<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen capture on a Raspberry Pi]]></title><description><![CDATA[<p dir="auto">I had to look this one up myself today. For those of you wanting to do a screen capture on your MM2 on the raspberry pi, you can install the <code>scrot</code> package (<code>sudo apt-get install scrot</code>) and use it to do that. Simply issuing the <code>scrot</code> command from a terminal will take a screen capture of what’s being displayed and saves a PNG file in the current folder. You can also tell it where to put the file by issuing <code>scrot /path/to/file.png</code> - note you must put in a file name as well for this to work.</p>
<p dir="auto">Now obviously you can’t do that when MM2 is running, but you can do it through an SSH login to the raspberry pi. You will have to tell it which display to use: <code>DISPLAY=:0 scrot /path/to/file.png</code>.</p>
<p dir="auto">Because I develop from a remote machine (through SSH), the above command comes in handy because I can drop the file onto a shared folder and access it from my remote system.</p>
<p dir="auto">Using <code>scrot</code> beats taking a picture of the screen whenever you want to show something on your MM installation.</p>
]]></description><link>https://forum.magicmirror.builders/topic/37/screen-capture-on-a-raspberry-pi</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 11:10:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/37.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 May 2016 21:31:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screen capture on a Raspberry Pi on Sun, 12 Aug 2018 21:12:01 GMT]]></title><description><![CDATA[<p dir="auto">Really helpful, thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/43336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43336</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Sun, 12 Aug 2018 21:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to Screen capture on a Raspberry Pi on Sat, 11 Aug 2018 10:07:07 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the information.</p>
]]></description><link>https://forum.magicmirror.builders/post/43286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43286</guid><dc:creator><![CDATA[steveray]]></dc:creator><pubDate>Sat, 11 Aug 2018 10:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Screen capture on a Raspberry Pi on Thu, 22 Jun 2017 11:35:38 GMT]]></title><description><![CDATA[<p dir="auto">If you are interested in using screen capture you can try <a href="http://www.dpcoupon.com/store/techsmith-promo-codes/" target="_blank" rel="noopener noreferrer nofollow ugc">techsmith</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/24386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24386</guid><dc:creator><![CDATA[devinpaul]]></dc:creator><pubDate>Thu, 22 Jun 2017 11:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to Screen capture on a Raspberry Pi on Thu, 05 May 2016 08:13:49 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! Good to know. I usually use VNC, but this could be helpful too.</p>
]]></description><link>https://forum.magicmirror.builders/post/185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/185</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 05 May 2016 08:13:49 GMT</pubDate></item></channel></rss>
