<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3.]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I’m having trouble to get my PM2 to work on my RPI 2.<br />
I’ve installed PM2 through the MM installation:<br />
“curl -sL <a href="https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh</a> | bash”<br />
Everything is installed without any errors.</p>
<p dir="auto">Here’s the problem.</p>
<p dir="auto">When i do this on my RPI 3 it works just fine! MM starts at bootup and everything works as it should.</p>
<p dir="auto">BUT! When i do the exact same thing on my RPI 2 it do not work?<br />
When i restart the RPI 2 nothing happens… PM2 dosen’t boot.<br />
I’ve tired to install PM2 afterwards but no difference.</p>
<p dir="auto">Do anybody have any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/4499/pm2-do-not-start-at-bootup-on-my-rpi-2-works-fine-on-my-rpi-3</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 08:54:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4499.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jul 2017 12:44:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Thu, 20 Jul 2017 17:47:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
I tried this but somehow the RPI 2 didn’t boot up with pm2. Worked just fine with my RPI 3.</p>
]]></description><link>https://forum.magicmirror.builders/post/25567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25567</guid><dc:creator><![CDATA[tomyboy96]]></dc:creator><pubDate>Thu, 20 Jul 2017 17:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Thu, 20 Jul 2017 15:29:41 GMT]]></title><description><![CDATA[<p dir="auto">I know you have a solution and all, but PM2 should already be running on your Pi as part of the installation process.</p>
<p dir="auto">Did you save your PM2 state before reboot? If you’re willing to experiment, remove the PM2 commands from your crontab and reboot your mirror. Once it’s back up, start the mirror with <code>pm2 start mm</code>, wait for the interface to appear and then enter <code>pm2 save</code>.</p>
<p dir="auto">Once PM2 has saved the state, reboot your mirror and MM2 should start after a few seconds.</p>
]]></description><link>https://forum.magicmirror.builders/post/25550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25550</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 20 Jul 2017 15:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 14:05:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/baxer" aria-label="Profile: Baxer">@<bdi>Baxer</bdi></a> Worked! Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/25511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25511</guid><dc:creator><![CDATA[tomyboy96]]></dc:creator><pubDate>Wed, 19 Jul 2017 14:05:45 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 13:56:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomyboy96" aria-label="Profile: tomyboy96">@<bdi>tomyboy96</bdi></a> said in <a href="/post/25509">PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3.</a>:</p>
<p dir="auto">errors in crontab file, can’t install.</p>
<p dir="auto">do you have the @reboot before pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> if you dont try with that</p>
]]></description><link>https://forum.magicmirror.builders/post/25510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25510</guid><dc:creator><![CDATA[Baxer]]></dc:creator><pubDate>Wed, 19 Jul 2017 13:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 13:46:56 GMT]]></title><description><![CDATA[<p dir="auto">When trying to save this error shows up:</p>
<p dir="auto">“/tmp/crontab.gpsLPh/crontab”:22: bad time specifier<br />
errors in crontab file, can’t install.<br />
Do you want to retry the same edit? (y/n)</p>
]]></description><link>https://forum.magicmirror.builders/post/25509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25509</guid><dc:creator><![CDATA[tomyboy96]]></dc:creator><pubDate>Wed, 19 Jul 2017 13:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 13:34:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomyboy96" aria-label="Profile: tomyboy96">@<bdi>tomyboy96</bdi></a> test with pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> in crontab -e then and see if that works</p>
]]></description><link>https://forum.magicmirror.builders/post/25508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25508</guid><dc:creator><![CDATA[Baxer]]></dc:creator><pubDate>Wed, 19 Jul 2017 13:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 13:26:14 GMT]]></title><description><![CDATA[<p dir="auto">Did not work…</p>
<p dir="auto">only way to get PM2 to start is by using:</p>
<p dir="auto">pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
]]></description><link>https://forum.magicmirror.builders/post/25507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25507</guid><dc:creator><![CDATA[tomyboy96]]></dc:creator><pubDate>Wed, 19 Jul 2017 13:26:14 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 do not start at bootup on my RPI 2? Works fine on my RPI 3. on Wed, 19 Jul 2017 13:09:21 GMT]]></title><description><![CDATA[<p dir="auto">have you put pm2 start mm in crontab? if you havent you can do so with<br />
crontab -e then type <strong>@reboot pm2 start mm</strong> at the end of the file then restart it to test</p>
]]></description><link>https://forum.magicmirror.builders/post/25505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25505</guid><dc:creator><![CDATA[Baxer]]></dc:creator><pubDate>Wed, 19 Jul 2017 13:09:21 GMT</pubDate></item></channel></rss>
