<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google Assistant Demo and Idea.]]></title><description><![CDATA[<p dir="auto">After several times of trial, I can run google assistant demo on my raspberrypi. Most of the problems were about sound configuration. Anyway, it works very well at last.</p>
<p dir="auto">With ‘grpc client API’, someone can build an awesome module for MM someday. But I cannot wait.<br />
So…<br />
I opened IFTTT;</p>
<p dir="auto"><strong>If [Google Assistant] to [Maker Webhooks]</strong></p>
<p dir="auto">If your home internet box can support DDNS(or static IP), you can make your mirror visible from outside your home by port-forwarding. It means IFTTT can send some message to your mirror.<br />
I tested some message with MMM-IFTTT. it works.</p>
<p dir="auto">So I made some IFTTT applets;</p>
<p dir="auto">If you say “Wake up”, then make a web request ‘POST {message:‘screen on’}’<br />
If you say “Let my mirror $ (or Tell my mirror $ or Ask my mirror $)”, then make a web request ‘POST {message:$}’<br />
…</p>
<p dir="auto">And I will make a small listener for the listening requests from IFTTT hook. The listener will parse requested commands and find proper MM notification or some function with my pre-defined mapping recipes.</p>
<p dir="auto">It could be like this;<br />
I say “Ok, Google. Let my mirror ‘sleep in ten minutes’”. Then, GA run in the background of my mirror listens that commands and IFTTT trigger will be fired. GA will response me “Yes, she will ‘sleep in ten minutes’”(response format could be defined in IFTTT).<br />
And ‘sleep in ten minutes’ message will be posted to my MM via DDNS, and after parsing and mapping the message to turn display off.</p>
<p dir="auto">I have no time because I’m just a holiday hobbist. So, I could make this real in this weekend. But I think it is very simple, therefore everybody can make his own easily.</p>
<p dir="auto">Anyway, if you have not only DDNS but also SSL certificated server, it could be easier and better to make webhook directly without IFTTT.</p>
<p dir="auto">I’m reading ‘grpc API’ all day long, It just gave me some headache. so I want to escape. I hope there will be someone who can provide the awsome native integrated GA to us.</p>
<p dir="auto">ps. Alexa-IFTTT is not good as GA-IFTTT. Alexa cannot pick ‘ingredients’ up from your sentence. So if you use Alexa, you should make so many individual applets for all commands you wish.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4197/google-assistant-demo-and-idea</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 01:19:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4197.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Jun 2017 21:00:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Thu, 29 Jun 2017 00:28:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/24624">Google Assistant Demo and Idea.</a>:</p>
<p dir="auto">EVERY American has a bad accent… do your worst LOL</p>
<p dir="auto">Uhh, I’m from New Yawk Siddy. I aint got no ackcent.</p>
<p dir="auto">Fuhgeddaboudit!</p>
]]></description><link>https://forum.magicmirror.builders/post/24635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24635</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 29 Jun 2017 00:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Wed, 28 Jun 2017 21:08:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> said in <a href="/post/24622">Google Assistant Demo and Idea.</a>:</p>
<p dir="auto">Tried giving the Google Assistant SDK a go. Didn’t work well for me due to my Scottish Accent. If I put on a bad American accent it works well but Alexa seems to be perfect with me.</p>
]]></description><link>https://forum.magicmirror.builders/post/24624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24624</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 28 Jun 2017 21:08:29 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Wed, 28 Jun 2017 20:04:18 GMT]]></title><description><![CDATA[<p dir="auto">Tried giving the Google Assistant SDK a go. Didn’t work well for me due to my Scottish Accent. If I put on a bad American accent it works well but Alexa seems to be perfect with me.</p>
]]></description><link>https://forum.magicmirror.builders/post/24622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24622</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Wed, 28 Jun 2017 20:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Wed, 28 Jun 2017 09:46:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauravsacc" aria-label="Profile: gauravsacc">@<bdi>gauravsacc</bdi></a> said in <a href="/post/24527">Google Assistant Demo and Idea.</a>:</p>
<p dir="auto">Here’s my progress on the GA module <a href="https://github.com/gauravsacc/MMM-GoogleAssistant" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/gauravsacc/MMM-GoogleAssistant</a></p>
<p dir="auto">Wooooow!</p>
]]></description><link>https://forum.magicmirror.builders/post/24605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24605</guid><dc:creator><![CDATA[ezarlive]]></dc:creator><pubDate>Wed, 28 Jun 2017 09:46:11 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Mon, 26 Jun 2017 18:43:00 GMT]]></title><description><![CDATA[<p dir="auto">Here’s my progress on the GA module <a href="https://github.com/gauravsacc/MMM-GoogleAssistant" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/gauravsacc/MMM-GoogleAssistant</a></p>
]]></description><link>https://forum.magicmirror.builders/post/24527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24527</guid><dc:creator><![CDATA[gauravsacc]]></dc:creator><pubDate>Mon, 26 Jun 2017 18:43:00 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Fri, 23 Jun 2017 19:13:14 GMT]]></title><description><![CDATA[<p dir="auto">Nice… I just started on a similar implementation. I’m using pubsub though.</p>
]]></description><link>https://forum.magicmirror.builders/post/24427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24427</guid><dc:creator><![CDATA[gauravsacc]]></dc:creator><pubDate>Fri, 23 Jun 2017 19:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Fri, 23 Jun 2017 15:04:11 GMT]]></title><description><![CDATA[<p dir="auto">Exciting stuff!</p>
]]></description><link>https://forum.magicmirror.builders/post/24423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24423</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Fri, 23 Jun 2017 15:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant Demo and Idea. on Fri, 23 Jun 2017 05:39:36 GMT]]></title><description><![CDATA[<p dir="auto">Wonderful! Can you make a MMM module?</p>
]]></description><link>https://forum.magicmirror.builders/post/24418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24418</guid><dc:creator><![CDATA[ezarlive]]></dc:creator><pubDate>Fri, 23 Jun 2017 05:39:36 GMT</pubDate></item></channel></rss>
