<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NPM restart issue]]></title><description><![CDATA[<p dir="auto">Hi, i’ve had Magic Mirror up and running for a few days now and all was fine.</p>
<p dir="auto">I added new module and now when i run NPM restart i get the following</p>
<pre><code class="language-pi@Mirror:~/MagicMirror">&gt; magicmirror@2.0.0 start /home/pi/MagicMirror
&gt; electron js/electron.js
npm ERR! Linux 4.4.14-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "restart"
npm ERR! node v6.3.0
npm ERR! npm  v3.10.3
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     electron js/electron.js
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
**Sorry can't work out how to get it out of inline**
I google this error and noticed that something similar was posted which referred to an Electron Quick start which i also ran which generate a similar error.
heres the content of my nam-debug.log any thoughts?
1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'restart' ]
2 info using npm@3.10.3
3 info using node@v6.3.0
4 verbose run-script [ 'prerestart',
4 verbose run-script   'prestop',
4 verbose run-script   'stop',
4 verbose run-script   'poststop',
4 verbose run-script   'restart',
4 verbose run-script   'prestart',
4 verbose run-script   'start',
4 verbose run-script   'poststart',
4 verbose run-script   'postrestart' ]
5 info lifecycle magicmirror@2.0.0~prerestart: magicmirror@2.0.0
6 silly lifecycle magicmirror@2.0.0~prerestart: no script for prerestart, continuing
7 info lifecycle magicmirror@2.0.0~prestop: magicmirror@2.0.0
8 silly lifecycle magicmirror@2.0.0~prestop: no script for prestop, continuing
9 info lifecycle magicmirror@2.0.0~stop: magicmirror@2.0.0
10 silly lifecycle magicmirror@2.0.0~stop: no script for stop, continuing
11 info lifecycle magicmirror@2.0.0~poststop: magicmirror@2.0.0
12 silly lifecycle magicmirror@2.0.0~poststop: no script for poststop, continuing
13 info lifecycle magicmirror@2.0.0~restart: magicmirror@2.0.0
14 silly lifecycle magicmirror@2.0.0~restart: no script for restart, continuing
15 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
16 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
17 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
18 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
19 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
20 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
21 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
22 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
23 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
24 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
24 verbose stack Exit status 1
24 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:242:16)
24 verbose stack     at emitTwo (events.js:106:13)
24 verbose stack     at EventEmitter.emit (events.js:191:7)
24 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
24 verbose stack     at ChildProcess.emit (events.js:191:7)
24 verbose stack     at maybeClose (internal/child_process.js:852:16)
24 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
25 verbose pkgid magicmirror@2.0.0
26 verbose cwd /home/pi/MagicMirror/config
27 error Linux 4.4.14-v7+
28 error argv "/usr/bin/nodejs" "/usr/bin/npm" "restart"
29 error node v6.3.0
30 error npm  v3.10.3
31 error code ELIFECYCLE
32 error magicmirror@2.0.0 start: `electron js/electron.js`
32 error Exit status 1
33 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
33 error Make sure you have the latest version of node.js and npm installed.
33 error If you do, this is most likely a problem with the magicmirror package,
33 error not with npm itself.
33 error Tell the author that this fails on your system:
33 error     electron js/electron.js
33 error You can get information on how to open an issue for this project with:
33 error     npm bugs magicmirror
33 error Or if that isn't available, you can get their info via:
33 error     npm owner ls magicmirror
33 error There is likely additional logging output above.
34 verbose exit [ 1, true ]</code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/376/npm-restart-issue</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 18:33:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/376.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jul 2016 19:46:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 17:54:54 GMT]]></title><description><![CDATA[<p dir="auto">Sleep? Is there a definition for that? :)</p>
<p dir="auto">To note: the npm process starts up Electron in kiosk mode on the rpi. Electron is simply a browser, which then loads the localhost address to MM². So if you know your rpi’s address on your network, you can load it up anywhere through a browser.</p>
<p dir="auto">In case you haven’t seen it, I posted how my (development) setup is, and it hints at doing just that with a remote browser:<br />
<a href="https://forum.magicmirror.builders/topic/265/my-setup-or-how-crazy-i-am">https://forum.magicmirror.builders/topic/265/my-setup-or-how-crazy-i-am</a></p>
]]></description><link>https://forum.magicmirror.builders/post/2775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2775</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 21 Jul 2016 17:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 17:28:44 GMT]]></title><description><![CDATA[<p dir="auto">Arrrr that’s Because I didn’t realise you could access Mirror through the browser without a running. And I hadn’t thought to test it out.</p>
<p dir="auto">So I’m basically providing two conflicting commands that’s causing the error then.  (In its most basic of explanations)</p>
<p dir="auto">Thanks for your answers though. Do you ever sleep?</p>
]]></description><link>https://forum.magicmirror.builders/post/2768</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2768</guid><dc:creator><![CDATA[mikmonken]]></dc:creator><pubDate>Thu, 21 Jul 2016 17:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 08:41:47 GMT]]></title><description><![CDATA[<p dir="auto">Actually, you can’t run both the default startup of the mirror, AND a serveronly. Once the mirror is up and running, just open a browser from wherever you are and load up the rpi’s address with the configured port. I believe you said that’s :8080. I guess I don’t understand why you are trying to also run serveronly …</p>
]]></description><link>https://forum.magicmirror.builders/post/2760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2760</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 21 Jul 2016 08:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 08:35:35 GMT]]></title><description><![CDATA[<p dir="auto">this is where i’m out of my depth then, does the fact that the mirror boots fine on RPI start up not mean that the config.js is OK?</p>
<p dir="auto">I’m guessing not, but is there an easy way to debug? usually if the config.js file is wrong (say i get a comma out of place) then mirror just boots onto the default you’ve got a problem with the config.js screen check you have one page, which doesn’t happen with this error?</p>
]]></description><link>https://forum.magicmirror.builders/post/2759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2759</guid><dc:creator><![CDATA[mikmonken]]></dc:creator><pubDate>Thu, 21 Jul 2016 08:35:35 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 08:25:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mikmonken" aria-label="Profile: mikmonken">@<bdi>mikmonken</bdi></a> said in <a href="/post/2757">NPM restart issue</a>:</p>
<p dir="auto">pi@Mirror:~/MagicMirror $ node serveronly<br />
Loading config …<br />
WARNING! Could not find config. Please create one.</p>
<p dir="auto">That right there should be your clue … You have an error in your <code>'config.js'</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/2758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2758</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 21 Jul 2016 08:25:57 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Thu, 21 Jul 2016 07:35:46 GMT]]></title><description><![CDATA[<p dir="auto">OK so after a fresh install all seemed to work, i’ve just tried to log in via SSH from outside my network, and so i could see the mirror ran the server only mode command and it churns out this.</p>
<pre><code>pi@Mirror:~/MagicMirror $ node serveronly
Loading config ...
Loading module helpers ...
No helper found for module: helloworld.
All module helpers loaded.
Starting server op port 8080 ...
Server started ...
Sockets connected &amp; modules started ...
Ready to go! Please point your browser to: http://localhost:8080
{ Error: listen EADDRINUSE :::8080
    at Object.exports._errnoException (util.js:1008:11)
    at exports._exceptionWithHostPort (util.js:1031:20)
    at Server._listen2 (net.js:1253:14)
    at listen (net.js:1289:10)
    at Server.listen (net.js:1385:5)
    at new Server (/home/pi/MagicMirror/js/server.js:17:9)
    at /home/pi/MagicMirror/js/app.js:121:17
    at loadConfig (/home/pi/MagicMirror/js/app.js:45:4)
    at start (/home/pi/MagicMirror/js/app.js:107:3)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/serveronly/index.js:2:5)
  code: 'EADDRINUSE',
  errno: 'EADDRINUSE',
  syscall: 'listen',
  address: '::',
  port: 8080 }
<p dir="auto">So could it be the act of running the Server only mode that causes the issue? as now i get all the same errors listed above when i try to run pm restart?</p>
<p dir="auto">Just as a side note that despite getting the error it still let me log onto the mirror through safari on :8080</p>
]]></description><link>https://forum.magicmirror.builders/post/2757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2757</guid><dc:creator><![CDATA[mikmonken]]></dc:creator><pubDate>Thu, 21 Jul 2016 07:35:46 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Wed, 20 Jul 2016 20:10:45 GMT]]></title><description><![CDATA[<p dir="auto">i don’t think  it did, fortunately i backed up my RPI before i add the module so i’ll try a fresh install and see if that works.</p>
<p dir="auto">I was adding back in the compliments module so i could put a happy birthday message on so had change the narrative in the compliments module.</p>
]]></description><link>https://forum.magicmirror.builders/post/2738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2738</guid><dc:creator><![CDATA[mikmonken]]></dc:creator><pubDate>Wed, 20 Jul 2016 20:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to NPM restart issue on Wed, 20 Jul 2016 19:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Does it work if you remove the module you recently added? If so, it’s not an npm nor electron problem. It’s the module, probably a bad configuration, either in the module settings, or in your config.js.</p>
]]></description><link>https://forum.magicmirror.builders/post/2737</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2737</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 20 Jul 2016 19:59:53 GMT</pubDate></item></channel></rss>
