<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Button white screen]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have installed the MMM Button. When I restart my PI3 I only get a white screen.<br />
When I uncomment the butten module in the config with //, the screen is after a new start normal.<br />
I have also tried it with a connected and unconneted butten. Always the same.</p>
<p dir="auto">Has anybody an idea, why I have a white screen?</p>
<p dir="auto">Sebastian</p>
]]></description><link>https://forum.magicmirror.builders/topic/411/mmm-button-white-screen</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 17:53:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/411.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Jul 2016 16:03:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Button white screen on Sun, 29 Jan 2017 09:39:24 GMT]]></title><description><![CDATA[<p dir="auto">Okay, next try…</p>
<pre><code>npm ERR! Linux 4.4.26-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
npm ERR! node v7.4.0
npm ERR! npm  v4.0.5
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     electron js/electron.js "dev"
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
]]></description><link>https://forum.magicmirror.builders/post/12870</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12870</guid><dc:creator><![CDATA[FlorianRD]]></dc:creator><pubDate>Sun, 29 Jan 2017 09:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 26 Jan 2017 08:27:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/florianrd" aria-label="Profile: FlorianRD">@<bdi>FlorianRD</bdi></a><br />
you are in the wrong directory.</p>
<pre><code class="language-bash">cd MagicMirror
npm start dev
]]></description><link>https://forum.magicmirror.builders/post/12547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12547</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Thu, 26 Jan 2017 08:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Wed, 25 Jan 2017 22:16:31 GMT]]></title><description><![CDATA[<p dir="auto">He guys. Another error log after raspberry startup. Maybe helps?</p>
<pre><code>pi@raspberrypi:~ $ npm start dev
npm ERR! node v6.9.1
npm ERR! npm  v3.10.8
npm ERR! path /home/pi/package.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! syscall open
npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR!     /home/pi/npm-debug.log
]]></description><link>https://forum.magicmirror.builders/post/12511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12511</guid><dc:creator><![CDATA[FlorianRD]]></dc:creator><pubDate>Wed, 25 Jan 2017 22:16:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Sun, 15 Jan 2017 18:21:45 GMT]]></title><description><![CDATA[<p dir="auto">Yes,  even many times.</p>
]]></description><link>https://forum.magicmirror.builders/post/11121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11121</guid><dc:creator><![CDATA[FlorianRD]]></dc:creator><pubDate>Sun, 15 Jan 2017 18:21:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Sun, 15 Jan 2017 10:49:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/florianrd" aria-label="Profile: FlorianRD">@<bdi>FlorianRD</bdi></a> after The Update do you have the raspberry pi restart?</p>
]]></description><link>https://forum.magicmirror.builders/post/11071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11071</guid><dc:creator><![CDATA[Nonamexp]]></dc:creator><pubDate>Sun, 15 Jan 2017 10:49:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Sun, 15 Jan 2017 09:38:55 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem. I did perform  <strong>“nmp install”</strong> and <strong>“npm install onoff”</strong> in the MMM-Button folder.<br />
And the fix from <em><strong>Nonamexp</strong></em>.  But the screen after a reboot is white. :-(</p>
<pre><code>pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
    at Error (native)
    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20)
    at Object.Module._extensions..node (module.js:583:18)
    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
    at Module.load (module.js:473:32)
    at tryModuleLoad (module.js:432:12)
    at Function.Module._load (module.js:424:3)
    at Module.require (module.js:483:17)
    at require (internal/module.js:20:19)
    at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
]]></description><link>https://forum.magicmirror.builders/post/11065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11065</guid><dc:creator><![CDATA[FlorianRD]]></dc:creator><pubDate>Sun, 15 Jan 2017 09:38:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 05 Jan 2017 19:30:22 GMT]]></title><description><![CDATA[<p dir="auto">now it woks, thank you very much.</p>
<p dir="auto">Have I made a mistake here?<br />
Or what is the reason?</p>
]]></description><link>https://forum.magicmirror.builders/post/10490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10490</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Thu, 05 Jan 2017 19:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 05 Jan 2017 18:04:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a> try this</p>
<p dir="auto">cd ~/MagicMirror/modules/MMM-Button<br />
sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=<a href="https://atom.io/download/atom-shell" target="_blank" rel="noopener noreferrer nofollow ugc">https://atom.io/download/atom-shell</a> --abi=50</p>
]]></description><link>https://forum.magicmirror.builders/post/10483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10483</guid><dc:creator><![CDATA[Nonamexp]]></dc:creator><pubDate>Thu, 05 Jan 2017 18:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 05 Jan 2017 17:54:29 GMT]]></title><description><![CDATA[<p dir="auto">i have the same problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/10482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10482</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Thu, 05 Jan 2017 17:54:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Tue, 15 Nov 2016 22:24:15 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem. Also did everything from this thread.</p>
]]></description><link>https://forum.magicmirror.builders/post/8008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8008</guid><dc:creator><![CDATA[dicker182]]></dc:creator><pubDate>Tue, 15 Nov 2016 22:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Tue, 15 Nov 2016 17:43:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello, i have the same problem. I also get a white-screen. My error-log:</p>
<p dir="auto">$ tail -f /home/pi/.pm2/logs/mm-error-0.log</p>
<pre><code>at Error (native)
at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
<p dir="auto">Any Ideas? Thanks!<br />
I’ve done everything which was postet in this topic…</p>
]]></description><link>https://forum.magicmirror.builders/post/7984</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7984</guid><dc:creator><![CDATA[schubi]]></dc:creator><pubDate>Tue, 15 Nov 2016 17:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Fri, 29 Jul 2016 16:10:16 GMT]]></title><description><![CDATA[<p dir="auto">It can be a confusing, sometimes damn near frustrating landscape to maneuver. Glad you got it to work though.</p>
]]></description><link>https://forum.magicmirror.builders/post/3144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3144</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 29 Jul 2016 16:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Fri, 29 Jul 2016 10:24:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a><br />
Ahhh, okay, that´s an explanation why I have sometimes problems with some modules.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/3120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3120</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Fri, 29 Jul 2016 10:24:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Fri, 29 Jul 2016 05:35:47 GMT]]></title><description><![CDATA[<p dir="auto">No, the instructions, as written, are accurate. You missed the last bit of Step 1:</p>
<ol>
<li>Navigate into your MagicMirror’s modules folder and execute git clone <a href="https://github.com/ptrbld/MMM-Button.git.**%60A" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ptrbld/MMM-Button.git.**`A</a> new folder will appear navigate into it.`**</li>
<li>Execute <code>npm install</code> to install the node dependencies.</li>
</ol>
<p dir="auto">Had you done that last bit, you would be executing the next step from <em>within</em> the button module folder, <em>not</em> within the MagicMirror folder.</p>
]]></description><link>https://forum.magicmirror.builders/post/3111</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3111</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 29 Jul 2016 05:35:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Fri, 29 Jul 2016 05:24:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a></p>
<p dir="auto">I read the instruction and I executed the <code>nmp install</code> in the <em>MagicMirror</em> folder and  thought that <code>onoff</code> would be installed automaticly.<br />
But I had to execute <code>npm install onoff </code> extra in the  <em>MagicMirror</em> folder to get the module run.</p>
<p dir="auto">Maybe there should a step 3, that tells you to execute  <code>npm install onoff </code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/3109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3109</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Fri, 29 Jul 2016 05:24:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 28 Jul 2016 20:06:35 GMT]]></title><description><![CDATA[<p dir="auto">That tells me you didn’t read the instructions, because step 2, under <strong>Installation</strong>, it specifically says to run <code>'npm install'</code> which would’ve taken care of installing <code>onoff</code> for you. I find it helps when I follow the author’s instructions. </p>
<p dir="auto"><a href="https://github.com/PtrBld/MMM-Button#installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/PtrBld/MMM-Button#installation</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3079</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 28 Jul 2016 20:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 28 Jul 2016 19:40:24 GMT]]></title><description><![CDATA[<p dir="auto">Solved the problem…</p>
<p dir="auto">I hat forgotten to install onoff (pi@raspberrypi:~/MagicMirror $ npm install onoff<br />
)</p>
]]></description><link>https://forum.magicmirror.builders/post/3076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3076</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Thu, 28 Jul 2016 19:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Thu, 28 Jul 2016 19:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a><br />
I checked the double checked the spelling. Everthing is correct.<br />
The screen stays white…</p>
<p dir="auto">I tried node serveronly</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ node serveronly<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
No helper found for module: clock.<br />
Initializing new module helper …<br />
WARNING! Could not find config. Please create one.<br />
Whoops! There was an uncaught exception…<br />
{ Error: Cannot find module ‘onoff’<br />
at Function.Module._resolveFilename (module.js:440:15)<br />
at Function.Module._load (module.js:388:25)<br />
at Module.require (module.js:468:17)<br />
at require (internal/module.js:20:19)<br />
at Object. (/home/pi/MagicMirror/modules/MMM-Button/node_helper.j        s:10:14)<br />
at Module._compile (module.js:541:32)<br />
at Object.Module._extensions…js (module.js:550:10)<br />
at Module.load (module.js:458:32)<br />
at tryModuleLoad (module.js:417:12)<br />
at Function.Module._load (module.js:409:3) code: ‘MODULE_NOT_FOUND’ }<br />
MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?<br />
If you think this really is an issue, please open an issue on GitHub: <a href="https://gi" target="_blank" rel="noopener noreferrer nofollow ugc">https://gi</a>        <a href="http://thub.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">thub.com/MichMich/MagicMirror/issues</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3072</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Thu, 28 Jul 2016 19:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Wed, 27 Jul 2016 17:31:48 GMT]]></title><description><![CDATA[<p dir="auto">code: ‘MODULE_NOT_FOUND’ sounds like you misspelled the module name in the config</p>
]]></description><link>https://forum.magicmirror.builders/post/3008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3008</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 27 Jul 2016 17:31:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Button white screen on Wed, 27 Jul 2016 16:29:19 GMT]]></title><description><![CDATA[<p dir="auto">Here is the error log:</p>
<p dir="auto">pi@raspberrypi:~ $ tail -f  /home/pi/.pm2/logs/mm-error-0.log</p>
<pre><code>at Module._resolveFilename (module.js:438:15)
at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/comm/reset-search-paths.js:35:12)
at Function.Module._load (module.js:386:25)
at Module.require (module.js:466:17)
at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Button/node_helper.js:10:14)
at Object.Module._extensions..js (module.js:550:10)
at Module.load (module.js:456:32)
at tryModuleLoad (module.js:415:12) code: 'MODULE_NOT_FOUND' }
]]></description><link>https://forum.magicmirror.builders/post/3007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3007</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Wed, 27 Jul 2016 16:29:19 GMT</pubDate></item></channel></rss>
