<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Remote-Control is disabling MMM-scrobbler?]]></title><description><![CDATA[<p dir="auto">When I’m using the Remote Control module, after a little while it will automatically turn off my MMM-Scrobbler (connected to Spotify) module. Rebooting doesn’t fix anything. Disabling the Remote module will restore the Scrobbler.</p>
<p dir="auto">This has happened twice now; I fixed it the first time by just completely re-installing the Remote module, but now it’s persistently happening. Does anyone know what might be causing this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/4412/mmm-remote-control-is-disabling-mmm-scrobbler</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:04:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4412.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Jul 2017 01:57:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Remote-Control is disabling MMM-scrobbler? on Sun, 09 Jul 2017 10:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/malicious_banjo" aria-label="Profile: malicious_banjo">@<bdi>malicious_banjo</bdi></a> Have you used the Hide/Show functionality of the remote control module? Please try deleting <code>settings.json</code> in the remote control module directory. Do you have other modules hiding and showing modules, such as ProfileSwitcher or FaceRecognition?</p>
]]></description><link>https://forum.magicmirror.builders/post/25104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25104</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Sun, 09 Jul 2017 10:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control is disabling MMM-scrobbler? on Sat, 08 Jul 2017 14:16:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/malicious_banjo" aria-label="Profile: malicious_banjo">@<bdi>malicious_banjo</bdi></a> I’ve experienced a somewhat similar issue after sending a command via RemoteControl. Somehow, this command got stuck in the networking queue or whatever and was received periodically again and again.<br />
If you didn’t send any command before, then this is surely something different.<br />
(If you sent a command to disable other modules than Scrobbler, it may still be the same issue, if you also mess with the order of modules by for example deleting modules)</p>
]]></description><link>https://forum.magicmirror.builders/post/25090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25090</guid><dc:creator><![CDATA[Anhalter42]]></dc:creator><pubDate>Sat, 08 Jul 2017 14:16:49 GMT</pubDate></item></channel></rss>
