<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Czech mirror in IKEA LILLÅNGEN]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">after 6 months I finally completed my mirror. I used <a href="http://www.ikea.com/cz/cs/catalog/products/S09893982/" target="_blank" rel="noopener noreferrer nofollow ugc">IKEA LILLÅNGEN</a> mirror.</p>
<p dir="auto">Components:</p>
<ul>
<li>14’’ LCD panel LP154W02 (from old HP notebook)</li>
<li>LVDS controler <a href="http://www.ebay.com/itm/LP154W02-LP154WE2-LTN154MT02-B154SW01-V-0-screen-TV-HDMI-controller-board-KIT-/221989744241" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.com/itm/LP154W02-LP154WE2-LTN154MT02-B154SW01-V-0-screen-TV-HDMI-controller-board-KIT-/221989744241</a></li>
<li>Raspberry pi 3</li>
<li><a href="http://www.modmypi.com/blog/raspberry-pi-gpio-sensing-motion-detection" target="_blank" rel="noopener noreferrer nofollow ugc">HC-SR501</a> Infrared PIR Motion Sensor Module for Raspberry pi</li>
</ul>
<p dir="auto">Because LCDs high consumption I’d like to switching on/off LCD panel, but the boot up time is almost 8 sec, so the PIR is controling only backlight.</p>
<p dir="auto">Here some photos. If you have any question, feel free to ask :)</p>
<p dir="auto"><a href="https://goo.gl/photos/8mwrdMqRnGwHfEqa7" target="_blank" rel="noopener noreferrer nofollow ugc">https://goo.gl/photos/8mwrdMqRnGwHfEqa7</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/404/czech-mirror-in-ikea-lillången</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 09:01:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/404.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jul 2016 11:42:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Thu, 25 Aug 2016 06:05:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomaszmuda" aria-label="Profile: TomasZmuda">@<bdi>TomasZmuda</bdi></a><br />
I tested unplugging pin 3 and you are right: the display / backlight ist switched off 👍<br />
I also got me a voltmeter and checked the currents :) seems to be identical to your setup. So next, I’ll connect a PIR, check the current and connect it as you described.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/3963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3963</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Thu, 25 Aug 2016 06:05:32 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 16 Aug 2016 10:52:21 GMT]]></title><description><![CDATA[<p dir="auto">I just posted a question about PIR connection to a similar board. Feel free to help me out guys :)</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/503/pir-sensor-to-cut-backlight-power">https://forum.magicmirror.builders/topic/503/pir-sensor-to-cut-backlight-power</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomaszmuda" aria-label="Profile: TomasZmuda">@<bdi>TomasZmuda</bdi></a> if you look at my option 2. do I need to ground inverter and Pi?</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/3729</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3729</guid><dc:creator><![CDATA[MrH]]></dc:creator><pubDate>Tue, 16 Aug 2016 10:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Wed, 03 Aug 2016 10:07:44 GMT]]></title><description><![CDATA[<p dir="auto">Perfect, you could only unplug this cable and the LCD shound be without background. It’s simple test. :) Next plug this cable to PIR output and as i wrote in first post, don’t remember hook up ground between LVDS and Raspberry.</p>
]]></description><link>https://forum.magicmirror.builders/post/3312</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3312</guid><dc:creator><![CDATA[TomasZmuda]]></dc:creator><pubDate>Wed, 03 Aug 2016 10:07:44 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 02 Aug 2016 18:08:57 GMT]]></title><description><![CDATA[<p dir="auto">I found the description of the board and pins:<br />
<a href="http://www.vslcd.com/Specification/T.VST29.03.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.vslcd.com/Specification/T.VST29.03.pdf</a></p>
<p dir="auto">“CN2” describes the pinout for the invertor.<br />
Pin 3 is backlight on/off and pin 4 is for the adjustment of the brightness.</p>
]]></description><link>https://forum.magicmirror.builders/post/3265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3265</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Tue, 02 Aug 2016 18:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 02 Aug 2016 17:19:20 GMT]]></title><description><![CDATA[<p dir="auto">Without the proper tools or instruments, you have to be really careful that you don’t short out the inverter or cause other damage.</p>
]]></description><link>https://forum.magicmirror.builders/post/3263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3263</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 02 Aug 2016 17:19:20 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 02 Aug 2016 16:37:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Tomas,</p>
<p dir="auto">unfortunately I don’t have a voltmeter or an oscilloscope at hand. I hope I’ll figure it out somehow :/</p>
<p dir="auto">Sebastian</p>
]]></description><link>https://forum.magicmirror.builders/post/3262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3262</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Tue, 02 Aug 2016 16:37:06 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 02 Aug 2016 16:00:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sero,</p>
<p dir="auto">your inventor has 6 cables, so one of this should be backlight controller. I can’t help you more, you have to measure it by voltmeter or oscilloscope.</p>
<p dir="auto">Tomas</p>
]]></description><link>https://forum.magicmirror.builders/post/3261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3261</guid><dc:creator><![CDATA[TomasZmuda]]></dc:creator><pubDate>Tue, 02 Aug 2016 16:00:29 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Mon, 01 Aug 2016 13:30:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">your mirror looks great!</p>
<p dir="auto">I´m planning to do the same (and I even looked at the same Ikea mirror :) ) and was wondering how you solved tha backlight handling exactly.</p>
<p dir="auto">You talked about an invertor in one of your posts. My controller has an invertor, too. Can you tell me if your solution would work here aswell?<br />
This is the board with the controller: <a href="http://www.ebay.de/itm/TV-HDMI-VGA-AV-USB-AUDIO-control-board-for-15-6-B156HAN01-2-1920x1080-IPS-LCD-/361128251020" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.de/itm/TV-HDMI-VGA-AV-USB-AUDIO-control-board-for-15-6-B156HAN01-2-1920x1080-IPS-LCD-/361128251020</a></p>
<p dir="auto">Thanks :)</p>
]]></description><link>https://forum.magicmirror.builders/post/3210</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3210</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Mon, 01 Aug 2016 13:30:06 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 26 Jul 2016 18:13:27 GMT]]></title><description><![CDATA[<p dir="auto">Of course, first I tried to control backlight by raspberry gpio. PIR send signal to raspberry, and by some <a href="http://diyhacking.com/raspberry-pi-gpio-control/" target="_blank" rel="noopener noreferrer nofollow ugc">python script</a> open NPN bipolar tranzistor which turns backlight on.<br />
<img src="http://www.tajned.cz/wp-content/uploads/2014/10/bipolar.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">But there was a problem with hight current, and any other problems.</p>
<p dir="auto">In the invertor the are 4 cables: ground, brightness 3,1-3,5V, backlight 5V, power 12V.</p>
<p dir="auto">Fortunately the backlight si possible to control via any voltage (not any, but 3V-12V is ok). The PIR has output 5V, so I connected the output from PIR directly to LVDS converter. Be carefull, you have to hook up the groud in raspberry and in LVDS!</p>
]]></description><link>https://forum.magicmirror.builders/post/2967</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2967</guid><dc:creator><![CDATA[TomasZmuda]]></dc:creator><pubDate>Tue, 26 Jul 2016 18:13:27 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 26 Jul 2016 15:37:47 GMT]]></title><description><![CDATA[<p dir="auto">How are you controlling the backlight?</p>
<p dir="auto">Could you share how this is done, please?</p>
]]></description><link>https://forum.magicmirror.builders/post/2958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2958</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Tue, 26 Jul 2016 15:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 26 Jul 2016 11:14:25 GMT]]></title><description><![CDATA[<p dir="auto">Now I have there only foil (film), it was really cheap (20€) <a href="http://www.dcfix.cz/detail.php?kod=F3398050" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.dcfix.cz/detail.php?kod=F3398050</a></p>
<p dir="auto">But my wife don’t like this, because it isn’t real mirror and you are seeing things like in fog.</p>
<p dir="auto">Now, I ask some glass companies for price offer and try the real mirror. The price is about 55€. <a href="http://glassolutions.cz/cs/produkty/mirastar-chromove-zrcadlo" target="_blank" rel="noopener noreferrer nofollow ugc">http://glassolutions.cz/cs/produkty/mirastar-chromove-zrcadlo</a> You can translate page via google translator.</p>
]]></description><link>https://forum.magicmirror.builders/post/2947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2947</guid><dc:creator><![CDATA[TomasZmuda]]></dc:creator><pubDate>Tue, 26 Jul 2016 11:14:25 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Tue, 26 Jul 2016 09:25:53 GMT]]></title><description><![CDATA[<p dir="auto">Great!</p>
<p dir="auto">One question, where did you ordered the 2 ways mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/2944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2944</guid><dc:creator><![CDATA[tataille]]></dc:creator><pubDate>Tue, 26 Jul 2016 09:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to Czech mirror in IKEA LILLÅNGEN on Mon, 25 Jul 2016 21:16:15 GMT]]></title><description><![CDATA[<p dir="auto">nice!</p>
<p dir="auto">I’m going for the same thing. Using a PIR to only cut backlightning. Power usage dropped from 38w to 5w. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/2923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2923</guid><dc:creator><![CDATA[MrH]]></dc:creator><pubDate>Mon, 25 Jul 2016 21:16:15 GMT</pubDate></item></channel></rss>
