<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Regions]]></title><description><![CDATA[<p dir="auto">In case one wants to know where the various regions are. Missing are the fullscreen_below and fullscreen_above as those cover the whole screen, one under everything else and the other above.</p>
<p dir="auto"><code>top_bar</code> and <code>bottom_bar</code> are light gray<br />
<code>top_left</code> and <code>bottom_left</code> are red<br />
<code>top_center</code> and <code>bottom_center</code> are blue<br />
<code>top_right</code> and <code>bottom_right</code> are green<br />
<code>upper_third</code> is yellow<br />
<code>middle_center</code> is cyan<br />
<code>lower_third</code> is magenta</p>
<p dir="auto">All these regions will resize as needed.</p>
<p dir="auto"><img src="https://forum.magicmirror.builders/uploads/files/1467093643063-regions.png" alt="0_1467093434766_regions.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/286/regions</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 02:11:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/286.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jun 2016 06:09:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Regions on Sun, 08 Oct 2023 04:11:56 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1696738284660-0250ebe0-9390-4080-8e70-feb4e71b7d80-image.png" alt="0250ebe0-9390-4080-8e70-feb4e71b7d80-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/111452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111452</guid><dc:creator><![CDATA[roth_nj]]></dc:creator><pubDate>Sun, 08 Oct 2023 04:11:56 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 08 Oct 2023 04:09:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> said in <a href="/post/111447">Regions</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roth_nj" aria-label="Profile: roth_nj">@<bdi>roth_nj</bdi></a> yes. That’s begging for CalendarExt3 type functionality and a bit of heavy CSS.</p>
<p dir="auto">that’s what I’m working on right now. have calendarext3 in and working. I have 2 of my 6 calendars set up (saving the rest for when I have the functionality I want). trying to get a photo background working atm. wanted to pull from my iPhotos but I seem to be hitting a snag. have it working out of the bing pics</p>
<p dir="auto"><img src="/assets/uploads/files/1696738033417-62285ef3-e641-4e58-a49f-5644177fd4c9-image.png" alt="62285ef3-e641-4e58-a49f-5644177fd4c9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/111451</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111451</guid><dc:creator><![CDATA[roth_nj]]></dc:creator><pubDate>Sun, 08 Oct 2023 04:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 08 Oct 2023 03:38:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roth_nj" aria-label="Profile: roth_nj">@<bdi>roth_nj</bdi></a> yes. That’s begging for CalendarExt3 type functionality and a bit of heavy CSS.</p>
]]></description><link>https://forum.magicmirror.builders/post/111447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111447</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 08 Oct 2023 03:38:01 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 08 Oct 2023 03:36:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roth_nj" aria-label="Profile: roth_nj">@<bdi>roth_nj</bdi></a> maybe if you use something like MMM-CalenderEXT3</p>
]]></description><link>https://forum.magicmirror.builders/post/111446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111446</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Oct 2023 03:36:51 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 08 Oct 2023 02:41:46 GMT]]></title><description><![CDATA[<p dir="auto">is there a way to have something like the calendar on 2/3rd of the screen to look like the dakboard?</p>
<p dir="auto"><img src="/assets/uploads/files/1696732887804-5de0d134-37ab-4ee9-8ed4-fb12707ddd55-image.png" alt="5de0d134-37ab-4ee9-8ed4-fb12707ddd55-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/111445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111445</guid><dc:creator><![CDATA[roth_nj]]></dc:creator><pubDate>Sun, 08 Oct 2023 02:41:46 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Fri, 06 Oct 2023 18:00:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/111419">Regions</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roth_nj" aria-label="Profile: roth_nj">@<bdi>roth_nj</bdi></a>  The regions will be the same but obviously the sizes will be different</p>
<p dir="auto">You can do the same color view by adding a background color to each one of the regions in custom CSS and then you can see where they are</p>
<p dir="auto">thank you</p>
<p dir="auto">thats actually a good idea. it will give me something to practice for setting up a custom CSS for the first time</p>
]]></description><link>https://forum.magicmirror.builders/post/111422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111422</guid><dc:creator><![CDATA[roth_nj]]></dc:creator><pubDate>Fri, 06 Oct 2023 18:00:02 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Fri, 06 Oct 2023 17:48:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roth_nj" aria-label="Profile: roth_nj">@<bdi>roth_nj</bdi></a>  The regions will be the same but obviously the sizes will be different</p>
]]></description><link>https://forum.magicmirror.builders/post/111419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111419</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Oct 2023 17:48:44 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Fri, 06 Oct 2023 17:15:33 GMT]]></title><description><![CDATA[<p dir="auto">im just diving into this project (mech eng with very limited programming experience)</p>
<p dir="auto">i have the MM installed and running on my mac using terminal/electron. ive been in the config editing it and taking out stuff i dont want and added CalendarExt3 and have that working. im doing it on my mac for now waiting on my PI to come in the mail. from what ive read it will also speed up the editing phase vs pop it into the pi over and over.</p>
<p dir="auto">im about to start digging into size/area/color/font/etc and have a combo of questions:</p>
<p dir="auto">the picture posted in the start of this thread is very helpful for the zones. i want to run mine in landscape view. will those zones be the same in landscape vs portrait?  i can’t tell if it is because i haven’t configured it properly for my monitors or if it needs to be adjusted (portrait to landscape). if so, is there another version of the same picture but in the other orientation?</p>
<p dir="auto">sorry if these are self explanatory questions once i dive into it more just wanted to ask to help the process</p>
]]></description><link>https://forum.magicmirror.builders/post/111418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111418</guid><dc:creator><![CDATA[roth_nj]]></dc:creator><pubDate>Fri, 06 Oct 2023 17:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Thu, 09 Dec 2021 16:00:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pastormingle" aria-label="Profile: pastormingle">@<bdi>pastormingle</bdi></a> no, not a valid position</p>
<p dir="auto">here is the list from the MM doc</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/modules/configuration.html#module-configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/configuration.html#module-configuration</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Dec 2021 16:00:28 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Thu, 09 Dec 2021 15:59:25 GMT]]></title><description><![CDATA[<p dir="auto">can you position left middle?</p>
]]></description><link>https://forum.magicmirror.builders/post/97314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97314</guid><dc:creator><![CDATA[pastormingle]]></dc:creator><pubDate>Thu, 09 Dec 2021 15:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Tue, 08 Jun 2021 16:27:22 GMT]]></title><description><![CDATA[<p dir="auto">hi all, how could i center this kodi-websocket module between these two?</p>
<p dir="auto"><img src="/assets/uploads/files/1623169630414-0c7f3eab-0372-47e1-bc6a-e11ae8bd7409-image.png" alt="0c7f3eab-0372-47e1-bc6a-e11ae8bd7409-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">using bottom left for map, bottom center for kodi websocket and bottom right for wind</p>
<p dir="auto">i tried custom.css module placement but did not work</p>
<p dir="auto">.module.MMM-Kodi-WebSocket{<br />
left : 600 px,<br />
}</p>
]]></description><link>https://forum.magicmirror.builders/post/92017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92017</guid><dc:creator><![CDATA[megagprime]]></dc:creator><pubDate>Tue, 08 Jun 2021 16:27:22 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Tue, 01 Dec 2020 12:24:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/toots" aria-label="Profile: toots">@<bdi>toots</bdi></a> u could edit the index.html to add your left/right locations, and add entries to custom.css for them</p>
]]></description><link>https://forum.magicmirror.builders/post/85337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85337</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Dec 2020 12:24:54 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Tue, 01 Dec 2020 03:20:15 GMT]]></title><description><![CDATA[<p dir="auto">Sorry if this has been asked. Is there a way to do left_side and right_side? I’m displaying my mirror on a chromecast so it’s locked into landscape mode at 720p and there isn’t a whole lot of room for each of the regions. I’d rather replace top_left and bottom_left with left_side, and just use the entire edge.</p>
]]></description><link>https://forum.magicmirror.builders/post/85328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85328</guid><dc:creator><![CDATA[toots]]></dc:creator><pubDate>Tue, 01 Dec 2020 03:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Thu, 05 Dec 2019 02:39:21 GMT]]></title><description><![CDATA[<p dir="auto">Yes I would HIGHLY suggest you do not change the main.css file… that could send other modules or positions in to chaos.  Use the custom css as Mykle1 suggested :)</p>
]]></description><link>https://forum.magicmirror.builders/post/65491</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65491</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:39:21 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 01 Dec 2019 16:06:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drwatson" aria-label="Profile: drwatson">@<bdi>drwatson</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a></p>
<p dir="auto">Can you then suggest the equivalent change to make the proper way without modifying the main.css?</p>
<p dir="auto">Well, any changes that you consider making in the main.css can be made in the custom.css file without changing the main.css file. The custom.css file will override what is in the main.css file. This way you’re not altering any core files and your modifications will be accepted. When it’s time to upgrade to a newer version of MM the upgrade won’t abort because of changes you’ve made to the core files and your custom.css changes will survive the upgrade. :-)</p>
<p dir="auto">I’m still learning things every day and I enjoy the process. That’s the whole point for me.</p>
<p dir="auto">Peace!</p>
]]></description><link>https://forum.magicmirror.builders/post/65310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65310</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 01 Dec 2019 16:06:01 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 01 Dec 2019 14:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Yes I added code to custom.css not main.css. Thanks for all</p>
]]></description><link>https://forum.magicmirror.builders/post/65306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65306</guid><dc:creator><![CDATA[Fifin404]]></dc:creator><pubDate>Sun, 01 Dec 2019 14:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 01 Dec 2019 13:54:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> ouh damned…your concerns are absolutely justified. Haven’t hought of that. Thanks for pointing me to that.:thumbs_up_light_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/65300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65300</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sun, 01 Dec 2019 13:54:28 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 01 Dec 2019 03:48:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drwatson" aria-label="Profile: drwatson">@<bdi>drwatson</bdi></a>  Copy the exact same code that <a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> noted above and put it in the custom.css file.</p>
<p dir="auto">Below is what I put in my custom.css file.</p>
<pre><code>body {
  margin: 5px;
  position: absolute;
  height: calc(100% - 10px);
  width: calc(100% - 10px);
]]></description><link>https://forum.magicmirror.builders/post/65291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65291</guid><dc:creator><![CDATA[cskenney]]></dc:creator><pubDate>Sun, 01 Dec 2019 03:48:16 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sun, 01 Dec 2019 03:35:34 GMT]]></title><description><![CDATA[<p dir="auto">Good point, <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/65290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65290</guid><dc:creator><![CDATA[drwatson]]></dc:creator><pubDate>Sun, 01 Dec 2019 03:35:34 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sat, 30 Nov 2019 21:09:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> said in <a href="/post/65270">Regions</a>:</p>
<p dir="auto">Im main.css you can change</p>
<p dir="auto">Encouraging people to modify their main.css is really not a good idea, especially for those that are new to MM and/or linux.</p>
<p dir="auto">Please direct your help towards the custom.css file which is intended for just such modifications.</p>
<p dir="auto">Peace</p>
<p dir="auto">-A concerned citizen-</p>
]]></description><link>https://forum.magicmirror.builders/post/65279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65279</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 30 Nov 2019 21:09:47 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sat, 30 Nov 2019 16:59:56 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, that is what I looking for.</p>
]]></description><link>https://forum.magicmirror.builders/post/65272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65272</guid><dc:creator><![CDATA[Fifin404]]></dc:creator><pubDate>Sat, 30 Nov 2019 16:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sat, 30 Nov 2019 16:42:57 GMT]]></title><description><![CDATA[<p dir="auto">Im main.css you can change the margin, heightand width under ‚body’ as you need. Here are my values I adjusted. The default values are commented.</p>
<pre><code>body {
  /* margin: 60px; */
  margin: 5px;
  position: absolute;
  /*height: calc(100% - 120px);
  width: calc(100% - 120px);*/
]]></description><link>https://forum.magicmirror.builders/post/65270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65270</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sat, 30 Nov 2019 16:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Regions on Sat, 30 Nov 2019 15:52:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi all, is there any way to change outer border around modules? Make it smaller?<br />
<img src="/assets/uploads/files/1575129077345-img_20191130_153745.png" alt="0_1575129077002_IMG_20191130_153745.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65269</guid><dc:creator><![CDATA[Fifin404]]></dc:creator><pubDate>Sat, 30 Nov 2019 15:52:38 GMT</pubDate></item></channel></rss>
