<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with install new modules]]></title><description><![CDATA[<p dir="auto">I wanted to install some modules.<br />
I’m always on the instructions of the modules on Github.<br />
After the “installing” the mirror has a problem, displays is/shows only a black screen.</p>
<p dir="auto">What could that be?<br />
Can someone help me?<br />
Would be best in German :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/466/problem-with-install-new-modules</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 08:14:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/466.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Aug 2016 15:27:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with install new modules on Sat, 17 Sep 2016 17:10:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> said in <a href="/post/4928">Problem with install new modules</a>:</p>
<p dir="auto">since Raspi 3 has Wifi and Ethernet , is it possible to get both IP’s displayed with name as LAN and Wifi.</p>
<p dir="auto">@strawberry-3-141  MMM-IP is a 3rd-party module. Please contact the module author or look at the <a href="https://github.com/fewieden/MMM-ip" target="_blank" rel="noopener noreferrer nofollow ugc">GitHub</a>  for it.</p>
]]></description><link>https://forum.magicmirror.builders/post/4935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4935</guid><dc:creator><![CDATA[andrewchumchal]]></dc:creator><pubDate>Sat, 17 Sep 2016 17:10:19 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with install new modules on Sat, 17 Sep 2016 15:31:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a>  Module MMM-IP works fine and display one one  IP of MM, since Raspi 3 has Wifi and Ethernet , is it possible to get both IP’s displayed with name as LAN and Wifi.</p>
]]></description><link>https://forum.magicmirror.builders/post/4928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4928</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sat, 17 Sep 2016 15:31:41 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with install new modules on Tue, 09 Aug 2016 14:59:14 GMT]]></title><description><![CDATA[<p dir="auto"><code>wuforecast</code> is 3rd-party module. Please contact the module author.</p>
]]></description><link>https://forum.magicmirror.builders/post/3533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3533</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 09 Aug 2016 14:59:14 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with install new modules on Tue, 09 Aug 2016 08:48:48 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your help!<br />
Now the MMM-ip works!</p>
<p dir="auto">But I have another question:<br />
Have it to consider something at the wuforecast module?<br />
I set it up and now it shows only that it lades, but nothing changes :(</p>
]]></description><link>https://forum.magicmirror.builders/post/3529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3529</guid><dc:creator><![CDATA[tommibaer]]></dc:creator><pubDate>Tue, 09 Aug 2016 08:48:48 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with install new modules on Sun, 07 Aug 2016 14:29:25 GMT]]></title><description><![CDATA[<p dir="auto">I just updated the master version. Maybe that solves your issue.</p>
<p dir="auto">To update:</p>
<pre><code>cd ~/MagicMirror
git pull
]]></description><link>https://forum.magicmirror.builders/post/3474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3474</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 07 Aug 2016 14:29:25 GMT</pubDate></item></channel></rss>
