<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Withings]]></title><description><![CDATA[<p dir="auto">Moin from Hamburg,</p>
<p dir="auto">i need help with the Withings Scale.<br />
<a href="http://www.amazon.de/Withings-WS-50-Smart-Analyzer-schwarz/dp/B00BKRQ4E8/ref=sr_1_1?s=drugstore&amp;ie=UTF8&amp;qid=1462363132&amp;sr=1-1&amp;keywords=withings+waage" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.amazon.de/Withings-WS-50-Smart-Analyzer-schwarz/dp/B00BKRQ4E8/ref=sr_1_1?s=drugstore&amp;ie=UTF8&amp;qid=1462363132&amp;sr=1-1&amp;keywords=withings+waage</a></p>
<p dir="auto">There is an API (<a href="http://oauth.withings.com/api/doc" target="_blank" rel="noopener noreferrer nofollow ugc">http://oauth.withings.com/api/doc</a>) and i try to write my own CustomCSS to get the actual weight and some stats at the Mirror.<br />
Unfortunately, I 'm apparently too stupid for this. Maybe someone with more Skills have the same problem?</p>
<p dir="auto">Thank you in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/30/withings</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 18:24:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/30.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 May 2016 12:03:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Withings on Tue, 18 Dec 2018 18:40:47 GMT]]></title><description><![CDATA[<p dir="auto">Anybody get this working with the new OAuth 2.0?</p>
]]></description><link>https://forum.magicmirror.builders/post/48289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48289</guid><dc:creator><![CDATA[iwaldrum]]></dc:creator><pubDate>Tue, 18 Dec 2018 18:40:47 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Thu, 19 Jul 2018 07:30:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I also try to make it work, but I didn’t succed. Probably I did some wrong behaviour during the oAuth process.</p>
<p dir="auto">At the end I can see on my MagicMirror logs an error 283, that correspond according to Nokia API website to : “283 : Token is invalid or doesn’t exist”.</p>
<p dir="auto">I considered it was OAuth version 1.0 because it look like it.</p>
<p dir="auto">Also it is written on Nokia website :</p>
<p dir="auto">“The Health Mate API is now fully functional with OAuth 2.0 authentication protocol.<br />
Therefore, the OAuth 1.0 process will no longer be supported beginning:<br />
November 30, 2018”</p>
<p dir="auto">Also I do not really want to fight to make it work if the service will be cut by Nokia/Withings on a few months.</p>
<p dir="auto">Does someone have the knowledge to update this module with OAuth 2.0 ?</p>
]]></description><link>https://forum.magicmirror.builders/post/42370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42370</guid><dc:creator><![CDATA[AgP42]]></dc:creator><pubDate>Thu, 19 Jul 2018 07:30:34 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Tue, 27 Mar 2018 16:30:09 GMT]]></title><description><![CDATA[<p dir="auto">I looked at the module and it just need to be updated however, I can find a way to be able to get the JSON data to be displayed. All I get is a {“status”:342,“error”:“The signature (using Oauth) is invalid”}</p>
<p dir="auto">I tried almost everything already.</p>
<p dir="auto">If anyone can give it a try and make that work, I can update the module and even create new features.</p>
]]></description><link>https://forum.magicmirror.builders/post/37482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37482</guid><dc:creator><![CDATA[fabbr]]></dc:creator><pubDate>Tue, 27 Mar 2018 16:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 06 Mar 2017 21:23:27 GMT]]></title><description><![CDATA[<p dir="auto">I can not get it to work. I only have  the scale.</p>
]]></description><link>https://forum.magicmirror.builders/post/16656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16656</guid><dc:creator><![CDATA[Jayh391]]></dc:creator><pubDate>Mon, 06 Mar 2017 21:23:27 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 03 Mar 2017 20:16:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aluini" aria-label="Profile: aluini">@<bdi>aluini</bdi></a> said in <a href="/post/9868">Withings</a>:</p>
<p dir="auto">I corrected some things on the module :</p>
<ul>
<li>correction of the <a class="plugin-mentions-user plugin-mentions-a" href="/user/ih800a" aria-label="Profile: ih800a">@<bdi>ih800a</bdi></a> bug (I had the same)</li>
<li>add external CSS</li>
<li>add the loader</li>
<li>add translation</li>
</ul>
<p dir="auto">I’ll review the design of the module</p>
<p dir="auto">[card:aluini/MM_Withings]</p>
<p dir="auto">Nice. I want to test it.<br />
My data from my withings steel also showable?</p>
]]></description><link>https://forum.magicmirror.builders/post/16390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16390</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Fri, 03 Mar 2017 20:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 10 Feb 2017 07:17:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/aluini" aria-label="Profile: aluini">@<bdi>aluini</bdi></a>, is your module still working correctly? I’m only getting the weight. :)<br />
I have an Body Cardio Scale, do I have to define this somewhere?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/14145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14145</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Fri, 10 Feb 2017 07:17:39 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 26 Dec 2016 20:42:49 GMT]]></title><description><![CDATA[<p dir="auto">I corrected some things on the module :</p>
<ul>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/9868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9868</guid><dc:creator><![CDATA[aluini]]></dc:creator><pubDate>Mon, 26 Dec 2016 20:42:49 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 09 Dec 2016 15:39:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt25" aria-label="Profile: matt25">@<bdi>matt25</bdi></a></p>
<p dir="auto">I have a few Withings devices (pulse, scale, BP monitor, etc), so your theory makes good sense.  Kudos, by the way on this proof of concept - I like it and this will be one of my first Pi / Magic Mirror / module customizations, so I appreciate any insight you have.</p>
<p dir="auto">The errors appear at MM_Withings.js:208, which I believe is the line that writes the error to the log.</p>
]]></description><link>https://forum.magicmirror.builders/post/9096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9096</guid><dc:creator><![CDATA[ih800a]]></dc:creator><pubDate>Fri, 09 Dec 2016 15:39:05 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 09 Dec 2016 09:48:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ih800a" aria-label="Profile: ih800a">@<bdi>ih800a</bdi></a><br />
ok thanks.<br />
Do you only have a Withings scale, correct? or do you also have a watch or others?</p>
<p dir="auto">My guess is that as my module is just currently a proof of concept, I try to display all the related information (weight, sleep, activity ) but if you do not have the withings device related it crashes.</p>
<p dir="auto">Also, could you tell me when:<br />
“error TypeError: Cannot read property ‘date’ of undefined”<br />
which line in the MM_Withings.js script is related. It should be written in the debug console. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/9080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9080</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Fri, 09 Dec 2016 09:48:38 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Thu, 08 Dec 2016 20:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt25" aria-label="Profile: matt25">@<bdi>matt25</bdi></a></p>
<p dir="auto">Per the console, I do receive weight (poids=90.67;) and date (date=1481195497) information, but then see the following:</p>
<p dir="auto">status=0<br />
error TypeError: Cannot read property ‘date’ of undefined<br />
error TypeError: Cannot read property ‘body’ of undefined<br />
data=undefined<br />
data is null</p>
]]></description><link>https://forum.magicmirror.builders/post/9065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9065</guid><dc:creator><![CDATA[ih800a]]></dc:creator><pubDate>Thu, 08 Dec 2016 20:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Thu, 08 Dec 2016 20:08:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ih800a" aria-label="Profile: ih800a">@<bdi>ih800a</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a></p>
<p dir="auto">Hi, sorry, was out last few weeks. Just tried the module on another raspberry card with from scratch installation and I cannot reproduce the issue you describe. When you launch the mirror, do you have any issue in the logs? (use “npm start dev” command). Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/9064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9064</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Thu, 08 Dec 2016 20:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Thu, 08 Dec 2016 14:01:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a>  I’m getting the same results as you.  I suspect the MM_Withings.js script needs to be tweaked a bit.  I manually tested all the variables used in the config.js file, confirming that the API is setup correctly and returning data.  My guess is that the output string of the  MM_Withings.js script is different than what I’m testing.</p>
]]></description><link>https://forum.magicmirror.builders/post/9051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9051</guid><dc:creator><![CDATA[ih800a]]></dc:creator><pubDate>Thu, 08 Dec 2016 14:01:35 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Thu, 01 Dec 2016 19:50:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt25" aria-label="Profile: matt25">@<bdi>matt25</bdi></a> Hi,</p>
<p dir="auto">Thanks, with your pointers, I got through to step 4 and the resultant URL does retrieve data so I know the credentials are working- but putting that into the config.js (all info it looks like you ask for is contained in that request URL), I still get zeros.</p>
<p dir="auto">I suspect I’m close, but not sure what could be wrong.</p>
]]></description><link>https://forum.magicmirror.builders/post/8773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8773</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Thu, 01 Dec 2016 19:50:56 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 21 Nov 2016 13:59:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a></p>
<p dir="auto">Seems that you are not using correct parameters in the Withings authentification process:</p>
<ul>
<li>
<p dir="auto">Step1 : Use API keys and API secret generated during your Withings apps creation.<br />
You get a result URL with oauth_token and oauth_token_secret.</p>
</li>
<li>
<p dir="auto">Step2: Use oath_token and oauth_token_secret generated at step1. This will generate a result URL. Click on it and look at the adress bar, you will get in the URL your userid (6 digits),  ‘&amp;userid=xxxxxxx’</p>
</li>
<li>
<p dir="auto">Step3: use the userid got from step2. you will get an URL result with oauth_signature and oauth_token.</p>
</li>
</ul>
<p dir="auto">Hope it helps.</p>
<p dir="auto">Selecting the data you want to display is the next step, that is why currently this is just a basic module and I did not yet published a official release.</p>
]]></description><link>https://forum.magicmirror.builders/post/8318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8318</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Mon, 21 Nov 2016 13:59:20 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 18 Nov 2016 21:43:39 GMT]]></title><description><![CDATA[<p dir="auto">Ah, OK,</p>
<p dir="auto">Now a different error.</p>
<p dir="auto">When I get to Step 3, do I stop there or continue on (I’m getting a Bad Request on step 4)</p>
<p dir="auto">Also it says in step 2 I should get a URL once I access the user - but I get Access Granted - and another token - no URL.</p>
<p dir="auto">To be clear about the parameters for the config.js:</p>
<p dir="auto">oath_consumer key is the key given in the partner app page. under My Keys and called APIKey</p>
<p dir="auto">oauth_signature is listed right at the bottom in the black box in step 3.</p>
<p dir="auto">clientID  - no idea what that is</p>
<p dir="auto">oauth_token is taken from the black box in step 3 and is highlighted. There are two copies of it.</p>
<p dir="auto">Oh, One last request about functionality. It would be great if you could specify in Config.js which readings are actually shown. I only use the scales and so the other stuff is superfluous. I suspect the majority of people would not necessarily have the full set (steps and sleep).</p>
]]></description><link>https://forum.magicmirror.builders/post/8209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8209</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Fri, 18 Nov 2016 21:43:39 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 18 Nov 2016 17:42:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a>  Ok sorry. When creating a withings app it is necessary to write something in the application website (127.0.0.1). In the Withings authentification process, do not fill the the ‘callback url’ field. Hope it helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/8193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8193</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Fri, 18 Nov 2016 17:42:05 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 18 Nov 2016 12:02:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt25" aria-label="Profile: matt25">@<bdi>matt25</bdi></a><br />
The problem I had was that I was ssh’ing into my mirror - so I tried running the Withings authorisation process on the mirror using Chrome, but I’m now getting a message that 127.0.0.1 can’t be reached.</p>
]]></description><link>https://forum.magicmirror.builders/post/8174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8174</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Fri, 18 Nov 2016 12:02:59 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 14 Nov 2016 17:02:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a> I personally simply wrote 127.0.0.1 and no problem. Let me know if it is ok so that I can complete the user guide.</p>
]]></description><link>https://forum.magicmirror.builders/post/7936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7936</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Mon, 14 Nov 2016 17:02:21 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 14 Nov 2016 14:43:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt25" aria-label="Profile: matt25">@<bdi>matt25</bdi></a> What do you put in for the application website when creating the application on the withings site? Seems to be needed later when granting access - and I get a 404 error if I just put some random site mane in there.</p>
]]></description><link>https://forum.magicmirror.builders/post/7930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7930</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Mon, 14 Nov 2016 14:43:13 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Sun, 13 Nov 2016 16:37:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Just upload first version of my module. This is more a proof of concept than a complete functional module, but it works fairly well on my mirror.</p>
<p dir="auto"><a href="https://github.com/john7002/MM_Withings/" target="_blank" rel="noopener noreferrer nofollow ugc">MM_Withings</a></p>
<p dir="auto">Will update and improve it (especially design, if someone could provide me nice icons) and create new post in module section forum.<br />
Module is based on Netatmo module from Christopher Fenner.</p>
]]></description><link>https://forum.magicmirror.builders/post/7891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7891</guid><dc:creator><![CDATA[matt25]]></dc:creator><pubDate>Sun, 13 Nov 2016 16:37:09 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Tue, 25 Oct 2016 15:23:21 GMT]]></title><description><![CDATA[<p dir="auto">So the Python module I was trying to re-use didn’t work. I suspect Withings have changed their API or something else has changed. Following the steps on their website though, did work and I was able to send a command to retrieve my data.</p>
<p dir="auto">Now it’s a case of trying to code it up into a module!</p>
]]></description><link>https://forum.magicmirror.builders/post/6860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6860</guid><dc:creator><![CDATA[darrene]]></dc:creator><pubDate>Tue, 25 Oct 2016 15:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Mon, 24 Oct 2016 09:13:55 GMT]]></title><description><![CDATA[<p dir="auto">I got the withings scale, interested about the module you’re building :)</p>
]]></description><link>https://forum.magicmirror.builders/post/6775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6775</guid><dc:creator><![CDATA[plumcraft]]></dc:creator><pubDate>Mon, 24 Oct 2016 09:13:55 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Sun, 23 Oct 2016 22:43:28 GMT]]></title><description><![CDATA[<p dir="auto">I’ve been having a very quick play with <a href="https://github.com/maximebf/python-withings" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> python script on my Pi, which demonstrates the API which could form the basis of a simple weight-data retrival module.</p>
<p dir="auto">I’m struggling with a few issues at the moment though - I’ve git clone’d and npm install’d, created a <a href="http://test.py" target="_blank" rel="noopener noreferrer nofollow ugc">test.py</a> file as indicated by the readme and in it I’ve put in it my Withings API key and secret values.</p>
<p dir="auto">I had to sudo pip install requests_oauthlib as that was a requirement which wasn’t installed.</p>
<p dir="auto">I’m SO nearly there I think! when my <a href="http://test.py" target="_blank" rel="noopener noreferrer nofollow ugc">test.py</a> file runs, it generates a Withings URL to authorise the app, I authorise on the website and am given an oauth response verification code, but when I paste it back into the script response, I get an error which i think is at the point the script tries to parse them through auth.get_credentials (after this point, the script gets my last measured weight):</p>
<pre><code> File "test.py", line 8, in &lt;module&gt;
 creds = auth.get_credentials(oauth_verifier)
 File "/home/pi/MagicMirror/modules/python-withings/withings/__init__.py", line 107, in get_credentials
tokens = oauth.fetch_access_token('%s/access_token' % self.URL)
File "/usr/local/lib/python2.7/dist-packages/requests_oauthlib/oauth1_session.py", line 304, in fetch_access_token
token = self._fetch_token(url, **request_kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests_oauthlib/oauth1_session.py", line 361, in _fetch_token
raise ValueError(error)
ValueError: Unable to decode token from token response. This is commonly caused by an unsuccessful request where a non urlencoded error message is returned. The decoding error was No JSON object could be decoded.
<p dir="auto">Oh well. It’s progress I suppose.</p>
]]></description><link>https://forum.magicmirror.builders/post/6760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6760</guid><dc:creator><![CDATA[darrene]]></dc:creator><pubDate>Sun, 23 Oct 2016 22:43:28 GMT</pubDate></item><item><title><![CDATA[Reply to Withings on Fri, 21 Oct 2016 08:09:12 GMT]]></title><description><![CDATA[<p dir="auto">I too have a Withings scale which I’d be interested in integrating the data from with MM.</p>
<p dir="auto">It’s next on my list to take a look at, but I suspect progress is likely to be slow as my skills are very basic :)</p>
]]></description><link>https://forum.magicmirror.builders/post/6622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6622</guid><dc:creator><![CDATA[darrene]]></dc:creator><pubDate>Fri, 21 Oct 2016 08:09:12 GMT</pubDate></item></channel></rss>
