<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-awesome-alexa black screen, installation error]]></title><description><![CDATA[<p dir="auto">I am trying to get the MMM-awesome-alexa black screen module to work.</p>
<p dir="auto">However, my MM only gives a black screen as well as the following installation errors:</p>
<p dir="auto">100 error code ELIFECYCLE<br />
101 error mmm-awesome-alexa@1.0.0 postinstall: <code>npm run build</code><br />
101 error Exit status 1<br />
102 error Failed at the mmm-awesome-alexa@1.0.0 postinstall script ‘npm run build’.<br />
102 error Make sure you have the latest version of node.js and npm installed.<br />
102 error If you do, this is most likely a problem with the mmm-awesome-alexa package,<br />
102 error not with npm itself.<br />
102 error Tell the author that this fails on your system:<br />
102 error     npm run build</p>
<p dir="auto">Anyone knows how to fix this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/4227/mmm-awesome-alexa-black-screen-installation-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 01:46:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4227.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Jun 2017 20:32:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-awesome-alexa black screen, installation error on Sat, 08 Jul 2017 11:00:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mc_landin" aria-label="Profile: mc_landin">@<bdi>mc_landin</bdi></a> read the gitter forum…there are a few solution for problems and common mistakes.</p>
]]></description><link>https://forum.magicmirror.builders/post/25085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25085</guid><dc:creator><![CDATA[mydiva]]></dc:creator><pubDate>Sat, 08 Jul 2017 11:00:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa black screen, installation error on Sat, 08 Jul 2017 10:52:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mydiva" aria-label="Profile: mydiva">@<bdi>mydiva</bdi></a> said in <a href="/post/25066">MMM-awesome-alexa black screen, installation error</a>:</p>
<p dir="auto">gitter</p>
<p dir="auto">Doesn’t do the trick for me. What else may fix this?</p>
]]></description><link>https://forum.magicmirror.builders/post/25084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25084</guid><dc:creator><![CDATA[mc_landin]]></dc:creator><pubDate>Sat, 08 Jul 2017 10:52:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa black screen, installation error on Fri, 07 Jul 2017 21:17:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mydiva" aria-label="Profile: mydiva">@<bdi>mydiva</bdi></a> Thanks that worked for me</p>
]]></description><link>https://forum.magicmirror.builders/post/25069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25069</guid><dc:creator><![CDATA[letsirk]]></dc:creator><pubDate>Fri, 07 Jul 2017 21:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa black screen, installation error on Fri, 07 Jul 2017 20:05:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mc_landin" aria-label="Profile: mc_landin">@<bdi>mc_landin</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/letsirk" aria-label="Profile: letsirk">@<bdi>letsirk</bdi></a> in the MMM-awesome-alexa directory, run <code> npm run electron-rebuild</code></p>
<p dir="auto">check this side:<br />
<a href="https://gitter.im/awesome-alexa/Lobby" target="_blank" rel="noopener noreferrer nofollow ugc">gitter</a></p>
<p dir="auto">Does it works to you guys? I got it to work but it did not recognize my voice… please write your problems at gitter…</p>
]]></description><link>https://forum.magicmirror.builders/post/25066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25066</guid><dc:creator><![CDATA[mydiva]]></dc:creator><pubDate>Fri, 07 Jul 2017 20:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa black screen, installation error on Fri, 07 Jul 2017 15:46:31 GMT]]></title><description><![CDATA[<p dir="auto">I’m having the same issue, if you find a fix please let me know.</p>
]]></description><link>https://forum.magicmirror.builders/post/25058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25058</guid><dc:creator><![CDATA[letsirk]]></dc:creator><pubDate>Fri, 07 Jul 2017 15:46:31 GMT</pubDate></item></channel></rss>
