<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Module WunderGround problem]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have a problem with installing the WunderGround Module. I get some warnings when I execute npm install, see image.<br />
Can anybody please help me?<br />
<img src="/uploads/files/1469288939423-wunderground.png" alt="0_1469288603347_WunderGround.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Sebastian</p>
]]></description><link>https://forum.magicmirror.builders/topic/394/module-wunderground-problem</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:43:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/394.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Jul 2016 15:49:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Module WunderGround problem on Sun, 24 Jul 2016 10:06:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys,<br />
thank you for your help. I thought I have always to run npm install.</p>
<p dir="auto">Now I´m a little bit smarter. Only run npm install when the author it´s write.</p>
]]></description><link>https://forum.magicmirror.builders/post/2855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2855</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Sun, 24 Jul 2016 10:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sun, 24 Jul 2016 04:14:00 GMT]]></title><description><![CDATA[<p dir="auto">I said it before, I will say it again:</p>
<p dir="auto"><strong>Do not run <code>'npm install'</code> unless you are specifically told to do so by the module’s README, or by the author</strong> <em>(who should be putting it in the README anyway.)</em></p>
]]></description><link>https://forum.magicmirror.builders/post/2853</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2853</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Sun, 24 Jul 2016 04:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sun, 24 Jul 2016 03:43:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shgmongohh" aria-label="Profile: shgmongohh">@<bdi>shgmongohh</bdi></a><br />
It’s not obvious what to do - but you can look at the instructions for, say, MMM-Wunderlist:<br />
“Navigate into your MagicMirror’s modules folder and execute git clone <a href="https://github.com/paviro/MMM-Wunderlist.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/paviro/MMM-Wunderlist.git</a>. A new folder will appear navigate into it.”</p>
<p dir="auto">So you need to do the same for WUNDERGROUND (but use the correct git). In other words, execute<br />
sudo git clone <a href="https://github.com/RedNax67/MMM-WunderGround.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/RedNax67/MMM-WunderGround.git</a></p>
<p dir="auto">Viel Glueck</p>
]]></description><link>https://forum.magicmirror.builders/post/2849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2849</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Sun, 24 Jul 2016 03:43:58 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sat, 23 Jul 2016 20:03:34 GMT]]></title><description><![CDATA[<p dir="auto">well i looked in the repository and the author doesn’t say that you have to run the command npm install, so i don’t know why you are trying this?!</p>
]]></description><link>https://forum.magicmirror.builders/post/2845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2845</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 23 Jul 2016 20:03:34 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sat, 23 Jul 2016 19:26:05 GMT]]></title><description><![CDATA[<p dir="auto">No, that doesn´t work. I get the same message.</p>
<p dir="auto"><img src="/uploads/files/1469301953499-wunderground2.png" alt="0_1469301617847_WunderGround2.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/2844</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2844</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Sat, 23 Jul 2016 19:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sat, 23 Jul 2016 18:47:02 GMT]]></title><description><![CDATA[<p dir="auto">MMM-WunderGround</p>
]]></description><link>https://forum.magicmirror.builders/post/2843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2843</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 23 Jul 2016 18:47:02 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sat, 23 Jul 2016 17:48:39 GMT]]></title><description><![CDATA[<p dir="auto">But which is the right directory?</p>
]]></description><link>https://forum.magicmirror.builders/post/2839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2839</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Sat, 23 Jul 2016 17:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to Module WunderGround problem on Sat, 23 Jul 2016 17:44:34 GMT]]></title><description><![CDATA[<p dir="auto">you are in the wrong directory cd into it first then npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/2837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2837</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 23 Jul 2016 17:44:34 GMT</pubDate></item></channel></rss>
