<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Calendar adjustment]]></title><description><![CDATA[<p dir="auto">Hello,<br />
first of all thanks to all who are involved here, I am impressed. With the help of the forum I have build a MM and installed the software as noob. But I can read English better than write, so I apologize that I use the help of google to post here. ;)</p>
<p dir="auto">A question about the default calendar module. How can I display a relative date without the word “um” (in english “at”)? Someone has an idea?</p>
<p dir="auto"><img src="/assets/uploads/files/1502048582422-img_0435.png" alt="0_1502048581963_IMG_0435.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Dirk</p>
]]></description><link>https://forum.magicmirror.builders/topic/4613/default-calendar-adjustment</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 16:42:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4613.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Aug 2017 19:47:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Calendar adjustment on Sun, 05 Jan 2020 08:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Two years later… :)</p>
<p dir="auto">After updating to MM 2.10, I noticed again that the “um” or “at” still bothers me and makes the calendar entries unnecessarily wide.<br />
Does anybody have another idea or a tip, what exactly should be changed in the calendar.js to remove it?</p>
]]></description><link>https://forum.magicmirror.builders/post/67227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67227</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Sun, 05 Jan 2020 08:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar adjustment on Mon, 07 Aug 2017 13:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surger13" aria-label="Profile: surger13">@<bdi>surger13</bdi></a> That part is controller by moment.js. It’s not possible configurated. Only way to make this is change the source code of <code>calendar.js</code> in the module directory.</p>
]]></description><link>https://forum.magicmirror.builders/post/26275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26275</guid><dc:creator><![CDATA[roramirez]]></dc:creator><pubDate>Mon, 07 Aug 2017 13:21:24 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar adjustment on Mon, 07 Aug 2017 11:36:26 GMT]]></title><description><![CDATA[<p dir="auto">Hello barnosch,<br />
it is the default <a href="https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar" target="_blank" rel="noopener noreferrer nofollow ugc">calendar module</a> from MagicMirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/26272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26272</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Mon, 07 Aug 2017 11:36:26 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar adjustment on Mon, 07 Aug 2017 09:24:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dirk,</p>
<p dir="auto">is it the standard calender module?<br />
where does you source come from? Where do you get this information from?<br />
I am also interested in a module like this and could look into it aswell.</p>
<p dir="auto">Ist das das Standard Kalender Modul? Wo ist deine Quelle?<br />
Wäre auch an dem Modul interessiert und könnte es mir dann genauer anschauen</p>
]]></description><link>https://forum.magicmirror.builders/post/26268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26268</guid><dc:creator><![CDATA[barnosch]]></dc:creator><pubDate>Mon, 07 Aug 2017 09:24:24 GMT</pubDate></item></channel></rss>
