<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Modules]]></title><description><![CDATA[<p dir="auto">The following modules come with a default installation of MagicMirror²:</p>
<pre><code class="language-javascript">Alert            - Displays alerts on the mirror when configured in another module.
Clock            - Display either a digital, analog, or both types of clocks
Calendar         - Displays a calendar of upcoming events, able to use Google and Facebook calendars.
Current Weather  - Displays the current weather for the configured location
Weather Forecast - Displays the weather forecast for the configured location
News Feed        - Displays a running ticker of a news feed, able to use a variety of different feeds
Compliments      - "Hi Sexy!"
Hello World      - Sample module, not enabled by default
<p dir="auto">Third party modules change almost daily. It’s the author’s own responsibility to post their module in the <a href="https://forum.magicmirror.builders/category/7/showcase">Showcase category</a>.</p>
]]></description><link>https://forum.magicmirror.builders/topic/343/default-modules</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:14:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/343.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jul 2016 18:48:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Modules on Wed, 27 Jul 2022 18:54:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oboudreaux" aria-label="Profile: Oboudreaux">@<bdi>Oboudreaux</bdi></a> submit a PR to the GitHub repo</p>
]]></description><link>https://forum.magicmirror.builders/post/103103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103103</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 27 Jul 2022 18:54:20 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Wed, 27 Jul 2022 18:42:23 GMT]]></title><description><![CDATA[<p dir="auto">A little improvement on compliments:  a day of the week category.</p>
<pre><code>const day = moment().format("dddd");
if (day in this.config.compliments) {
              compliments.push.apply(compliments, this.config.compliments[day])
<p dir="auto">allows entries like:</p>
<pre><code>"Monday" : [
    "Looks like somebody has a case of the Mondays"
"Tuesday" : [
    "Take out the trash."
<p dir="auto">Sorry, I didn’t see a better place to drop this</p>
]]></description><link>https://forum.magicmirror.builders/post/103102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/103102</guid><dc:creator><![CDATA[Oboudreaux]]></dc:creator><pubDate>Wed, 27 Jul 2022 18:42:23 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Tue, 19 Jul 2022 18:13:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> looks like latest calendar build has an issue with “broadcastPastEvents”</p>
<p dir="auto">If I set it to true, it will not display any events.  Calendar only works if set to false.</p>
]]></description><link>https://forum.magicmirror.builders/post/102940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/102940</guid><dc:creator><![CDATA[david_jonesy]]></dc:creator><pubDate>Tue, 19 Jul 2022 18:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Mon, 14 Oct 2019 21:57:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bjjsoul" aria-label="Profile: bjjsoul">@<bdi>bjjsoul</bdi></a> it does nothing but display the text “hello world”. It’s a super basic template for buildinh your own module.</p>
]]></description><link>https://forum.magicmirror.builders/post/62672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62672</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Mon, 14 Oct 2019 21:57:54 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Mon, 14 Oct 2019 20:58:21 GMT]]></title><description><![CDATA[<p dir="auto">who knows what  the module ; Hello World does</p>
<p dir="auto">is this a voice command or news</p>
<p dir="auto">i want to know what is the function of ; Hello World</p>
<p dir="auto">how i can activate it</p>
]]></description><link>https://forum.magicmirror.builders/post/62670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62670</guid><dc:creator><![CDATA[bjjsoul]]></dc:creator><pubDate>Mon, 14 Oct 2019 20:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Thu, 03 Oct 2019 20:59:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n21brown" aria-label="Profile: n21brown">@<bdi>n21brown</bdi></a> open an issue on the magicmirror github site so someone can track it.</p>
<p dir="auto">if you are a programmer, and want to contribute the fix as u care about it, then fork the repo, and make changes, then submit a pull request back.   we are all volunteers on this project</p>
<p dir="auto">and if u are not a programmer, maybe its a new challenge?</p>
]]></description><link>https://forum.magicmirror.builders/post/62104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62104</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 20:59:51 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Thu, 03 Oct 2019 19:55:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nem1" aria-label="Profile: nem1">@<bdi>nem1</bdi></a> I’ve got the same problem with the forecast too.  After approx 15:00 in a day I dont want to see that day’s for cast as it’s 60% of the day gone, therefore the next day should be shown.</p>
]]></description><link>https://forum.magicmirror.builders/post/62102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62102</guid><dc:creator><![CDATA[n21brown]]></dc:creator><pubDate>Thu, 03 Oct 2019 19:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Tue, 05 Mar 2019 17:10:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> just adding a link to github for the default modules as was difficult to find the second time I was looking for it.</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/master/modules/default</a></p>
]]></description><link>https://forum.magicmirror.builders/post/53707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53707</guid><dc:creator><![CDATA[thereallegend27]]></dc:creator><pubDate>Tue, 05 Mar 2019 17:10:41 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Sun, 14 Jan 2018 17:50:52 GMT]]></title><description><![CDATA[<p dir="auto">For the sake of completeness I’d say that even on the current day it’s still helpfull to see the forecast with the lowest and highest temp throughout the day.</p>
<hr />
<p dir="auto">The reason I revided this thread, though, is: <strong>DECIMAL MARKS IN WEATHER MODULES</strong></p>
<p dir="auto">I saw a lot of Mirrors from German users with typographically wrong decimal marks in the defeault modules <em>Current Weather</em> and <em>Weather Forecast</em> (9.5°C vs 9,5°C).</p>
<p dir="auto">With the latest update, there’s the possibility to change the decimal mark from the English decimal dot to the German (and other language’s) decimal comma. If you’re not sure what decimal mark your language is using, check this <a href="https://en.wikipedia.org/wiki/Decimal_separator#Countries_using_Arabic_numerals_with_decimal_point" target="_blank" rel="noopener noreferrer nofollow ugc">list on Wikipedia</a>.</p>
<p dir="auto">Usage:<br />
In the config of <em>currentweather</em> and <em>weatherforecast</em>, just add the line</p>
<pre><code>decimalSymbol: ","
<p dir="auto"><strong>only with MagicMirror² v2.2.0 and up</strong></p>
]]></description><link>https://forum.magicmirror.builders/post/33940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33940</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Sun, 14 Jan 2018 17:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to Default Modules on Mon, 12 Dec 2016 13:06:03 GMT]]></title><description><![CDATA[<p dir="auto">Just a quick question to the Weather Forecast default module. It is working fine, thanks for that, but:</p>
<p dir="auto">Today, we have Monday and the weather for today is shown by using the module current weather. Why is the monday (today) also included in the weather forecast?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/9225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9225</guid><dc:creator><![CDATA[nem1]]></dc:creator><pubDate>Mon, 12 Dec 2016 13:06:03 GMT</pubDate></item></channel></rss>
