<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[electron performance]]></title><description><![CDATA[<p dir="auto">Is it normal 3 electron process? and this CPU usage?</p>
<p dir="auto"><img src="/assets/uploads/files/1496869605829-upload-87479adf-15e5-4fc2-aff4-94dedf86cf38.png" alt="0_1496869604575_upload-87479adf-15e5-4fc2-aff4-94dedf86cf38" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2717/electron-performance</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 23:28:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2717.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Jun 2017 21:07:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to electron performance on Sat, 26 Aug 2017 01:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wtidwell" aria-label="Profile: wtidwell">@<bdi>wtidwell</bdi></a> said in <a href="/post/27048">electron performance</a>:</p>
<p dir="auto">Can you think of anything dumb i didn’t do once it’s installed? Like change a config file or anything?</p>
<p dir="auto">No, it <em>SHOULD</em> work with the default installation, and then some. As you can see from this topic other people have had this problem and sorted it out. I just don’t understand your particular circumstance.</p>
<p dir="auto">I hate to keep throwing suggestions at you but perhaps you can try an SD card that does not have a <code>U</code> rating at all, like the one I posted in the other topic? And you formatted the card using the suggestions I posted as well? I’m trying to think of something, anything that might help you.</p>
]]></description><link>https://forum.magicmirror.builders/post/27050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27050</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 26 Aug 2017 01:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to electron performance on Sat, 26 Aug 2017 01:35:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/27048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27048</guid><dc:creator><![CDATA[wtidwell]]></dc:creator><pubDate>Sat, 26 Aug 2017 01:35:04 GMT</pubDate></item><item><title><![CDATA[Reply to electron performance on Sat, 10 Jun 2017 23:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ezarlive" aria-label="Profile: ezarlive">@<bdi>ezarlive</bdi></a> said in <a href="/post/22577">electron performance</a>:</p>
<p dir="auto">After these actions, it works fine!</p>
<p dir="auto">Glad you got it sorted out. Enjoy your mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/22587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22587</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 10 Jun 2017 23:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to electron performance on Sat, 10 Jun 2017 17:51:51 GMT]]></title><description><![CDATA[<p dir="auto">I remove MMM-Stock module. Now it’s working fine.<br />
I revert to electron 1.4.x, because seems that is updated to 1.7 (beta).</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.magicmirror.builders/post/22577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22577</guid><dc:creator><![CDATA[ezarlive]]></dc:creator><pubDate>Sat, 10 Jun 2017 17:51:51 GMT</pubDate></item><item><title><![CDATA[Reply to electron performance on Fri, 09 Jun 2017 12:18:32 GMT]]></title><description><![CDATA[<p dir="auto">Restarted using only default modules…</p>
<p dir="auto"><img src="/assets/uploads/files/1497010708130-upload-3f0e042b-7139-421c-aa12-8962001718d6.png" alt="0_1497010707541_upload-3f0e042b-7139-421c-aa12-8962001718d6" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/22521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22521</guid><dc:creator><![CDATA[ezarlive]]></dc:creator><pubDate>Fri, 09 Jun 2017 12:18:32 GMT</pubDate></item><item><title><![CDATA[Reply to electron performance on Wed, 07 Jun 2017 22:50:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ezarlive" aria-label="Profile: ezarlive">@<bdi>ezarlive</bdi></a> said in <a href="/post/22469">electron performance</a>:</p>
<p dir="auto">I have 2 electron processes reported by the <code>top</code> command in the terminal and 4 reported in the Task Manager. However, you’ll notice that my CPU usage for electron is virtually nil in both cases.</p>
<p dir="auto">I also note that your time up is 3 min, 3 users and load averages are extremely high. You could start with just the default modules and see what the results are. Do you have very many modules installed and enabled? Or perhaps a few modules that demand more resources than others?</p>
<p dir="auto">Here are my stats for your comparison. You will notice the differences immediately.<br />
<img src="/assets/uploads/files/1496875826811-e2.jpeg" alt="0_1496875847433_e2.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1496875839528-electron.jpeg" alt="0_1496875860699_electron.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/22471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22471</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 07 Jun 2017 22:50:44 GMT</pubDate></item></channel></rss>
