<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help to install MagicMirror]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I followed the tutorial: <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial</a><br />
I have installed magic but I have error messages.<br />
I use a Raspberry pi 2 model B<br />
Who can help me ?<br />
Thanks you very much.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4596/help-to-install-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 17:42:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4596.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Aug 2017 09:29:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help to install MagicMirror on Sun, 24 Sep 2017 13:33:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I get the same error when using same version of Rasbian.<br />
Any news how to fix it?</p>
]]></description><link>https://forum.magicmirror.builders/post/28436</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28436</guid><dc:creator><![CDATA[7even]]></dc:creator><pubDate>Sun, 24 Sep 2017 13:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to Help to install MagicMirror on Tue, 08 Aug 2017 08:13:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I had not downloaded the right version of Rasbian. If you want this to work, you need the RASPBIAN version JESSIE WITH DESKTOP<br />
<img src="/assets/uploads/files/1502179993645-daf0823f-31d7-408a-a5f3-3482784f72ac-image.png" alt="0_1502180055925_daf0823f-31d7-408a-a5f3-3482784f72ac-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/26304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26304</guid><dc:creator><![CDATA[greda]]></dc:creator><pubDate>Tue, 08 Aug 2017 08:13:24 GMT</pubDate></item><item><title><![CDATA[Reply to Help to install MagicMirror on Fri, 04 Aug 2017 16:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greda" aria-label="Profile: greda">@<bdi>greda</bdi></a> For the benefit of others who might run into similar problems, can you post what went wrong and what you did to fix it?</p>
]]></description><link>https://forum.magicmirror.builders/post/26196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26196</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 04 Aug 2017 16:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to Help to install MagicMirror on Fri, 04 Aug 2017 07:07:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I resolved all my problems.<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/26178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26178</guid><dc:creator><![CDATA[greda]]></dc:creator><pubDate>Fri, 04 Aug 2017 07:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to Help to install MagicMirror on Thu, 03 Aug 2017 10:23:58 GMT]]></title><description><![CDATA[<p dir="auto">I forgot this information : npm-debug.log<br />
0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]<br />
2 info using npm@3.10.10<br />
3 info using node@v6.11.2<br />
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]<br />
5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2<br />
6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing<br />
7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2<br />
8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true<br />
9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games<br />
10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror<br />
11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’ ]<br />
12 info lifecycle magicmirror@2.1.2~start: Failed to exec start script<br />
13 verbose stack Error: magicmirror@2.1.2 start: <code>sh run-start.sh</code><br />
13 verbose stack spawn ENOENT<br />
13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)<br />
13 verbose stack     at emitTwo (events.js:106:13)<br />
13 verbose stack     at ChildProcess.emit (events.js:191:7)<br />
13 verbose stack     at maybeClose (internal/child_process.js:891:16)<br />
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)<br />
14 verbose pkgid magicmirror@2.1.2<br />
15 verbose cwd /home/pi/MagicMirror<br />
16 error Linux 4.9.40-v7+<br />
17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
18 error node v6.11.2<br />
19 error npm  v3.10.10<br />
20 error file sh<br />
21 error code ELIFECYCLE<br />
22 error errno ENOENT<br />
23 error syscall spawn<br />
24 error magicmirror@2.1.2 start: <code>sh run-start.sh</code><br />
24 error spawn ENOENT<br />
25 error Failed at the magicmirror@2.1.2 start script ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’.<br />
25 error Make sure you have the latest version of node.js and npm installed.<br />
25 error If you do, this is most likely a problem with the magicmirror package,<br />
25 error not with npm itself.<br />
25 error Tell the author that this fails on your system:<br />
25 error     sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
25 error You can get information on how to open an issue for this project with:<br />
25 error     npm bugs magicmirror<br />
25 error Or if that isn’t available, you can get their info via:<br />
25 error     npm owner ls magicmirror<br />
25 error There is likely additional logging output above.<br />
26 verbose exit [ 1, true ]</p>
]]></description><link>https://forum.magicmirror.builders/post/26155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26155</guid><dc:creator><![CDATA[greda]]></dc:creator><pubDate>Thu, 03 Aug 2017 10:23:58 GMT</pubDate></item></channel></rss>
