<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Did you remember to update?]]></title><description><![CDATA[<p dir="auto">So ten (11?) days ago I wrote that long tutorial on setting up an rpi3 from pulling it out of the box to having MM² running. At that time I updated <em><strong>everything</strong></em> on the rpi, including the firmware. Booted up that same rpi today only to find another firmware available. This is just a friendly reminder to remember to update your rpi every so often, both the packages through <code>'sudo apt-get update ; sudo apt-get upgrade'</code> as well as the firmware with <code>'sudo rpi-update'</code>.</p>
<p dir="auto">The latest firmware version is:</p>
<pre><code>$ /opt/vc/bin/vcgencmd version
Jun 20 2016 18:13:27
Copyright (c) 2012 Broadcom
version 460b39c674ef2ac89360e15331f97a2cb1388a44 (clean) (release)
]]></description><link>https://forum.magicmirror.builders/topic/274/did-you-remember-to-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 14:14:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/274.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Jun 2016 06:35:06 GMT</pubDate><ttl>60</ttl></channel></rss>
