<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems with Wi-Fi connectivity.]]></title><description><![CDATA[<p dir="auto">I’ve been able to get my MM up and running when all the parts and pieces are outside the wooden frame I built. When I assemble it all into the frame I lose my wi-fi connection. Its seems that either the housing is shielding the unit or there is radio interference from the monitor.</p>
<p dir="auto">I have a Raspberry Pi 3 with on-board wi-fi. I poked around the internet and found some info on modding the board to add a bigger antenna but I would prefer not to mod the board. Has anyone had experience with disabling the on-board wi-fi and adding a wi-fi dongle? Has anyone had similar trouble and solved it some other way? Any help would be appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/2703/problems-with-wi-fi-connectivity</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 12:48:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2703.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Jun 2017 13:35:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Wed, 07 Jun 2017 12:46:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nuckinfutz" aria-label="Profile: nuckinfutz">@<bdi>nuckinfutz</bdi></a> Excellent point, I’m not having power issues so I will probable just leave it how it is. Thanks for the input.</p>
]]></description><link>https://forum.magicmirror.builders/post/22445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22445</guid><dc:creator><![CDATA[n8ms]]></dc:creator><pubDate>Wed, 07 Jun 2017 12:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Wed, 07 Jun 2017 02:18:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n8ms" aria-label="Profile: n8ms">@<bdi>n8ms</bdi></a> Disables the onboard wireless. You might want to try bluetooth and a bluetooth keyboard. Why worry about the onboard? Just leave it.Doubt you are having power issues.</p>
]]></description><link>https://forum.magicmirror.builders/post/22426</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22426</guid><dc:creator><![CDATA[nuckinfutz]]></dc:creator><pubDate>Wed, 07 Jun 2017 02:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Wed, 07 Jun 2017 01:20:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nuckinfutz" aria-label="Profile: nuckinfutz">@<bdi>nuckinfutz</bdi></a> Will this disable both wlan1 and wlan0, wlan0 being the native wireless adapter? I currently have both active and the dongle is working great. I would trial and error it but I am trying to avoid disabling wireless and losing my SSH connection. Will have to open it all up and connect a keyboard to get it running again.</p>
]]></description><link>https://forum.magicmirror.builders/post/22419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22419</guid><dc:creator><![CDATA[n8ms]]></dc:creator><pubDate>Wed, 07 Jun 2017 01:20:23 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Tue, 06 Jun 2017 12:33:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n8ms" aria-label="Profile: n8ms">@<bdi>n8ms</bdi></a> add to config.txt<br />
dtoverlay=pi3-disable-wifi<br />
dtoverlay=pi3-disable-bt</p>
<p dir="auto">(This also disables Bluetooth)</p>
]]></description><link>https://forum.magicmirror.builders/post/22402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22402</guid><dc:creator><![CDATA[nuckinfutz]]></dc:creator><pubDate>Tue, 06 Jun 2017 12:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Tue, 06 Jun 2017 03:43:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Thanks for the reply. Can you point me to a good “how to” on disabling the on-board and enabling a wi-fi dongle.</p>
]]></description><link>https://forum.magicmirror.builders/post/22386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22386</guid><dc:creator><![CDATA[n8ms]]></dc:creator><pubDate>Tue, 06 Jun 2017 03:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Tue, 06 Jun 2017 02:38:39 GMT]]></title><description><![CDATA[<p dir="auto">I used a WiFi dongle on my first mirror. In certain areas of the house, connectivity was pretty poor. I had installed a USB port into the box in case I needed to plug in a keyboard/mouse and troubleshoot. Plugging the WiFi dongle into that external port solved my WiFi problems right nicely.<br />
So it sounds like you’re on the right track. And disabling the onboard WiFi is pretty easy.</p>
]]></description><link>https://forum.magicmirror.builders/post/22384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22384</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 06 Jun 2017 02:38:39 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with Wi-Fi connectivity. on Tue, 06 Jun 2017 00:58:22 GMT]]></title><description><![CDATA[<p dir="auto">Adding a dongle on yours may be a good solution. use a usb extension cable yso you can move the dongle around if you dont get connectivity.</p>
]]></description><link>https://forum.magicmirror.builders/post/22382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22382</guid><dc:creator><![CDATA[nuckinfutz]]></dc:creator><pubDate>Tue, 06 Jun 2017 00:58:22 GMT</pubDate></item></channel></rss>
