<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error installing the magicmirror]]></title><description><![CDATA[<pre><code>
691 verbose lifecycle electron@1.6.8~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
692 verbose lifecycle electron@1.6.8~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron
693 silly lifecycle electron@1.6.8~postinstall: Args: [ '-c', 'node install.js' ]
694 silly lifecycle electron@1.6.8~postinstall: Returned: code: 1  signal: null
695 info lifecycle electron@1.6.8~postinstall: Failed to exec postinstall script
696 verbose unlock done using /home/pi/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
697 silly rollbackFailedOptional Starting
698 silly rollbackFailedOptional Finishing
699 silly runTopLevelLifecycles Finishing
700 silly install printInstalled
701 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
702 verbose If you need help, you may report this error at:
702 verbose     &lt;https://github.com/npm/npm/issues&gt;
703 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
704 verbose If you need help, you may report this error at:
704 verbose     &lt;https://github.com/npm/npm/issues&gt;
705 verbose stack Error: electron@1.6.8 postinstall: `node install.js`
705 verbose stack Exit status 1
705 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
705 verbose stack     at emitTwo (events.js:106:13)
705 verbose stack     at EventEmitter.emit (events.js:191:7)
705 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
705 verbose stack     at ChildProcess.emit (events.js:191:7)
705 verbose stack     at maybeClose (internal/child_process.js:886:16)
705 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
706 verbose pkgid electron@1.6.8
707 verbose cwd /home/pi/MagicMirror
708 error Linux 4.4.21-v7+
709 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "electron"
710 error node v6.10.3
711 error npm  v3.10.10
712 error code ELIFECYCLE
713 error electron@1.6.8 postinstall: `node install.js`
713 error Exit status 1
714 error Failed at the electron@1.6.8 postinstall script 'node install.js'.
714 error Make sure you have the latest version of node.js and npm installed.
714 error If you do, this is most likely a problem with the electron package,
714 error not with npm itself.
714 error Tell the author that this fails on your system:
714 error     node install.js
714 error You can get information on how to open an issue for this project with:
714 error     npm bugs electron
714 error Or if that isn't available, you can get their info via:
714 error     npm owner ls electron
714 error There is likely additional logging output above.
715 verbose exit [ 1, true ]
<p dir="auto">Having error installing the magic mirror and getting it to run… some help would greatly be appreciated!</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/2589/error-installing-the-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 05:49:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2589.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 May 2017 07:42:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error installing the magicmirror on Fri, 19 May 2017 00:04:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jubeenshah" aria-label="Profile: jubeenshah">@<bdi>jubeenshah</bdi></a> said in <a href="/post/21778">Error installing the magicmirror</a>:</p>
<p dir="auto">I solved it on my own and it worked out…</p>
<p dir="auto">Perhaps you’ll post how you solved the issue so others might benefit if they have the same issue. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/21826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21826</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 19 May 2017 00:04:30 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Thu, 18 May 2017 17:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jubeenshah" aria-label="Profile: jubeenshah">@<bdi>jubeenshah</bdi></a> Glad you got it.</p>
]]></description><link>https://forum.magicmirror.builders/post/21790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21790</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 18 May 2017 17:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Thu, 18 May 2017 13:35:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>  Nevermind bro… I solved it on my own and it worked out… Thanksss a lot brother</p>
]]></description><link>https://forum.magicmirror.builders/post/21778</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21778</guid><dc:creator><![CDATA[jubeenshah]]></dc:creator><pubDate>Thu, 18 May 2017 13:35:00 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Thu, 18 May 2017 13:13:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a></p>
<pre><code>&gt; magicmirror@2.1.1 start /home/pi/MagicMirror
&gt; sh run-start.sh
/home/pi/MagicMirror/node_modules/electron/index.js:9
  throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
    at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
    at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.1.1 start script.
npm ERR!     /home/pi/.npm/_logs/2017-05-18T13_11_39_986Z-debug.log
]]></description><link>https://forum.magicmirror.builders/post/21774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21774</guid><dc:creator><![CDATA[jubeenshah]]></dc:creator><pubDate>Thu, 18 May 2017 13:13:38 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Thu, 18 May 2017 12:50:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> I tried again following the steps… but then in the end it again showed me errors regarding installing dependencies…</p>
<p dir="auto">I believe two in particular…</p>
<pre><code>npm WARN prefer global coffee-script@1.10.0 should be installed with -g
npm WARN prefer global jsonlite@1.6.2 should be installed with -g
&gt; electron-chromedriver@1.7.1 install/jome/pi/MagicMirror/node_modules/electron-chromedriver
&gt; node ./download-chromedriver.js
]]></description><link>https://forum.magicmirror.builders/post/21768</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21768</guid><dc:creator><![CDATA[jubeenshah]]></dc:creator><pubDate>Thu, 18 May 2017 12:50:53 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Thu, 18 May 2017 07:23:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Thanks a lot! I’ll try that and let you know about how it turns about!</p>
]]></description><link>https://forum.magicmirror.builders/post/21755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21755</guid><dc:creator><![CDATA[jubeenshah]]></dc:creator><pubDate>Thu, 18 May 2017 07:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing the magicmirror on Wed, 17 May 2017 09:34:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jubeenshah" aria-label="Profile: jubeenshah">@<bdi>jubeenshah</bdi></a> said in <a href="/post/21692">Error installing the magicmirror</a>:</p>
<p dir="auto">Failed at the electron</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jakllo" aria-label="Profile: Jakllo">@<bdi>Jakllo</bdi></a><br />
I initially had that problem too - you need to be logged in as PI - not root.<br />
I’d suggest starting all over: it really wont take that long. Follow the<br />
tutorial @strawberry-3-141 mentioned (<a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial</a>) to the letter. It was written by <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> &amp; made all of my problem go away. I have now done it 4 times, getting it done in less than an hour from unpacking to having it all run!</p>
<p dir="auto">My raspberry all of a sudden even connected via WiFi, and I am expecting my hair to grow back any day now.</p>
<p dir="auto">I’m telling you - pure magic, these guys.</p>
<p dir="auto">All the best</p>
]]></description><link>https://forum.magicmirror.builders/post/21696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21696</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 17 May 2017 09:34:52 GMT</pubDate></item></channel></rss>
