<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Calender using ics file from a path on pi.]]></title><description><![CDATA[<p dir="auto">How do i use default calender using my own .ics file from outlook.?<br />
the ics file is saved at a location on pi.<br />
what config parameter needs to edited in order to point default calender to use the ics file.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4309/default-calender-using-ics-file-from-a-path-on-pi</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:50:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4309.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jul 2017 06:20:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Calender using ics file from a path on pi. on Wed, 05 Jul 2017 14:47:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arifms" aria-label="Profile: arifms">@<bdi>arifms</bdi></a></p>
<p dir="auto">This page shows all the config options. “Show Location” is NOT one of them.</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar</a></p>
]]></description><link>https://forum.magicmirror.builders/post/24879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24879</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 05 Jul 2017 14:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calender using ics file from a path on pi. on Wed, 05 Jul 2017 12:13:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arifms" aria-label="Profile: arifms">@<bdi>arifms</bdi></a> said in <a href="/post/24855">Default Calender using ics file from a path on pi.</a>:</p>
<p dir="auto">Update:!!<br />
I have managed to get the my ics file for the calendar module. and is working as required.<br />
however i’m unable to see the location of the event. what is the config parameter to get this?</p>
]]></description><link>https://forum.magicmirror.builders/post/24868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24868</guid><dc:creator><![CDATA[arifms]]></dc:creator><pubDate>Wed, 05 Jul 2017 12:13:46 GMT</pubDate></item></channel></rss>
