<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NOAA - Another Weather Module]]></title><description><![CDATA[<h1>Description:</h1>
<p dir="auto">Built with love by me, <a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a>, with help from <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto">Didn’t plan on releasing this but due to requests here it is…</p>
<p dir="auto">MMM-NOAA - another weather module :)</p>
<p dir="auto"><strong>Currently available in English, Swedish and German flavors… [Please PM me if you’d be interested in making any other translation files for this ].</strong></p>
<p dir="auto">Time/Date<br />
Current weather<br />
current condition<br />
current temp [if above certain temp number turns red]<br />
UV Index [using the UV Index color codes]<br />
Humidity [if above certain % changes number color]<br />
Wind and direction<br />
Barometer [Shows number plus if rising, falling or steady]</p>
<p dir="auto">Sunrise/Sunset times</p>
<p dir="auto">Forecast<br />
Rotates through 10 day forecast [including today]<br />
Expected condition<br />
with high/low temps<br />
expected humidity</p>
<p dir="auto"><strong>Please follow Readme on Github!</strong></p>
<h1>Screenshots:</h1>
<p dir="auto">English<br />
<img src="/assets/uploads/files/1501456862427-en.png" alt="0_1501456861536_en.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Swedish<br />
<img src="/assets/uploads/files/1501456889514-sv1.png" alt="0_1501456889445_sv1.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1501456893530-sv2.png" alt="0_1501456893050_sv2.png" class=" img-fluid img-markdown" /></p>
<h2>Version 1.0.0</h2>
<h1>Download:</h1>
<p dir="auto">[card:cowboysdude/MMM-NOAA]</p>
]]></description><link>https://forum.magicmirror.builders/topic/4585/mmm-noaa-another-weather-module</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 08:42:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4585.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 30 Jul 2017 23:28:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:41:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i went throu the link you’ve send before.<br />
got the information “missing module request”.<br />
just finished npm install request…all’s working.</p>
<p dir="auto">Great thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/post/96936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96936</guid><dc:creator><![CDATA[n0v4]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:41:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:37:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n0v4" aria-label="Profile: n0v4">@<bdi>n0v4</bdi></a> said in <a href="/post/96934">MMM-NOAA - Another Weather Module</a>:</p>
<p dir="auto">0|MagicMir |   code: ‘MODULE_NOT_FOUND’,</p>
<p dir="auto">so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library</p>
<p dir="auto">–lines=50</p>
]]></description><link>https://forum.magicmirror.builders/post/96935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96935</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:37:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:36:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
sorry…like i’ve said…totally new to the topic.</p>
<p dir="auto">i’m i right:</p>
<p dir="auto">/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:<br />
0|MagicMir |     at require (internal/modules/cjs/helpers.js:88:18)<br />
0|MagicMir |     at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)<br />
0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:1078:30)<br />
0|MagicMir |     at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {<br />
0|MagicMir |   code: ‘MODULE_NOT_FOUND’,<br />
0|MagicMir |   requireStack: [<br />
0|MagicMir |     ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,<br />
0|MagicMir |     ‘/home/pi/MagicMirror/js/app.js’,<br />
0|MagicMir |     ‘/home/pi/MagicMirror/js/electron.js’,<br />
0|MagicMir |     ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
0|MagicMir |     undefined<br />
0|MagicMir |   ]<br />
0|MagicMir | }<br />
0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a></p>
]]></description><link>https://forum.magicmirror.builders/post/96934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96934</guid><dc:creator><![CDATA[n0v4]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:36:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:29:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n0v4" aria-label="Profile: n0v4">@<bdi>n0v4</bdi></a>  the topic posted defined work for you to do</p>
<p dir="auto">when the screen is black, what do the  messages say in the place u start MM.</p>
<p dir="auto">either npm start or<br />
pm2</p>
<p dir="auto">if pm2, then pm2 logs --lines=nnn  show the results (nnn= number, default 15)</p>
]]></description><link>https://forum.magicmirror.builders/post/96933</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96933</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:22:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your link.<br />
but the Mirror is working without the MMM-NOAA-Another Weather Module activated.<br />
As soons as i activate it, the screen stayes black.</p>
<p dir="auto">in the link i couldn’t find any solution.</p>
<p dir="auto">Any other ideas?<br />
Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/96932</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96932</guid><dc:creator><![CDATA[n0v4]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:22:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 22:07:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n0v4" aria-label="Profile: n0v4">@<bdi>n0v4</bdi></a> probably this <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/96931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96931</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 Nov 2021 22:07:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 29 Nov 2021 21:26:14 GMT]]></title><description><![CDATA[<p dir="auto">Dear cowboysdude,</p>
<p dir="auto">thanks a lot for the great Module. I’m trying to implement it.<br />
Just to know…totally new to it.</p>
<p dir="auto">Full install and config added. But now the MagicMirror staies black completally.<br />
When i remove the config information, the Mirror is working nomarlly.</p>
<p dir="auto">Has this to do with the API’s?<br />
Thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/96930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96930</guid><dc:creator><![CDATA[n0v4]]></dc:creator><pubDate>Mon, 29 Nov 2021 21:26:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 22 Nov 2021 23:38:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/msulzer" aria-label="Profile: msulzer">@<bdi>msulzer</bdi></a> Anything is possible LOL   Just go in and edit them out of the getDom section then they can’t show.</p>
<p dir="auto">If you need help let me know.    I can whittle it down for you, PM me ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/96699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96699</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 22 Nov 2021 23:38:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 21 Nov 2021 18:51:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?</p>
]]></description><link>https://forum.magicmirror.builders/post/96627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96627</guid><dc:creator><![CDATA[msulzer]]></dc:creator><pubDate>Sun, 21 Nov 2021 18:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Thu, 13 Aug 2020 19:47:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pielo" aria-label="Profile: Pielo">@<bdi>Pielo</bdi></a> how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt</p>
]]></description><link>https://forum.magicmirror.builders/post/80146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80146</guid><dc:creator><![CDATA[majdzik84]]></dc:creator><pubDate>Thu, 13 Aug 2020 19:47:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 22:39:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> I know. we did it at the same time.</p>
<p dir="auto">was adding info for others</p>
]]></description><link>https://forum.magicmirror.builders/post/79989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79989</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 09 Aug 2020 22:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 22:16:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Yes, I know. I’m using it in my MMM-BMW-OW module. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/79988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79988</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 09 Aug 2020 22:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 22:01:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>  yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api</p>
]]></description><link>https://forum.magicmirror.builders/post/79987</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79987</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 09 Aug 2020 22:01:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 21:52:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a></p>
<p dir="auto">Yes, understood. I’m using my darksky api key until it is no longer valid. Like you, my OpenWeather api key doesn’t show the 4 day forecast. I spoke with the author and he is extremely busy with work so he doesn’t have much time to troubleshoot his modules. You can fork the repo and fix it if you like. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/79986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79986</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 09 Aug 2020 21:52:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 19:48:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Well I tried changing coordinates for our capital city of Poland - Warsaw, but it is still not showing forecast. I also tried to change for weatherbit (previously used openweather) but with weatherbit it doesn’t even show forecast - (Prognoza na 4 dni).</p>
]]></description><link>https://forum.magicmirror.builders/post/79977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79977</guid><dc:creator><![CDATA[Lagmin]]></dc:creator><pubDate>Sun, 09 Aug 2020 19:48:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 14:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a></p>
<p dir="auto">Just spoke with the author. Some of the providers are not supplying the data they once were or they’ve changed the way they provide the data. This module uses several different providers so try another one and see if you get better results.</p>
<p dir="auto">Keeping this module functioning using all the different providers must be a monumental task. It may take a long time for the author to fix any of it, assuming he has the time.</p>
]]></description><link>https://forum.magicmirror.builders/post/79966</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79966</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 09 Aug 2020 14:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sun, 09 Aug 2020 00:31:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a></p>
<p dir="auto">I’m guessing that the data is not complete for all locations so you may not see % for Humidity, inHg for Pressure… or that information is not present in the data (for some reason).</p>
<p dir="auto">How I can translate WIND? I don’t have it in translation file (same for AQI, UV).</p>
<p dir="auto">You can add “Wind” to the translation file of your language and put in the translation. I’ve given an example below. Then send a PR to the author and he will add it to the repo.</p>
<pre><code>"Sun":"Sun",
"No Wind": "No Wind",
"Wind": "Yours",
"Humidity": "Humidity",
]]></description><link>https://forum.magicmirror.builders/post/79944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79944</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 09 Aug 2020 00:31:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Sat, 08 Aug 2020 17:25:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Ok, I got it, it is “working”.<br />
I used this simple config:</p>
<pre><code>   module: 'MMM-NOAA3',
position: 'top_left',
       provider: "must be in quotes", // From list above
       apiKey: "YOUR API KEY",        // From one of the providers listed above
       airKey: "YOUR API KEY",
       css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
   userlat: "xxxx", //MUST HAVE BOTH
       userlon: "xxxx"  //MUST HAVE BOTH
<p dir="auto">But:</p>
<ol>
<li>I don’t have % for Humidity, inHg for Pressure…</li>
<li>How I can translate WIND? I don’t have it in translation file (same for AQI, UV).</li>
<li>I don’t have forecast for 4 days below.</li>
</ol>
<p dir="auto">Do you know what can be the problem?</p>
<p dir="auto"><img src="/assets/uploads/files/1596907370329-2020-08-08-192016_1920x1080_scrot.png" alt="2020-08-08-192016_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/79938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79938</guid><dc:creator><![CDATA[Lagmin]]></dc:creator><pubDate>Sat, 08 Aug 2020 17:25:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Tue, 21 Jul 2020 22:58:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a> said in <a href="/post/78985">MMM-NOAA - Another Weather Module</a>:</p>
<p dir="auto">Do you know maybe what can be a solution to my problem showing only 3 results, please?</p>
<p dir="auto">Have you installed the dependencies?</p>
]]></description><link>https://forum.magicmirror.builders/post/78999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78999</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 21 Jul 2020 22:58:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Tue, 21 Jul 2020 17:26:40 GMT]]></title><description><![CDATA[<p dir="auto">No problem, not much time. Do you know maybe what can be a solution to my problem showing only 3 results, please?</p>
]]></description><link>https://forum.magicmirror.builders/post/78985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78985</guid><dc:creator><![CDATA[Lagmin]]></dc:creator><pubDate>Tue, 21 Jul 2020 17:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Tue, 21 Jul 2020 01:41:07 GMT]]></title><description><![CDATA[<p dir="auto">pl file added for Polish translation.  Thank you for taking the time to make it.  As Mykle1 says do a ‘git pull’ in the MMM-NOAA3 directory.</p>
]]></description><link>https://forum.magicmirror.builders/post/78951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78951</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 21 Jul 2020 01:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Tue, 21 Jul 2020 01:36:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a> said in <a href="/post/78914">MMM-NOAA - Another Weather Module</a>:</p>
<p dir="auto">Here you go, please update it and by the way, could you please tell me how to implement this language to my MagicMirror module?</p>
<p dir="auto">I forwarded to the author. He will add it to the module, at which time, you will have to run <code>git pull</code> in the MMM-NOAA3 directory. Your config language should be <code>language: "pl",</code></p>
]]></description><link>https://forum.magicmirror.builders/post/78949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78949</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 21 Jul 2020 01:36:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 20 Jul 2020 18:56:54 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, it worked for my other modules.</p>
<p dir="auto">For this module I have problem, it is showing only Rise, Daylight and Set. All other are ‘undefined’. Someone knows the solution?</p>
<p dir="auto">Here is my config:</p>
<pre><code>{
       provider: "openweather", // From list above
       apiKey: "key",        // From one of the providers listed above
       airKey: "key",
       css: "NOAA4",                   // THIS MUST CONTAIN A CSS STYLE NAME
   userlat: "52.429248", //MUST HAVE BOTH
       userlon: "20.962540"  //MUST HAVE BOTH
]]></description><link>https://forum.magicmirror.builders/post/78924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78924</guid><dc:creator><![CDATA[Lagmin]]></dc:creator><pubDate>Mon, 20 Jul 2020 18:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA - Another Weather Module on Mon, 20 Jul 2020 16:57:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lagmin" aria-label="Profile: Lagmin">@<bdi>Lagmin</bdi></a> edit config.js and set language: to the value u need. note that this is all of mm, some other things will need to be translated.</p>
]]></description><link>https://forum.magicmirror.builders/post/78915</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78915</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Jul 2020 16:57:10 GMT</pubDate></item></channel></rss>
