<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fatal: could not create work tree dir 'MagicMirror'.: Read-only file system]]></title><description><![CDATA[<p dir="auto">I get this error while running the command</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
<p dir="auto">that I got from the GitHub repo. This happens right after I get the notification that says<br />
“Note.js installation Done!<br />
Cloning MagicMirror…”</p>
<p dir="auto">Any advice on how to fix this? I’m not familiar much with linux so any help is appreciated :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/2953/fatal-could-not-create-work-tree-dir-magicmirror-read-only-file-system</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 08:18:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2953.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jun 2017 03:24:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to fatal: could not create work tree dir 'MagicMirror'.: Read-only file system on Wed, 14 Jun 2017 04:24:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iron_reptar" aria-label="Profile: Iron_Reptar">@<bdi>Iron_Reptar</bdi></a> Just for fun I decided to try to rerun the command again, and it first said that “dpkg was interrupted.” so I ran<br />
<code>sudo dpkg --configure -a</code><br />
Like the screen told me to, then re-re-ran it, to arrive at the error "E: Sub-process /usr/bin/dpkg returned an error code (1).<br />
Help, all I want is a working mirror :(</p>
]]></description><link>https://forum.magicmirror.builders/post/22920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22920</guid><dc:creator><![CDATA[Iron_Reptar]]></dc:creator><pubDate>Wed, 14 Jun 2017 04:24:05 GMT</pubDate></item></channel></rss>
