<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror² v2.1.2: Wrong calendar timeFormat after update]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’ve updated my mirror to MagicMirror² v2.1.2. I’m working with the 24 timeFormat, but my events seems to be in 12. The following event is at 16:30, not 04:30. I created some test-events. It’s the same problem with them. Before I updated, everything was fine.</p>
<p dir="auto"><img src="/assets/uploads/files/1499190532390-c2807b80-9c74-43f5-96d6-048cc3e41fe9-image.png" alt="0_1499190533769_c2807b80-9c74-43f5-96d6-048cc3e41fe9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Anyone else with this problem?</p>
<p dir="auto">Regards<br />
Maurice</p>
]]></description><link>https://forum.magicmirror.builders/topic/4306/magicmirror-v2-1-2-wrong-calendar-timeformat-after-update</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 10:47:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4306.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jul 2017 17:50:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Thu, 24 Aug 2017 20:02:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/randomnoise" aria-label="Profile: randomnoise">@<bdi>randomnoise</bdi></a> Great! Thank you, now it works as intended  again   :)</p>
]]></description><link>https://forum.magicmirror.builders/post/26988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26988</guid><dc:creator><![CDATA[FallandeGubbe]]></dc:creator><pubDate>Thu, 24 Aug 2017 20:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Thu, 24 Aug 2017 19:50:55 GMT]]></title><description><![CDATA[<p dir="auto">Edit your calendar.js</p>
<p dir="auto">Find the bit that says-<br />
longDateFormat<br />
Change LT: “hh:mm”<br />
To<br />
LT: “HH:mm”</p>
]]></description><link>https://forum.magicmirror.builders/post/26987</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26987</guid><dc:creator><![CDATA[randomnoise]]></dc:creator><pubDate>Thu, 24 Aug 2017 19:50:55 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Thu, 24 Aug 2017 19:34:27 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue.</p>
<p dir="auto">A noob question: how do I “hotfix” if I don’t want to wait for update?</p>
]]></description><link>https://forum.magicmirror.builders/post/26986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26986</guid><dc:creator><![CDATA[FallandeGubbe]]></dc:creator><pubDate>Thu, 24 Aug 2017 19:34:27 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Tue, 18 Jul 2017 07:48:44 GMT]]></title><description><![CDATA[<p dir="auto">Ah, I see. Thank you! There is a commit, too. I’ll wait for the update!</p>
]]></description><link>https://forum.magicmirror.builders/post/25467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25467</guid><dc:creator><![CDATA[djsunrise19]]></dc:creator><pubDate>Tue, 18 Jul 2017 07:48:44 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Sun, 09 Jul 2017 09:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsunrise19" aria-label="Profile: djsunrise19">@<bdi>djsunrise19</bdi></a> You can hotfix it yourself if you want: <a href="https://github.com/MichMich/MagicMirror/issues/940#issuecomment-313907110" target="_blank" rel="noopener noreferrer nofollow ugc">Github Issue</a></p>
]]></description><link>https://forum.magicmirror.builders/post/25103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25103</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Sun, 09 Jul 2017 09:22:45 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror² v2.1.2: Wrong calendar timeFormat after update on Sat, 08 Jul 2017 11:25:27 GMT]]></title><description><![CDATA[<p dir="auto">Nobody else?</p>
]]></description><link>https://forum.magicmirror.builders/post/25086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25086</guid><dc:creator><![CDATA[djsunrise19]]></dc:creator><pubDate>Sat, 08 Jul 2017 11:25:27 GMT</pubDate></item></channel></rss>
