<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t make it work&#x2F;start]]></title><description><![CDATA[<p dir="auto">I have a raspi 2 latest raspbian build, all upgraded, i tried with the automatic installation and it did not worked, there was only an empty folder, i tried with the manual one and it downloaded the files but i does not work. With npm install says npm: command not found, with node serveronly says:<br />
module.js:340<br />
throw err;<br />
^<br />
Error: Cannot find module ‘express’<br />
at Function.module._resolveFilename (module.js:338:15)</p>
<p dir="auto">and so on with these module: 280:25 364:17 380:17 8:15 456:26 474:10 356:32 312:12 and 364:17</p>
<p dir="auto">What should i do? thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/459/can-t-make-it-work-start</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 02:25:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/459.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Aug 2016 07:49:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t make it work&#x2F;start on Fri, 05 Aug 2016 09:17:04 GMT]]></title><description><![CDATA[<p dir="auto">FIXED<br />
the issue was in the node packet. By downloading out of the installer i solved the issue</p>
]]></description><link>https://forum.magicmirror.builders/post/3424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3424</guid><dc:creator><![CDATA[L_i_v_e]]></dc:creator><pubDate>Fri, 05 Aug 2016 09:17:04 GMT</pubDate></item></channel></rss>
