<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wunderlist, blank screen when Wunderlist module is added to config.js]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">I am having issues with the ‘MMM-Wunderlist’ and the enhanced version, when I add this in as a modules, then reboot the rpi. All I get is a blank screen? When I ssh in and then remove the module from the config.js, reboot then everything is back again. It does not seem to matter what I add the module config I get the same results.</p>
<p dir="auto">Thanks</p>
<p dir="auto">Nathan</p>
]]></description><link>https://forum.magicmirror.builders/topic/4246/wunderlist-blank-screen-when-wunderlist-module-is-added-to-config-js</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 17:23:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4246.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Jun 2017 19:45:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Fri, 04 Aug 2017 15:59:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/randomnoise" aria-label="Profile: randomnoise">@<bdi>randomnoise</bdi></a> Thank you very much!<br />
I didn’t know that, but it makes sense!<br />
It is working now =)</p>
]]></description><link>https://forum.magicmirror.builders/post/26192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26192</guid><dc:creator><![CDATA[ceddirr]]></dc:creator><pubDate>Fri, 04 Aug 2017 15:59:32 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Thu, 03 Aug 2017 20:55:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ceddirr" aria-label="Profile: ceddirr">@<bdi>ceddirr</bdi></a> looks like you’re running npm install from the modules directory, you probably want to cd in to the wunderlist folder (which itself is in modules) then run the npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/26173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26173</guid><dc:creator><![CDATA[randomnoise]]></dc:creator><pubDate>Thu, 03 Aug 2017 20:55:42 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Fri, 04 Aug 2017 06:39:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Same thing is happening to me, but just installed the enhanced folder.<br />
npm install is going bad :</p>
<pre><code>pi@mirror:~/MagicMirror/modules $ npm install
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
npm WARN modules No description
npm WARN modules No repository field.
npm WARN modules No README data
npm WARN modules No license field.
<p dir="auto">Any idea?<br />
Did you just re install the standard folder instead of the enhanced one to solve your problem, please?</p>
<p dir="auto">Thank you for your help!<br />
Cedric</p>
]]></description><link>https://forum.magicmirror.builders/post/26171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26171</guid><dc:creator><![CDATA[ceddirr]]></dc:creator><pubDate>Fri, 04 Aug 2017 06:39:16 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Thu, 29 Jun 2017 04:16:40 GMT]]></title><description><![CDATA[<p dir="auto">Great, glad u got it working :D</p>
]]></description><link>https://forum.magicmirror.builders/post/24639</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24639</guid><dc:creator><![CDATA[Kimzer]]></dc:creator><pubDate>Thu, 29 Jun 2017 04:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Wed, 28 Jun 2017 21:41:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kimzer" aria-label="Profile: Kimzer">@<bdi>Kimzer</bdi></a> Thanks for your quick replies. I deleted the Wunderlist and the enhanced Wunderlist folders/modules. Then created the Wunderlist folder again, then did npm install and this seems to have resolved the issue, must of been a problem with the Module.</p>
]]></description><link>https://forum.magicmirror.builders/post/24626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24626</guid><dc:creator><![CDATA[NathTheDude]]></dc:creator><pubDate>Wed, 28 Jun 2017 21:41:44 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Wed, 28 Jun 2017 20:00:26 GMT]]></title><description><![CDATA[<p dir="auto">Post some of ur config.js so we can see if there is a problem.<br />
With the module causing problems in ofcorse.</p>
]]></description><link>https://forum.magicmirror.builders/post/24621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24621</guid><dc:creator><![CDATA[Kimzer]]></dc:creator><pubDate>Wed, 28 Jun 2017 20:00:26 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Wed, 28 Jun 2017 19:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kimzer" aria-label="Profile: Kimzer">@<bdi>Kimzer</bdi></a> Hmmmm, maybe. From the times I have missed/messed up config if normally comes up with something like …missing config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/24620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24620</guid><dc:creator><![CDATA[NathTheDude]]></dc:creator><pubDate>Wed, 28 Jun 2017 19:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Wunderlist, blank screen when Wunderlist module is added to config.js on Wed, 28 Jun 2017 19:55:10 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you are missing a semicolon somewhere :)</p>
]]></description><link>https://forum.magicmirror.builders/post/24619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24619</guid><dc:creator><![CDATA[Kimzer]]></dc:creator><pubDate>Wed, 28 Jun 2017 19:55:10 GMT</pubDate></item></channel></rss>
