in presentation layout:</p>
<p dir="auto"><img src="/assets/uploads/files/1494633846527-screen-shot-2017-05-12-at-8.00.40-pm.png" alt="0_1494633843517_Screen Shot 2017-05-12 at 8.00.40 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>A note on v2.0:</strong><br />
I’ve updated this module to use the new Nunjucks templating system. It also adds a new optional 2-column layout, useful if you’ve assigned MMM-MyCalendar to a wide region in your layout.  See screenshot below.  If you want to use this version you will need MagicMirror v2.2.0.  Otherwise, you can download v1.0 here, which will work with earlier MM versions but will not have the 2-column layout option:<br />
<a href="https://github.com/jclarke0000/MMM-MyCalendar/releases/tag/v1.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-MyCalendar/releases/tag/v1.0</a></p>
<p dir="auto"><img src="/assets/uploads/files/1521028881516-screen-shot-2018-03-14-at-12.00.41-pm.png" alt="0_1521028879950_Screen Shot 2018-03-14 at 12.00.41 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2559/mmm-mycalendar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 21:42:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2559.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 May 2017 00:05:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyCalendar on Sat, 21 Nov 2020 18:35:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charp07" aria-label="Profile: charp07">@<bdi>charp07</bdi></a> What was the fix to your Loading issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/84899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84899</guid><dc:creator><![CDATA[PatrickGolfer]]></dc:creator><pubDate>Sat, 21 Nov 2020 18:35:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Tue, 11 Feb 2020 10:09:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi @j-e-f-f,</p>
<p dir="auto">Thank you for the great module! :)<br />
I have added an option to have a calendar label displayed before the event text as it looks more intuitive and does not require to remember colors :). If you are ok to have this added to your code I can either send the updates to you or create a pull request in github.</p>
<p dir="auto">Here is the screenshot (I use MM as a picture frame, not a mirror, with bright colored image, that’s why it is black on white in my case):<br />
<img src="http://bianca.bandorin.ru/mycalendar-modified.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/69415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69415</guid><dc:creator><![CDATA[eliah]]></dc:creator><pubDate>Tue, 11 Feb 2020 10:09:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Mon, 03 Feb 2020 22:10:59 GMT]]></title><description><![CDATA[<p dir="auto">Salve ho installato oggi il modulo MMM-MyCalendar ma per cambiare le icone o i simboli  ed assegnarle una diversa come  si fa ?Potreste mettermi un esempio?Grazie.Inoltre è possibile cambiare colore esempio Martedi 5 Febbario rosso e  Mercoledi 6 Febbraio in verde?Grazie.</p>
]]></description><link>https://forum.magicmirror.builders/post/69031</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69031</guid><dc:creator><![CDATA[Alex2020]]></dc:creator><pubDate>Mon, 03 Feb 2020 22:10:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sat, 18 Jan 2020 15:49:20 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f</p>
<p dir="auto">Hey. I found your Module last days and i love it. Thanks for that.</p>
<p dir="auto">One question.<br />
I have one added calendar (holidays) that have a “description” in his calendar entry.<br />
So the Modul Shows three lines.<br />
First with the Titel (christmas),<br />
Second with date (24 Dezember)<br />
third with description (<a href="http://calovo.de" target="_blank" rel="noopener noreferrer nofollow ugc">calovo.de</a>).</p>
<p dir="auto">Is it possible to hide the description?</p>
]]></description><link>https://forum.magicmirror.builders/post/68282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68282</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Sat, 18 Jan 2020 15:49:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Thu, 07 Nov 2019 05:17:15 GMT]]></title><description><![CDATA[<p dir="auto">Did anybody’s MMM-MyCalendar module break after daylight savings (Sunday November 3rd)? Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞</p>
]]></description><link>https://forum.magicmirror.builders/post/63964</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63964</guid><dc:creator><![CDATA[rookiepilot]]></dc:creator><pubDate>Thu, 07 Nov 2019 05:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Mon, 05 Aug 2019 16:18:20 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f This feature (grouping by day) would be awesome! Have you had a chance to make any progress on this?</p>
]]></description><link>https://forum.magicmirror.builders/post/59813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59813</guid><dc:creator><![CDATA[BRSQUIRRL]]></dc:creator><pubDate>Mon, 05 Aug 2019 16:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 19 May 2019 18:02:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charp07" aria-label="Profile: charp07">@<bdi>charp07</bdi></a> figured it out! Sorry!</p>
]]></description><link>https://forum.magicmirror.builders/post/57189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57189</guid><dc:creator><![CDATA[charp07]]></dc:creator><pubDate>Sun, 19 May 2019 18:02:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 19 May 2019 06:55:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zzaidi148" aria-label="Profile: zzaidi148">@<bdi>zzaidi148</bdi></a> @j-e-f-f</p>
<p dir="auto">I have this same issue and haven’t had any luck in resolving the issue. I even copied the recommended config from earlier in this forum. Is there something that I am missing?</p>
<p dir="auto">It will just say, “Loading…”</p>
<p dir="auto"><img src="/assets/uploads/files/1558248906461-mmmirror.png" alt="0_1558248904989_MMMirror.PNG" class=" img-fluid img-markdown" /></p>
<pre><code>{
			module: "MMM-MyCalendar",
			classes: "default everyone",
			header: "Upcoming",
			disabled: false,
				colored: true,
				maximumNumberOfDays: 30,
				maximumEntries: 5,
				fade: false,
				maxTitleLength: 500,
				useRelativeDates: false,
				dayOfWeekFormat: "dddd",
				timeFormat: "h:mm A",
				dateFormat: "MMMM D",
				joiningWord: "at",
				urgency: 1,
					url: "https://calendar.google.com/calendar/ical path",
					color: "#ffb350"
					color: "#ff77d4"
]]></description><link>https://forum.magicmirror.builders/post/57178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57178</guid><dc:creator><![CDATA[charp07]]></dc:creator><pubDate>Sun, 19 May 2019 06:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Mon, 18 Mar 2019 16:31:57 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f said in <a href="/post/54449">MMM-MyCalendar</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> No, but you can add a background colour to the module to make the text stand out better.  try something like this in your <code>custom.css</code> file:</p>
<pre><code>.MMM-MyCalendar .module-content {
  background-color: rgba(0,0,0,0.5);
<p dir="auto">The first three parameters <code>0,0,0</code> mean black, and the fourth parameter <code>0.5</code> is the level of transparency.  Specify a decimal between 0 and 1, where 0 is fully transparent, and 1 is fully opaque.</p>
<p dir="auto">Thanks j.e.f.f for your help !</p>
]]></description><link>https://forum.magicmirror.builders/post/54502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54502</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Mon, 18 Mar 2019 16:31:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 17 Mar 2019 19:23:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> No, but you can add a background colour to the module to make the text stand out better.  try something like this in your <code>custom.css</code> file:</p>
]]></description><link>https://forum.magicmirror.builders/post/54449</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54449</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 17 Mar 2019 19:23:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 17 Mar 2019 15:55:19 GMT]]></title><description><![CDATA[<p dir="auto">is it possible to color text ?<br />
because when i you have a wallpaper sometimes text is not visible.</p>
<p dir="auto">thanks for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/54435</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54435</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Sun, 17 Mar 2019 15:55:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Tue, 04 Dec 2018 23:59:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hnsy" aria-label="Profile: hnsy">@<bdi>hnsy</bdi></a> I’m not sure… I’m using the default calendar code to retrieve the calendar data.  I’ve only customized the display portion.  If multi-day blocks are included in the data then it should be possible.  I’ll have to take a look.</p>
]]></description><link>https://forum.magicmirror.builders/post/47717</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47717</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Tue, 04 Dec 2018 23:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Tue, 04 Dec 2018 22:19:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi @j-e-f-f , thanks a lot for your really great modules. I really appreciate the style and convenience of your modules.<br />
As I am using MyCalendar now for a while, I was wondering, if there is a possibility to display time-ranges? I mean the start date of a range is displayed, but when an event is taking place for, let’s say three days, currently I can only display the first day (start time).<br />
Is there a possibility that all (3) days would appear in the list?</p>
<p dir="auto">Maybe it is already integrated and I just didn’t get it.</p>
<p dir="auto">Once more: Thumbs up for your work!!</p>
<p dir="auto">Cheers, HNSY</p>
]]></description><link>https://forum.magicmirror.builders/post/47713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47713</guid><dc:creator><![CDATA[hnsy]]></dc:creator><pubDate>Tue, 04 Dec 2018 22:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 11 Nov 2018 16:18:43 GMT]]></title><description><![CDATA[<p dir="auto">My module does not have a configurable icon. It wouldn’t work with the calendar icon with the date inside.</p>
<p dir="auto">I based my modyle off the default calendar midule included wth MM. that one has a configurablenicon and perhaps I forgot to remove the instruction in my version.</p>
<p dir="auto">Mine never had a configurable icon.  I might enable a few options that would work with the date number inside, but at the moment you just get the one.</p>
]]></description><link>https://forum.magicmirror.builders/post/46623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46623</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 11 Nov 2018 16:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Sun, 11 Nov 2018 04:50:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi @j-e-f-f , thanks for the great module. The config indicates that the icons are customizable using Font Awesome, but the behavior and the code (line ~181) seem to indicate otherwise. Any chance we could get it back? Do you know how you would want it implement with the svg system you have?</p>
]]></description><link>https://forum.magicmirror.builders/post/46606</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46606</guid><dc:creator><![CDATA[DolphinScientist]]></dc:creator><pubDate>Sun, 11 Nov 2018 04:50:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Fri, 09 Nov 2018 15:17:12 GMT]]></title><description><![CDATA[<p dir="auto">When I set maximumEntries: 8 I only see items 3 items.<br />
I did some testing and I think the reason I only see 3 items is because some items are excluded.<br />
I think the excluded items are counted as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/46557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46557</guid><dc:creator><![CDATA[VinGroot]]></dc:creator><pubDate>Fri, 09 Nov 2018 15:17:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Thu, 08 Nov 2018 15:10:49 GMT]]></title><description><![CDATA[<p dir="auto">I’d like to have absolute days in my calendar, but all I see is ‘today’, Saturday (without date), etc.</p>
<p dir="auto">My config is:<br />
<em>maximumEntries: 8,<br />
useRelativeDates: false,<br />
joiningWord: “om”,<br />
maxTitleLength: 48,<br />
dateFormat: “D MMMM YYYY”,<br />
timeFormat: “HH:mm”,<br />
urgency: 0,<br />
getRelative: 0,<br />
calendars: [</em>* secret *<em>]</em></p>
<p dir="auto">Am I doing something wrong?</p>
<p dir="auto">Some things like timeFormat (HH:mm), maxTitleLength and joiningWord work fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/46507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46507</guid><dc:creator><![CDATA[VinGroot]]></dc:creator><pubDate>Thu, 08 Nov 2018 15:10:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Thu, 25 Oct 2018 19:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bokifide" aria-label="Profile: bokifide">@<bdi>bokifide</bdi></a> You would need to write some custom CSS to adjust the width of the containing column.  The module is designed to used all of the space available in its container.</p>
]]></description><link>https://forum.magicmirror.builders/post/45893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45893</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Thu, 25 Oct 2018 19:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCalendar on Tue, 23 Oct 2018 15:38:38 GMT]]></title><description><![CDATA[<p dir="auto">Hey there!</p>
<p dir="auto">For some time now, i have the following issue:</p>
<p dir="auto">My MMM-MyCalendar is showing dates wrongly (one day in the past) although they are correct in the used ics-file.</p>
<p dir="auto">I moved my question over to the “troubleshooting” section (as it seems it fits better there):</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/8963/mmm-mycalendar-showing-wrong-dates-days-one-day-in-the-past">https://forum.magicmirror.builders/topic/8963/mmm-mycalendar-showing-wrong-dates-days-one-day-in-the-past</a></p>
]]></description><link>https://forum.magicmirror.builders/post/45732</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45732</guid><dc:creator><![CDATA[Medo]]></dc:creator><pubDate>Tue, 23 Oct 2018 15:38:38 GMT</pubDate></item></channel></rss>
