<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame]]></title><description><![CDATA[<h1>Full length mounted mirror</h1>
<p dir="auto">The project was to create a full length mounted mirror for the wife that we could have in the study and walk by each day.</p>
<p dir="auto"><em>Note: This is a follow on from my initial post <a href="https://forum.magicmirror.builders/topic/1340/my-first-mirror-nyc/">here</a> a few months ago.</em></p>
<h3>Basic specs</h3>
<p dir="auto"><strong>Frame</strong><br />
38 x 130cm / 15 x 51"</p>
<p dir="auto"><strong>Mirror</strong><br />
32 x 122cm / 12.5" x 48"<br />
<a href="https://www.tapplastics.com/product/plastics/cut_to_size_plastic/two_way_mirrored_acrylic/558" target="_blank" rel="noopener noreferrer nofollow ugc">Tap Plastics 2-Way Mirrored Acrylic</a></p>
<p dir="auto"><strong>Power</strong><br />
For the monitor I use a small <a href="https://www.amazon.com/Smart-Wi-Fi-Enabled-Works-Amazon/dp/B01NBI0A6R/" target="_blank" rel="noopener noreferrer nofollow ugc">WeMo Mini smart switch</a> that’s hooked into my Samsung Smartthings hub. This then talks to a sensor I have in my lounge room so the mirror monitor turns on when it senses activity but turns off after 20min of inactivity.</p>
<p dir="auto"><strong>Modules</strong><br />
<em>Will update ASAP</em></p>
<h3>First frame</h3>
<p dir="auto">My first attempt at a frame went fairly well but I made the <em>critical mistake</em> of building the frame before I had the glass and also not making it completely square.</p>
<p dir="auto">This meant that when I received the acrylic it didn’t fit perfectly and meant I would’ve needed to do some serious adjustments. By this stage I had spent hours on this frame sanding, puttying (including all photos for honesty!) and preparing to paint.</p>
<p dir="auto">So instead I started again (cheap wood) and this time made sure I</p>
<ul>
<li>
<ol>
<li>Made things square!</li>
</ol>
</li>
<li>
<ol start="2">
<li>Took the time and didn’t rush</li>
</ol>
</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1502936774101-1.jpg" alt="0_1502936771582_1.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502936972560-2.jpg" alt="0_1502936969552_2.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502936972965-3.jpg" alt="1_1502936969552_3.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502936985530-4.jpg" alt="0_1502936984375_4.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502936985968-5.jpg" alt="1_1502936984376_5.JPG" class=" img-fluid img-markdown" /></p>
<h3>Monitor</h3>
<p dir="auto"><em>I’ll find the model number but essentially it was a 24" monitor our IT department was throwing out</em></p>
<p dir="auto">I removed the bezel and anything else I could from the monitor and kept the switches for later.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937060710-1.jpg" alt="0_1502937058966_1.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937060456-2.jpg" alt="1_1502937058966_2.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937078344-3.jpg" alt="0_1502937076940_3.JPG" class=" img-fluid img-markdown" /></p>
<h3>Wall mount</h3>
<p dir="auto">This is a simple French cleat style mount from <a href="https://www.lowes.com/pd/Hillman-18-in-Hangman-Picture-Hanging-System/3058195" target="_blank" rel="noopener noreferrer nofollow ugc">Lowes</a> that I cut down from 18" to roughly 12" with a hacksaw.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937078590-4.jpg" alt="1_1502937076941_4.JPG" class=" img-fluid img-markdown" /></p>
<h3>Second frame</h3>
<p dir="auto">This time round the wood I grabbed was slightly less deep (I had over estimated how much room the frame needed from the wall to the glass for the monitor) and I opted for screws/wood instead of the corner mounts from the first frame.</p>
<p dir="auto">Here’s some mockups on how the monitor and RasPi were going to look in the final product.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937387380-1.jpg" alt="0_1502937385625_1.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937387691-2.jpg" alt="1_1502937385626_2.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937402412-3.jpg" alt="0_1502937398647_3.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I wanted to make the outer frame myself and made a few mistakes with the 45deg angles but made sure to have plenty of extra framing so I could make better / more square cuts!</p>
<p dir="auto"><img src="/assets/uploads/files/1502937402798-4.jpg" alt="1_1502937398647_4.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937403193-5.jpg" alt="2_1502937398647_5.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I gave it a few coats of a simple all-in-one primer and paint from Lowes (both inside and out).</p>
<p dir="auto"><img src="/assets/uploads/files/1502937419322-6.jpg" alt="0_1502937416860_6.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here’s a mockup of a few “L” frame mounts I wanted to use for the bottom of the monitor (in case it wanted to fall randomly once we hung the mirror).</p>
<p dir="auto">At this stage I had also used some black card (around 1/2 cm thick) to block out the bottom part of the mirror.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937418767-7.jpg" alt="1_1502937416860_7.JPG" class=" img-fluid img-markdown" /></p>
<h3>Assembly!</h3>
<p dir="auto">Once painted I started assembly all of the parts and added the French cleat frame to the top of the mirror.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937696757-1.jpg" alt="0_1502937691096_1.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937695852-2.jpg" alt="1_1502937691096_2.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937696321-3.jpg" alt="2_1502937691096_3.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937714080-4.jpg" alt="0_1502937713211_4.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1502937714446-5.jpg" alt="1_1502937713211_5.JPG" class=" img-fluid img-markdown" /></p>
<h3>Home time</h3>
<p dir="auto">I packaged the frame up at work (we have a workshop and I live in an apartment!) and took it home to start mounting.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937839569-1.jpg" alt="0_1502937837360_1.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I drilled some holes in our (concrete?) walls, added some anchors and then screwed the French cleat into place.</p>
<p dir="auto"><img src="/assets/uploads/files/1502937900792-2.jpg" alt="0_1502937899957_2.JPG" class=" img-fluid img-markdown" /></p>
<h3>First problem!</h3>
<p dir="auto">My biggest issue with this build wouldn’t be realised until I mounted the mirror and walked at least 8m / 26ft away to the front door and looked back.</p>
<p dir="auto"><strong>Fun house effect!</strong></p>
<p dir="auto">Unfortunately the acrylic needs to be absolutely <em>100%</em> flat against the frame in order to avoid any distortion, warping or looking like the mirror belongs in a circus.</p>
<p dir="auto">This was unfortunately a total game changer as the mirror looked terrible and was completely unusable. Also it was a giant eye sore as soon as you walked into the apartment :(</p>
<p dir="auto">So, we moved the mirror to an alternate wall that’s only a few meters from it’s opposite wall and is more parallel with the hallway.</p>
<h3>Final product</h3>
<p dir="auto">Here’s the screen itself showing all of the modules (listed below) that we find useful:</p>
<p dir="auto"><img src="/assets/uploads/files/1502938183847-3.jpg" alt="0_1502938179710_3.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">And here’s a full standing shot of the mirror (it’s around 50cm / 20" off the floor):</p>
<p dir="auto"><img src="/assets/uploads/files/1502938269123-4.jpg" alt="0_1502938268233_4.JPG" class=" img-fluid img-markdown" /></p>
<hr />
<h3>Lessons learned</h3>
<p dir="auto">For the next mirror I would definitely:</p>
<ul>
<li><strong>Take my time</strong> with the frame build in general</li>
<li>Consider completely frameless for a nicer look (or at least a metal frame)</li>
<li>Potentially use a re-purposed laptop LCD with a driver board for a much lighter mirror</li>
<li>Definitely use proper 2-way glass rather than acrylic</li>
</ul>
<h3>Todo</h3>
<ul>
<li>Install a basic sensor to do some neat stuff with the RasPi</li>
<li>Suspend the RasPi based on the sensor activity noted above</li>
<li>Get some basic switches for the monitor controls</li>
</ul>
<h3>Feedback</h3>
<p dir="auto">Please let me know if you have any questions on the build! I’m so glad to have found this community and pored over all of the builds here before I started mine.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4666/full-length-mounted-mirror-single-monitor-38-x-130cm-15-x-51-frame</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 00:45:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4666.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Aug 2017 03:02:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Thu, 31 May 2018 05:44:39 GMT]]></title><description><![CDATA[<p dir="auto">What modules did you use for weather and commute. You mentioned you list them, but I am missing the list.</p>
]]></description><link>https://forum.magicmirror.builders/post/39970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39970</guid><dc:creator><![CDATA[rak]]></dc:creator><pubDate>Thu, 31 May 2018 05:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Wed, 30 May 2018 23:04:54 GMT]]></title><description><![CDATA[<p dir="auto">Nice project!</p>
<p dir="auto">Reading at the end of your post, I see that you say you wanted to put some switches for monitor controls. In my project (much simpler than yours), I put 2 of them to make hard reset to raspberry and to switch off the screen. In this last case, If I push it, I power off the raspberry too, but in the future I will try a PIR sensor to automatically poweroff only the screen when nobody stays near the mirror. Check it out if you want, maybe it gives you some idea.</p>
]]></description><link>https://forum.magicmirror.builders/post/39963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39963</guid><dc:creator><![CDATA[qu1que]]></dc:creator><pubDate>Wed, 30 May 2018 23:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Thu, 17 Aug 2017 14:29:16 GMT]]></title><description><![CDATA[<p dir="auto">Great !!! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/26655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26655</guid><dc:creator><![CDATA[greda]]></dc:creator><pubDate>Thu, 17 Aug 2017 14:29:16 GMT</pubDate></item><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Thu, 17 Aug 2017 11:36:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iamtyce" aria-label="Profile: iamtyce">@<bdi>iamtyce</bdi></a></p>
<p dir="auto">Congrats!</p>
]]></description><link>https://forum.magicmirror.builders/post/26652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26652</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 17 Aug 2017 11:36:55 GMT</pubDate></item><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Thu, 17 Aug 2017 11:26:27 GMT]]></title><description><![CDATA[<p dir="auto">Excellent!</p>
]]></description><link>https://forum.magicmirror.builders/post/26650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26650</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 17 Aug 2017 11:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to Full length mounted mirror | Single monitor, 38 x 130cm (15 x 51") frame on Thu, 17 Aug 2017 05:58:41 GMT]]></title><description><![CDATA[<p dir="auto">Nice build!</p>
]]></description><link>https://forum.magicmirror.builders/post/26645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26645</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Thu, 17 Aug 2017 05:58:41 GMT</pubDate></item></channel></rss>
