<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MIRASTAR 6mm Mirror : a good choice ?]]></title><description><![CDATA[<p dir="auto">I found this type of mirror : MIRASTAR</p>
<p dir="auto">Do you have expérience and advice ?</p>
<p dir="auto">Thankx,</p>
<p dir="auto">SGG MIRASTAR<br />
Product information<br />
Technical information<br />
PROCESSING CAPABILITIES<br />
In principle, the coating of SGG MIRASTAR can be thermally toughened*, even on the pulley roll side. Chromium mirror glass can therefore be converted to toughened glass, giving it a huge advantage over conventional silvered mirrors!<br />
Wet treatment and surface processing (grinding, drilling, engraving or screen printing) are possible as well as its fabrication to laminated safety glass.<br />
The coatings are applied using a magnetron process. Their scratch resistance and hardness are however equivalent to pyrolytic hard coatings.<br />
The glass has passed the following tests:<br />
Taber test<br />
Erichsen test<br />
Condensation resistance<br />
Acid water resistance<br />
Resistance to neutral salt spray<br />
Reflectance: coating side: ≥ 58 %**<br />
Transmission: 3 %**</p>
<ul>
<li>Radiation and convection heaters are suitable for these applications. Please contact the manufacturers of SGG MIRASTAR.<br />
** +/- 1 %<br />
Please ensure that SGG MIRASTAR is only used for its intended purpose. In case of doubt please contact the manufacturer directly.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/4301/mirastar-6mm-mirror-a-good-choice</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 05:12:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4301.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jul 2017 06:56:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MIRASTAR 6mm Mirror : a good choice ? on Mon, 24 Mar 2025 08:29:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acdacd2" aria-label="Profile: acdacd2">@<bdi>acdacd2</bdi></a> Hi! I just found a quote for this product from a local supplier. I was wondering if you (or anyone else here) had experience with it.</p>
]]></description><link>https://forum.magicmirror.builders/post/125183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125183</guid><dc:creator><![CDATA[danybony]]></dc:creator><pubDate>Mon, 24 Mar 2025 08:29:26 GMT</pubDate></item></channel></rss>
