<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blackscreen with config.js.sample]]></title><description><![CDATA[<p dir="auto">Like the topics says I am getting blackscreen with the sampls config. I do not get any errors while starting. but the screen stays black. I am running Ubuntu 17 in Virtualbox.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4512/blackscreen-with-config-js-sample</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:09:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4512.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Jul 2017 22:26:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blackscreen with config.js.sample on Fri, 21 Jul 2017 01:04:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ma5k" aria-label="Profile: MA5K">@<bdi>MA5K</bdi></a></p>
<p dir="auto">All’s well that ends well, as the saying goes.</p>
<p dir="auto">Enjoy your mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/25587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25587</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 21 Jul 2017 01:04:06 GMT</pubDate></item><item><title><![CDATA[Reply to Blackscreen with config.js.sample on Fri, 21 Jul 2017 00:35:24 GMT]]></title><description><![CDATA[<p dir="auto">I figured out that while performing “npm install” some warnings like :<br />
Colorguard (and 2 others) shoud be installed with install -g or so.</p>
<p dir="auto">I tried this ans after retrieing with sudo privs it worked.</p>
<p dir="auto">Now everything is running smooth.</p>
<p dir="auto">But thx for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/25586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25586</guid><dc:creator><![CDATA[MA5K]]></dc:creator><pubDate>Fri, 21 Jul 2017 00:35:24 GMT</pubDate></item><item><title><![CDATA[Reply to Blackscreen with config.js.sample on Thu, 20 Jul 2017 22:39:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ma5k" aria-label="Profile: MA5K">@<bdi>MA5K</bdi></a> said in <a href="/post/25580">Blackscreen with config.js.sample</a>:</p>
<p dir="auto">I can test your config for you. Post it here using these guidelines unless you already know how to fence a code block.</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners">https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners</a></p>
<p dir="auto">I’m assuming your made a copy of the config.js.sample and renamed the copy to <code>config.js</code></p>
]]></description><link>https://forum.magicmirror.builders/post/25581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25581</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 20 Jul 2017 22:39:57 GMT</pubDate></item></channel></rss>
