<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyNest]]></title><description><![CDATA[<p dir="auto">This is a fork of MMM-Nest by Luke Moch, modified to look much closer to the display you see in the Nest app.</p>
<p dir="auto"><strong>NOTE</strong> I have not tested this with multiple thermostats, as I only have one in my house, nor have I tested the display of list mode as it defeats the purpose of why I modified this module.</p>
<p dir="auto">[card:jclarke0000/MMM-MyNest]</p>
<p dir="auto"><img src="/assets/uploads/files/1494637771208-screen-shot-2017-05-12-at-8.55.45-pm.png" alt="0_1494637770578_Screen Shot 2017-05-12 at 8.55.45 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1494637966635-nest2.png" alt="0_1494637966438_nest2.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2560/mmm-mynest</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 02:59:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2560.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 May 2017 01:10:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyNest on Wed, 31 May 2017 15:43:56 GMT]]></title><description><![CDATA[<p dir="auto">Anyone working on integrating the nest protect smoke detectors?</p>
]]></description><link>https://forum.magicmirror.builders/post/22226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22226</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Wed, 31 May 2017 15:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyNest on Mon, 29 May 2017 21:46:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> hey! Great to hear you like the changes!  I’ve been thinking about modifying this to have the ticks in a citcle around th outside of the widget, just like the Nest itself. But I think it will require some pretty heavy changes to the markup and subsequently to the dom generator.</p>
<p dir="auto">Why don’t I play around on my version of the module then when I have something working I’ll message you to figure out how easy it would be to merge the two.</p>
]]></description><link>https://forum.magicmirror.builders/post/22150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22150</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Mon, 29 May 2017 21:46:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyNest on Mon, 29 May 2017 15:42:30 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Your CSS changes look great!  I added them back into my module with a few tweaks to get the heat&amp;cool mode working again.  If you just want to send me pull requests instead of making a new module with cosmetic changes, I’d me more than happy to merge them.</p>
]]></description><link>https://forum.magicmirror.builders/post/22142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22142</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Mon, 29 May 2017 15:42:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyNest on Thu, 18 May 2017 13:25:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tidus5" aria-label="Profile: tidus5">@<bdi>tidus5</bdi></a> Yeah I’ve been thinking about how I can create the same display as the Nest itself, with the ticks on the outside of the circle, the ambient temperature, the target heating .cooling temperature, etc.  I plan to release an update once I figure that out.</p>
]]></description><link>https://forum.magicmirror.builders/post/21777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21777</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Thu, 18 May 2017 13:25:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyNest on Thu, 18 May 2017 12:34:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello @j-e-f-f</p>
<p dir="auto">Thanks for your update (looks amazing)<br />
is there a way to see also the ambient temperature ?<br />
and i just built my IR frame :D so im looking to add the touch option - is it something possible ?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/21764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21764</guid><dc:creator><![CDATA[tidus5]]></dc:creator><pubDate>Thu, 18 May 2017 12:34:07 GMT</pubDate></item></channel></rss>
