<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Prefacing birthdays in calendar.]]></title><description><![CDATA[<p dir="auto">I tried, it did not work, but that’s most likely because of something I did or didn’t do.</p>
<p dir="auto">I added it to the custom.css if that’s not right, let me know.</p>
<p dir="auto">Alternatively, is there a way to preface an calendar item with something (or after it for that matter)</p>
<p dir="auto">i.e. Bob Jones and add 's birthday (Bob Jones’s birthday)</p>
<p dir="auto">or BDAY - Bob Jones</p>
<p dir="auto">Is this possible?</p>
<hr />
<p dir="auto"><strong>Note from Admin:</strong> To keep the original post on-topic, I moved your question to a separate post …</p>
]]></description><link>https://forum.magicmirror.builders/topic/455/prefacing-birthdays-in-calendar</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 07:39:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/455.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Aug 2016 19:01:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Prefacing birthdays in calendar. on Wed, 03 Aug 2016 20:07:29 GMT]]></title><description><![CDATA[<p dir="auto">Got it.  OK.  I left it as is and per your note, changed the icons which works well.</p>
<p dir="auto">Now if I can figure out the color thing, it will be “magic”.</p>
<p dir="auto">Brendon</p>
]]></description><link>https://forum.magicmirror.builders/post/3376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3376</guid><dc:creator><![CDATA[bscarano]]></dc:creator><pubDate>Wed, 03 Aug 2016 20:07:29 GMT</pubDate></item><item><title><![CDATA[Reply to Prefacing birthdays in calendar. on Wed, 03 Aug 2016 19:05:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bscarano" aria-label="Profile: bscarano">@<bdi>bscarano</bdi></a> Well, that’s what Facebook does by default. MagicMirror² filters that out. You can change this behavior, by overwriting the <code>titleReplace</code> property. Setting this to <code>titleReplace:{}</code> should disable the feature. See: <a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3373</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Wed, 03 Aug 2016 19:05:47 GMT</pubDate></item></channel></rss>
