MMM-ISY
  • Module Developer
    Description:
    Inspired by the MMM-OpenHABFloorplan module, this is a module for the MagicMirror² to connect to an ISY device from Universal Devices (http://www.universal-devices.com) using a WebSocket. It will display a floor plan showing live updates of which Insteon or Z-Wave devices are turned on/off (including dimming levels), which alarm zones are tripped, and the status of the thermostats.
    The module works by treating each device/variable as a “layer” on top of the base Floor Plan image–similar to layers in Photoshop. For each device, you create an overlay image (with a transparent background) of only what you want the device to look like when it’s on. The module will then show/hide this layer by setting the opacity based on if the ISY says the device is on or off.
    Screenshots:
    Live view:
    Floorplan Base Layer:
    Download:
    Version 1.0.0
    • Initial Release
Looks like your connection to MagicMirror Forum was lost, please wait while we try to reconnect.
