<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Frameless Illuminated Motion Sensitive SmartMirror]]></title><description><![CDATA[<p dir="auto">Hey</p>
<p dir="auto">I want to show you my smartmirror powered by Magic Mirror.</p>
<p dir="auto">I made a Video to show it to you in action.<br />
<a href="https://youtu.be/ElkHCLMMAxU" target="_blank" rel="noopener noreferrer nofollow ugc">Video</a></p>
<p dir="auto"><em>Let me know what you think!</em></p>
<hr />
<h1>Some more Details:</h1>
<p dir="auto"><img src="http://i.imgur.com/wKtW91N.jpg" alt="front of mirror turned on picture 1" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i.imgur.com/cHQfIKI.jpg" alt="front of mirror turned on picture 2" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto">The mirror’s measurements are 80cm x 55cm. While the ones of the frame are 70cm x 45cm. So that the mirror glas juts out the frame by 5cm on each side. It has a thickness of 6mm.<br />
I got the mirror from a  <a href="https://www.glas-schaefers.de/" target="_blank" rel="noopener noreferrer nofollow ugc">glazier </a> around my town. Unfortunately it is a german contact. On the delivery note it was mentioned as <code>ESG Mirastar-Spionspiegel</code> (Spionspiegel = “two way mirror”).</p>
<p dir="auto">I built the “frame” by myself. Actually it is rather a box than a frame. When standing in front of the mirror you won’t be able to see it.</p>
<p dir="auto"><img src="http://i.imgur.com/pSTlzKT.jpg" alt="early stage mirror frame front" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i.imgur.com/hwSvHqU.jpg" alt="early stage mirror frame back" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto">I attached the 21" monitor to the frame.<br />
The frame is attached to the mirror.<br />
I used a special double-sided tape to fix the mirror to the frame.</p>
<p dir="auto"><img src="http://i.imgur.com/20HICSH.jpg" alt="attaching monitor 1" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto">In the picture below you can see that the tape is transparent.<br />
I chose that one, because if it was a white one it could reflect light and it may be seen when you stand in front of the mirror. Therefore the box is also painted black.<br />
<img src="http://i.imgur.com/V9lp5Ph.jpg" alt="attaching monitor 2" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/4337/frameless-illuminated-motion-sensitive-smartmirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 00:09:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4337.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Jul 2017 23:33:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Tue, 11 Jul 2017 14:10:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pascal456" aria-label="Profile: pascal456">@<bdi>pascal456</bdi></a> Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/25213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25213</guid><dc:creator><![CDATA[PtrBld]]></dc:creator><pubDate>Tue, 11 Jul 2017 14:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Tue, 11 Jul 2017 11:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ptrbld" aria-label="Profile: PtrBld">@<bdi>PtrBld</bdi></a> Hi and thanks!</p>
<p dir="auto">I will update the original post regarding that information!</p>
]]></description><link>https://forum.magicmirror.builders/post/25207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25207</guid><dc:creator><![CDATA[pascal456]]></dc:creator><pubDate>Tue, 11 Jul 2017 11:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Tue, 11 Jul 2017 11:47:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Thank You!</p>
]]></description><link>https://forum.magicmirror.builders/post/25206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25206</guid><dc:creator><![CDATA[pascal456]]></dc:creator><pubDate>Tue, 11 Jul 2017 11:47:33 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Tue, 11 Jul 2017 08:47:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/pascal456" aria-label="Profile: pascal456">@<bdi>pascal456</bdi></a>,<br />
this looks really great! Could you tell me where you got your mirror from?</p>
]]></description><link>https://forum.magicmirror.builders/post/25201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25201</guid><dc:creator><![CDATA[PtrBld]]></dc:creator><pubDate>Tue, 11 Jul 2017 08:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Mon, 10 Jul 2017 22:08:19 GMT]]></title><description><![CDATA[<p dir="auto">Very nicely done!</p>
]]></description><link>https://forum.magicmirror.builders/post/25173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25173</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 10 Jul 2017 22:08:19 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Mon, 10 Jul 2017 18:14:19 GMT]]></title><description><![CDATA[<p dir="auto">After I put the mirror glas onto the frame, I turned it around, took it by the frame and shook it as hard as it was possible. Nothing happened :D</p>
<p dir="auto">Like you can see in the video in the <a href="https://www.hornbach.de/shop/ROXOLID-Montageband-transparent-19-mm-x-5-m/5722602/artikel.html" target="_blank" rel="noopener noreferrer nofollow ugc">product description</a> (unfortunately it is in german) of the tape that i used, they fixed more than a 10kg weight to a wall. Actually the mirror glas has a relatively minor weight of about 6.5kg ;) AND I used about 20 times as much of the tape, like they did in the video.</p>
<p dir="auto">I was more worried about the screws that i used to fix the mounting of the frame. :D</p>
]]></description><link>https://forum.magicmirror.builders/post/25165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25165</guid><dc:creator><![CDATA[pascal456]]></dc:creator><pubDate>Mon, 10 Jul 2017 18:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Mon, 10 Jul 2017 15:15:01 GMT]]></title><description><![CDATA[<p dir="auto">Very nice! I’m also a bit concerned about how well the tape would hold the glass. Aren’t you afraid that it might fall at some point? Or does it seam really solid?</p>
]]></description><link>https://forum.magicmirror.builders/post/25163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25163</guid><dc:creator><![CDATA[vincem92]]></dc:creator><pubDate>Mon, 10 Jul 2017 15:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Mon, 10 Jul 2017 12:19:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pascal456" aria-label="Profile: pascal456">@<bdi>pascal456</bdi></a> Thank you. I find your build process intriguing.</p>
<p dir="auto">Do you have any concerns about the adhesion of the glass and the tape? I suppose I don’t know much about frameless mirrors. I have no idea how commercial mirrors are constructed.</p>
]]></description><link>https://forum.magicmirror.builders/post/25151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25151</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 10 Jul 2017 12:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Fri, 07 Jul 2017 21:57:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi and thanks!!<br />
I actually do not have something like a build log. But I will post some more pics here.</p>
]]></description><link>https://forum.magicmirror.builders/post/25070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25070</guid><dc:creator><![CDATA[pascal456]]></dc:creator><pubDate>Fri, 07 Jul 2017 21:57:13 GMT</pubDate></item><item><title><![CDATA[Reply to Frameless Illuminated Motion Sensitive SmartMirror on Fri, 07 Jul 2017 00:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pascal456" aria-label="Profile: pascal456">@<bdi>pascal456</bdi></a> That looks awesome! Do you have a build log? Or pictures of the back? What are you using to attach the mirror to the monitor?</p>
]]></description><link>https://forum.magicmirror.builders/post/24958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/24958</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 07 Jul 2017 00:14:35 GMT</pubDate></item></channel></rss>
