<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[stronger Raspberry Pi 3 Alternatives]]></title><description><![CDATA[<p dir="auto">Several modules like the ones for face recognition, speech recognition or even streaming from webcams bring  the Raspberry Pi 3 to it’s performance limits by max out it’s memory and cpu. I found some older topics where several alternatives where named. Unfortunately those post were abandoned  like half a year ago and really hard to read, due to the overlapping conversations.</p>
<p dir="auto">I really want to find a powerful alternative to the Pi3. Perhaps the experienced builders can briefly share what they have done for experience with your alternatives. I think the following criteria are interesting.</p>
<p dir="auto">Everybody else please don’t forget to <strong>up vote</strong> the contributions of those who share.</p>
<h1>Model: Raspberry Pi 3 Model B</h1>
<p dir="auto"><img src="/assets/uploads/files/1500588785679-desi2003_a.png" alt="0_1500588784360_Desi2003_a.png" class=" img-fluid img-markdown" /></p>
<h4>Price</h4>
<ul>
<li>Board - 35 $</li>
<li>Power Supply (mini USB) -  5 $</li>
</ul>
<p dir="auto">in Total: about 40 $</p>
<h4>Dimensions</h4>
<p dir="auto">85.60mm x 56mm x 21mm</p>
<p dir="auto"><img src="/assets/uploads/files/1500589689718-rasp3_dimensions.png" alt="0_1500589688029_rasp3_dimensions.png" class=" img-fluid img-markdown" /></p>
<h4>Hardware Specifications</h4>
<ul>
<li>CPU: Quad Core <strong>1.2GHz</strong> Broadcom BCM2837 <strong>64bit</strong> CPU</li>
<li>Memory: <strong>1GB RAM</strong></li>
<li>WLAN: BCM43438 <strong>wireless LAN</strong> and Bluetooth Low Energy (BLE) on board</li>
<li>GPIO Pins::  40-pin extended</li>
<li>USB: <strong>4x USB 2.0 ports</strong></li>
<li>Video &amp; Stereo output:  4 Pole stereo output and composite video port</li>
<li>Full size <strong>HDMI</strong></li>
<li>CSI <strong>camera port</strong> for connecting a Raspberry Pi camera</li>
<li>DSI <strong>display port</strong> for connecting a Raspberry Pi touchscreen display</li>
<li><strong>Micro SD</strong> port for loading your operating system and storing data</li>
<li>Upgraded switched Micro USB power source up to 2.5A</li>
</ul>
<h4>Software:</h4>
<p dir="auto">OS: <a href="https://www.raspberrypi.org/downloads/raspbian/" target="_blank" rel="noopener noreferrer nofollow ugc">Raspian</a><br />
Is able to run:</p>
<ul>
<li>NodeJS - yes</li>
</ul>
<h4>Installation of MM:</h4>
<ul>
<li>Is the standard installation script  executable? - yes</li>
</ul>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)
<h4>Remarks:</h4>
<ul>
<li>Strong spread, big supportive community.</li>
</ul>
<h1>Model: Intel Thin Mini-ITX Motherboard</h1>
<p dir="auto">like <a href="https://www.newegg.com/Product/Product.aspx?Item=N82E16813132833" target="_blank" rel="noopener noreferrer nofollow ugc">ASUS H110T/CSM LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 Thin Mini-ITX Motherboards</a><br />
<img src="/assets/uploads/files/1500631620170-13-132-833-01.jpg" alt="0_1500631618216_13-132-833-01.jpg" class=" img-fluid img-markdown" /></p>
<h4>Price</h4>
<ul>
<li>Board: 80 $</li>
<li><a href="https://www.amazon.com/gp/product/B015HQ9TGW/ref=oh_aui_detailpage_o03_s00?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">Ram</a>: 8 GB - 70 $</li>
<li><a href="https://www.amazon.com/gp/product/B00GUNZUG0/ref=oh_aui_detailpage_o02_s00?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">Wifi Card</a>: 27 $</li>
<li><a href="https://www.newegg.com/Product/Product.aspx?Item=N82E16819117625" target="_blank" rel="noopener noreferrer nofollow ugc">CPU</a>: 56 $</li>
<li><a href="https://www.newegg.com/Product/Product.aspx?Item=N82E16835220067" target="_blank" rel="noopener noreferrer nofollow ugc">Cooler</a>: 20$</li>
<li>SSD: 128GB - 30 $</li>
<li>accepts 12 to 19 Volts Power Supply as for notebooks  -  15 $</li>
</ul>
<p dir="auto">in Total: about 300 $ (depending on components)</p>
<h4>Dimensions</h4>
<p dir="auto">1702mm x 1702 x 25mm</p>
<p dir="auto"><img src="/assets/uploads/files/1500631926547-intel-2.jpg" alt="0_1500631924158_Intel-2.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1500632102968-mmclj.png" alt="0_1500632100859_Mmclj.png" class=" img-fluid img-markdown" /></p>
<ul>
<li>Supported CPU (<em>CPU not included</em>)
<ul>
<li>Socket Type: LGA 1151</li>
<li>CPU Type: **Core i7 / i5 / i3 / Pentium / Celeron (LGA1151)</li>
<li>Supported CPU Technologies:   * Turbo Boost Technology 2.0</li>
</ul>
</li>
<li>Memory (not included)
<ul>
<li>Number of Memory Slots: 2×260pin</li>
<li>Memory Standard: DDR4 2133</li>
<li>Maximum Memory Supported: 32GB</li>
<li>Channel Supported: Dual Channel</li>
</ul>
</li>
<li>Onboard Video:
<ul>
<li>Integrated Graphics Processor</li>
<li>Multi-VGA output support: DP/HDMI/LVDS ports</li>
<li>Supports HDMI with max. resolution of 4096 x 2160 @ 24Hz / 2560 x 1600 @ 60Hz</li>
<li>Supports LVDS with max. resolution of 1920 x 1200 @ 60Hz</li>
<li>Supports DisplayPort with max. resolution of 4096 x 2304 @ 60 Hz</li>
<li>Maximum shared memory of 1024MB</li>
</ul>
</li>
<li>WLAN: only by using expansion Slot for 1 x M.2 Socket 1 with E key, type 2230 for WIFI device</li>
<li>LAN: Dual 10/100/1000Mbps with Realtek 8111H</li>
<li>GPIO Pins:  <strong>no</strong></li>
<li>Rear Panel Ports
<ul>
<li>1 x HDMI</li>
<li>2 x RJ45</li>
<li>1 x DisplayPort</li>
<li>4 x USB 3.0</li>
<li>2 Audio Ports</li>
</ul>
</li>
<li>Onboard USB:
<ul>
<li>2 x USB 2.0 2-port connectors support additional 4 USB 2.0 ports</li>
<li>1 x USB 2.0 1-port connectors support additional 1 USB 2.0 port</li>
</ul>
</li>
</ul>
<h4>Software:</h4>
<p dir="auto">Operating System Support:</p>
<ul>
<li>Unbuntu</li>
<li>Windows 10*</li>
<li>Windows 8.1*</li>
<li>Windows 7</li>
<li>64-bit supported only</li>
</ul>
<p dir="auto">Is able to run:</p>
<ul>
</ul>
<ul>
</ul>
<h4>Remarks:</h4>
<ul>
<li>Powerfull Board with several upgrading capabilities which comes with a bigger pice tag</li>
<li>Quotes:
<ul>
<li>“So things like @strawberry-3-141 voice module is REALLY fast and responsive. I’m also using an IR touch frame that responds quite well with no additional drivers needed.”</li>
</ul>
</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/4513/stronger-raspberry-pi-3-alternatives</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 17:18:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4513.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Jul 2017 22:40:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 20:36:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> said in <a href="/post/34158">stronger Raspberry Pi 3 Alternatives</a>:</p>
<p dir="auto">Does anyone know if it would be possible to use MagicMirror on a x86 system and uses external GPIOs?</p>
<p dir="auto">Well, it’s certainly possible to run MM on a x86 system. I haven’t a clue about external GPIO usage but it looks promising. For now, I use my mirror for some things and my Alexa for everything else.</p>
]]></description><link>https://forum.magicmirror.builders/post/34171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34171</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 17 Jan 2018 20:36:44 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 19:03:59 GMT]]></title><description><![CDATA[<p dir="auto">Well, adafruit has python sample code. You likely need the node FT232H module to use it from JS.</p>
<p dir="auto"><a href="https://www.npmjs.com/package/FT232H" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.npmjs.com/package/FT232H</a></p>
<p dir="auto">Does it actually work - I have no idea - that board is also apparently out of stock :-)</p>
<p dir="auto">Sample python code below</p>
<pre><code># Import standard Python time library.
import time
# Import GPIO and FT232H modules.
import Adafruit_GPIO as GPIO
import Adafruit_GPIO.FT232H as FT232H
# Temporarily disable the built-in FTDI serial driver on Mac &amp; Linux platforms.
FT232H.use_FT232H()
# Create an FT232H object that grabs the first available FT232H device found.
ft232h = FT232H.FT232H()
# Configure digital inputs and outputs using the setup function.
# Note that pin numbers 0 to 15 map to pins D0 to D7 then C0 to C7 on the board.
ft232h.setup(7, GPIO.IN)   # Make pin D7 a digital input.
ft232h.setup(8, GPIO.OUT)  # Make pin C0 a digital output.
# Loop turning the LED on and off and reading the input state.
print 'Press Ctrl-C to quit.'
while True:
	# Set pin C0 to a high level so the LED turns on.
	ft232h.output(8, GPIO.HIGH)
	# Sleep for 1 second.
	time.sleep(1)
	# Set pin C0 to a low level so the LED turns off.
	ft232h.output(8, GPIO.LOW)
	time.sleep(1)
	# Read the input on pin D7 and print out if it's high or low.
	level = ft232h.input(7)
	if level == GPIO.LOW:
		print 'Pin D7 is LOW!'
	else:
		print 'Pin D7 is HIGH!'
]]></description><link>https://forum.magicmirror.builders/post/34164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34164</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Wed, 17 Jan 2018 19:03:59 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 19:02:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/emlowe" aria-label="Profile: emlowe">@<bdi>emlowe</bdi></a> said in <a href="/post/34161">stronger Raspberry Pi 3 Alternatives</a>:</p>
<p dir="auto"><a href="https://www.adafruit.com/product/2264" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.adafruit.com/product/2264</a></p>
<p dir="auto">do you think its just that simple? that would be great.<br />
The question is, if the program code or the configuration will be the same as on a RPi. Or are u need to do some complicated hacks to use the board with MM?</p>
<p dir="auto">edit:<br />
okay… i searched now, too.</p>
<p dir="auto">Found this:</p>
<p dir="auto"><a href="https://www.raspberrypi.org/blog/gpio-expander/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/blog/gpio-expander/</a></p>
<p dir="auto">what do u guys think about that?</p>
]]></description><link>https://forum.magicmirror.builders/post/34163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34163</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Wed, 17 Jan 2018 19:02:04 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 18:43:38 GMT]]></title><description><![CDATA[<p dir="auto">You mean something like this:</p>
<p dir="auto">I just did a google for “USB GPIO breakout board”</p>
<p dir="auto">-Earle</p>
]]></description><link>https://forum.magicmirror.builders/post/34161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34161</guid><dc:creator><![CDATA[emlowe]]></dc:creator><pubDate>Wed, 17 Jan 2018 18:43:38 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 18:09:12 GMT]]></title><description><![CDATA[<p dir="auto">Well, i need to say that especially for me, the ability to use GPIOs is important. Unfortunately the power of the raspi’s &amp; co is not as good as x86 systems.</p>
<p dir="auto">Does anyone know if it would be possible to use MagicMirror on a x86 system and uses external GPIOs? I installed an MM instance on a virtual machine running Linux. When i add a module which uses GPIOs i get errors. Is there a possibility (maybe with server-client)</p>
]]></description><link>https://forum.magicmirror.builders/post/34158</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34158</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Wed, 17 Jan 2018 18:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 02:05:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a></p>
<p dir="auto">No, but I’ve used, and am using, old laptop boards (and one netbook) with ubuntu. They can be gotten on the cheap and come with everything you need. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/34118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34118</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 17 Jan 2018 02:05:52 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 02:02:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> The <a href="https://www.pine64.org/?product=usb-wifi-802-11bgn-rtl8188eu-for-rock64" target="_blank" rel="noopener noreferrer nofollow ugc">b/g/n adapter</a> is a further $7, and will also give you an antenna for better connectivity. The more robust (and likely excessive) <a href="https://www.pine64.org/?product=rock64-usb-3-0-dual-band-1200mbps-wifi-802-11abgnac-rtl8812au-adapter" target="_blank" rel="noopener noreferrer nofollow ugc">b/g/n/ac dual-antenna</a> is $22.</p>
<p dir="auto">Has anyone tried running MM on an Intel Compute Stick? I’m not normally a fan, but it seems it would suit the form factor and be easily placed behind a mirror, and has more fulsome specs to accommodate advanced modules, media streaming, etc.</p>
]]></description><link>https://forum.magicmirror.builders/post/34117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34117</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Wed, 17 Jan 2018 02:02:33 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Wed, 17 Jan 2018 00:49:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a></p>
<p dir="auto">No WiFi? NFW!</p>
]]></description><link>https://forum.magicmirror.builders/post/34112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34112</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 17 Jan 2018 00:49:11 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Tue, 16 Jan 2018 13:33:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto"><a href="https://youtu.be/FjbzKfeHB_8?t=8m10s" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/FjbzKfeHB_8?t=8m10s</a></p>
<p dir="auto">As i understood, u were able to use GPIO commands the same way u do on a raspberry. Seems to be a nice option</p>
<p dir="auto">Benchmarks at 08:10</p>
]]></description><link>https://forum.magicmirror.builders/post/34066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34066</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Tue, 16 Jan 2018 13:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sun, 08 Oct 2017 00:44:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stacywebb" aria-label="Profile: stacywebb">@<bdi>stacywebb</bdi></a> said in <a href="/post/29113">stronger Raspberry Pi 3 Alternatives</a>:</p>
<p dir="auto">I haven’t done any benchmarking as of yet. Once I do, I’ll post the results.</p>
<p dir="auto">If you could do some comparisons using nmon between a Pi3 and the Rock64 I’d really be interested in the results, as they pertain to this topic.<br />
<a href="https://forum.magicmirror.builders/topic/4684/electron-cpu-usage">https://forum.magicmirror.builders/topic/4684/electron-cpu-usage</a></p>
<p dir="auto">Otherwise, I’m looking forward to your results on the Rock64.</p>
]]></description><link>https://forum.magicmirror.builders/post/29115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29115</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 08 Oct 2017 00:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sun, 08 Oct 2017 00:06:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/29113</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29113</guid><dc:creator><![CDATA[stacywebb]]></dc:creator><pubDate>Sun, 08 Oct 2017 00:06:06 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sat, 07 Oct 2017 13:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stacywebb" aria-label="Profile: stacywebb">@<bdi>stacywebb</bdi></a> Thank you! I’ll try it out as soon as I got some time. Have you compared with a Pi3?</p>
]]></description><link>https://forum.magicmirror.builders/post/29099</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29099</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Sat, 07 Oct 2017 13:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sat, 07 Oct 2017 07:01:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a><br />
I’ve gotten it working a Pine Rock64 (arm64 also).</p>
<p dir="auto">Downloaded <a href="https://www.hamidx9.ir/dl/electron_arm64/electron-v1.7.5-linux-arm64.zip" target="_blank" rel="noopener noreferrer nofollow ugc">electron-v1.7.5-linux-arm64.zip</a> listed under electron’s <a href="https://github.com/electron/electron/pull/10205" target="_blank" rel="noopener noreferrer nofollow ugc">PR</a></p>
<p dir="auto">One thing to note:  when downloading from the link, the site’s cert has expired.</p>
<p dir="auto">From terminal:</p>
<pre><code>// Since the cert for the site has expired (but is safe)
wget --no-check-certificate https://www.hamidx9.ir/dl/electron_arm64/electron-v1.7.5-linux-arm64.zip
// Important make sure to unzip to your electron path
unzip electron-v1.7.5-linux-arm64.zip ~/MagicMirror/node_modules/electron/dist/
<p dir="auto">Once done just started as usual (<em>npm start</em>).</p>
]]></description><link>https://forum.magicmirror.builders/post/29097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29097</guid><dc:creator><![CDATA[stacywebb]]></dc:creator><pubDate>Sat, 07 Oct 2017 07:01:36 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Fri, 06 Oct 2017 12:22:22 GMT]]></title><description><![CDATA[<p dir="auto">All, I have got the Libre Computer now. Trying my best to get the mirror up. Ran in to a small hitch. There is no chromedriver  for arm64 yet. They are <a href="https://github.com/electron/electron/issues/5706" target="_blank" rel="noopener noreferrer nofollow ugc">working</a> on it and there is a <a href="https://github.com/vielmetti/worksonarm-news/issues/63" target="_blank" rel="noopener noreferrer nofollow ugc">PR</a> but it has not yet gone completely through it seems. I’ll see if I can figure it out some how anyway. :)</p>
<p dir="auto">I’ll come back to this thread as soon as I gotten MM up and running.</p>
]]></description><link>https://forum.magicmirror.builders/post/29076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29076</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Fri, 06 Oct 2017 12:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sun, 03 Sep 2017 16:11:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> No it will be underneath as I’m building into a type of desk/cabinet</p>
]]></description><link>https://forum.magicmirror.builders/post/27560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27560</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 03 Sep 2017 16:11:55 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Sun, 03 Sep 2017 16:09:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> is the idea that the mini atx sits beside the mirror as opposed to being built? Say on a console table with just an HDMI cable running to the screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/27559</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27559</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 03 Sep 2017 16:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Thu, 31 Aug 2017 00:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> <b>I’m working on it</b> <code>COMING SOON</code></p>
]]></description><link>https://forum.magicmirror.builders/post/27303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27303</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 31 Aug 2017 00:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Thu, 31 Aug 2017 00:21:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/27300">stronger Raspberry Pi 3 Alternatives</a>:</p>
<p dir="auto">Easy to put out of the way … NOW to build a frame for the ‘display’</p>
<p dir="auto">Great idea! Now hurry the hell up with the frame! :^)</p>
]]></description><link>https://forum.magicmirror.builders/post/27302</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27302</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 31 Aug 2017 00:21:51 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Thu, 31 Aug 2017 00:20:48 GMT]]></title><description><![CDATA[<p dir="auto">Well here’s step 1 for my big mirror…  I wanted something stronger then a PI so here is my mini-itx in its new home… Cooling is NOT an issue… it’s about 13" square and about 3 inches tall :)  Easy to put out of the way … NOW to build a frame for the ‘display’…  Coming soon!</p>
<p dir="auto"><img src="/assets/uploads/files/1504138494377-img_2879.png" alt="0_1504138490290_IMG_2879.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">HERE is how it all stays cool…this fan is totally SILENT… LOVE IT!<br />
<a href="https://www.newegg.com/Product/Product.aspx?Item=N82E16835220067" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.newegg.com/Product/Product.aspx?Item=N82E16835220067</a></p>
]]></description><link>https://forum.magicmirror.builders/post/27300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27300</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 31 Aug 2017 00:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Fri, 04 Aug 2017 22:42:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> said in <a href="/post/26194">stronger Raspberry Pi 3 Alternatives</a>:</p>
<p dir="auto">let us know what the noise from the fan is like.</p>
<p dir="auto">My experience with the <a href="https://forum.magicmirror.builders/topic/1588/how-hot-does-it-get/11">fan.</a></p>
<p dir="auto">My thoughts about using a fan:</p>
<p dir="auto">In my case, if there is any form of ambient sound in the room, I don’t hear the fan at all. If the window is open, if the tv or radio is on, anything at all then I can’t hear the fan. I listened for it when I first installed it.</p>
<p dir="auto">When do I hear it? At night, when the windows are closed, tv is off, and the house is absolutely silent. The mirror is not in my bedroom, although that wouldn’t matter. My wife’s snoring can mask the sound of a 747 on liftoff.</p>
]]></description><link>https://forum.magicmirror.builders/post/26205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26205</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 04 Aug 2017 22:42:35 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Fri, 04 Aug 2017 21:16:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> Will do!</p>
]]></description><link>https://forum.magicmirror.builders/post/26201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26201</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 04 Aug 2017 21:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Fri, 04 Aug 2017 16:07:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> When you have it all put together, let us know what the noise from the fan is like.</p>
]]></description><link>https://forum.magicmirror.builders/post/26194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26194</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 04 Aug 2017 16:07:19 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Thu, 03 Aug 2017 22:33:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a>  right now I don’t have it all together so I can’t really answer that question.  BUT it has crossed my mind… so I’m going to run a fan off of the motherboard and run it to the top of the ‘frame’ to get rid of the heat.  If you buy a high quality fan the noise shouldn’t be a problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/26175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26175</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 03 Aug 2017 22:33:33 GMT</pubDate></item><item><title><![CDATA[Reply to stronger Raspberry Pi 3 Alternatives on Thu, 03 Aug 2017 14:07:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> How is the miniATX for heat generation and dissipation when your mirror is hanging up against the wall?  Do you need to use a fan on the cpu or gpu?  My Pi3 already runs in the high 60’s Celcius without a fan (I’m not using face recognition, or this would likely be much worse)… I’d be concerned that the extra power and limited airflow would generate a significant amount of heat, and adding a fan would result in an annoying whirring sound – ideally I’d want the mirror to operate silently.</p>
]]></description><link>https://forum.magicmirror.builders/post/26160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26160</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Thu, 03 Aug 2017 14:07:34 GMT</pubDate></item></channel></rss>
