<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black Screen after Booting Up]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I recently made a mirror over the summer and I just moved into my college house. When I plugged my mirror back in it displayed the Raspberry Pi boot up like always and then went straight to the MagicMirror boot up, but after that the screen just goes black. It never brought up my desktop or anything. I have a Raspberry Pi 3 and the application was fully working before. I don’t know how to fix it because my keyboard and mouse aren’t responding when I plug them in.</p>
<p dir="auto">If someone could help me out that would be amazing!</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/4672/black-screen-after-booting-up</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 09:42:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4672.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Aug 2017 23:10:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black Screen after Booting Up on Tue, 17 Oct 2017 20:18:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a> said in <a href="/post/29702">Black Screen after Booting Up</a>:</p>
<p dir="auto">With pm2 status i get always two MagicMirror/mm instances.<br />
If i kill one, it comes back after a few seconds</p>
<p dir="auto">type <code>pm2 stop mm</code> or <code>pm2 stop mm.sh</code> in a terminal</p>
]]></description><link>https://forum.magicmirror.builders/post/29713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29713</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 17 Oct 2017 20:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Tue, 17 Oct 2017 19:43:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> said in <a href="/post/29701">Black Screen after Booting Up</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a> I’d suggest backing up your MagicMirror folder (i.e. rename it) and try a fresh install.  By renaming it you won’t lose anything.</p>
<p dir="auto">I Think so<br />
I just punched the</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
<p dir="auto">in the terminal…</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> do you know how i can solve the two pm2 sessions after a fresh install?<br />
]]></description><link>https://forum.magicmirror.builders/post/29702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29702</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Tue, 17 Oct 2017 19:43:10 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Tue, 17 Oct 2017 19:02:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a> I’d suggest backing up your MagicMirror folder (i.e. rename it) and try a fresh install.  By renaming it you won’t lose anything.</p>
]]></description><link>https://forum.magicmirror.builders/post/29701</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29701</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Tue, 17 Oct 2017 19:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Tue, 17 Oct 2017 18:53:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> said in <a href="/post/26696">Black Screen after Booting Up</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> ok.  Try installing the sample config file.<br />
Type:</p>
<p dir="auto"><code>cd ~/MagicMirror/config</code></p>
<p dir="auto"><code>mv config.js config.js.bak</code> (this will back up your existing config)</p>
<p dir="auto"><code>cp config.js.sample config.js</code></p>
<p dir="auto"><code>pm2 restart mm</code></p>
<p dir="auto">If magic mirror starts, then you either have a problem with your config or with a module.</p>
<p dir="auto">I checked the sample config. No other modules installed only the original. But i still have a blank screen…<br />
What would you propose?</p>
]]></description><link>https://forum.magicmirror.builders/post/29700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29700</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Tue, 17 Oct 2017 18:53:02 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 03:44:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> type:</p>
<p dir="auto"><code>cd ~/MagicMirror/config</code> (Takes you to the MM config directory)</p>
<p dir="auto"><code>mv config.js.bak config.js</code> (Restores your config file)</p>
<p dir="auto"><code>pm2 restart mm</code> (restarts MagicMirror)</p>
]]></description><link>https://forum.magicmirror.builders/post/26707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26707</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 03:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 03:20:53 GMT]]></title><description><![CDATA[<p dir="auto">how would I restore my config file? Sorry I am new to using terminal and don’t really know all the commands.</p>
]]></description><link>https://forum.magicmirror.builders/post/26706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26706</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 03:20:53 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:26:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> yes.</p>
<p dir="auto">Use the <code>ls</code> command to see a list of files in the current directory</p>
<p dir="auto">use the <code>cd</code> command to enter a directory e.g.: <code>cd directory-name</code></p>
<p dir="auto">use the the command <code>cd ..</code> to go back up to the parent directory</p>
<p dir="auto">the <code>pwd</code> command will tell show the path to the current directory</p>
<p dir="auto"><code>cd ~</code> will take you your home directory</p>
]]></description><link>https://forum.magicmirror.builders/post/26704</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26704</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:23:56 GMT]]></title><description><![CDATA[<p dir="auto">Is there a way to see what directories or files I have so I know what I can delete?</p>
]]></description><link>https://forum.magicmirror.builders/post/26703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26703</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> you can delete files with the <code>rm</code> command.  Be careful with this, because it can’t be undone.</p>
<p dir="auto">Say you wanted to delete some pictures you have in a folder in you home directory.  Navigate to that directory like so:</p>
<p dir="auto"><code>cd ~/photo-directory-name</code> (whatever the folder name might be)</p>
<p dir="auto"><code>rm file-name.jpg</code> (this will permanently delete the file)</p>
<p dir="auto">You can remove entire directories with the <code>-r</code> switch.  Example:</p>
<p dir="auto"><code>rm -r directory-name</code></p>
<p dir="auto">And be sure to double-check your typing before you hit enter.  deleting things this way is not recoverable.</p>
]]></description><link>https://forum.magicmirror.builders/post/26702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26702</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:09:44 GMT]]></title><description><![CDATA[<p dir="auto">Oh! How can I clear up space remotely?</p>
]]></description><link>https://forum.magicmirror.builders/post/26701</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26701</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> Aha!  I’d say that might be your problem.  See if you can free up some space, then restore your config file, and restart MM</p>
]]></description><link>https://forum.magicmirror.builders/post/26700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26700</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:07:32 GMT]]></title><description><![CDATA[<p dir="auto">So, unfortunately, I only had an 8gb sd card so I used that in my Pi and it is full so it will not write config.js.sample because there is not enough room…</p>
]]></description><link>https://forum.magicmirror.builders/post/26699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26699</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 02:00:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> ok.  Try installing the sample config file.<br />
Type:</p>
]]></description><link>https://forum.magicmirror.builders/post/26696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26696</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:00:04 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:57:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> all it responded with was<br />
“Spawning PM2 daemon with pm2_home=/home/pi/.pm2”</p>
]]></description><link>https://forum.magicmirror.builders/post/26695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26695</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:57:05 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:52:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> Also, at this point, you can start disabling modules one by one until MM starts.  That should help you figure out the culprit.</p>
]]></description><link>https://forum.magicmirror.builders/post/26694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26694</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:52:45 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:51:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> type <code>pm2 logs mm</code></p>
]]></description><link>https://forum.magicmirror.builders/post/26693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26693</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:51:43 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:50:56 GMT]]></title><description><![CDATA[<p dir="auto">I am able to connect via SSH now. How do I check the MM’s logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/26692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26692</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:50:56 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:28:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> is SSH enabled? if so try to connect that way.  That will allow you to check MM’s logs</p>
]]></description><link>https://forum.magicmirror.builders/post/26691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26691</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:28:56 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:27:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> I was able to connect but it still shows a black screen and I still cannot control it.</p>
]]></description><link>https://forum.magicmirror.builders/post/26689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26689</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:27:33 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:18:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> maybe try connecting a LAN cable.  it should work with DHCP by default</p>
]]></description><link>https://forum.magicmirror.builders/post/26688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26688</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:18:29 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:18:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a></p>
<p dir="auto">So the mirror has no internet connection?</p>
]]></description><link>https://forum.magicmirror.builders/post/26687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26687</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:15:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> I usually use VNC Connect to connect to it remotely, but since I moved into a new house it isn’t connected to the new wifi so it won’t work.</p>
]]></description><link>https://forum.magicmirror.builders/post/26686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26686</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 01:13:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> I tried the alt key but nothing happened. The Windows key won’t pull down the menu either.</p>
]]></description><link>https://forum.magicmirror.builders/post/26685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26685</guid><dc:creator><![CDATA[nickymac12]]></dc:creator><pubDate>Fri, 18 Aug 2017 01:13:50 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen after Booting Up on Fri, 18 Aug 2017 00:57:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickymac12" aria-label="Profile: nickymac12">@<bdi>nickymac12</bdi></a> are you able to connect remotely? over SSH?  if so you might be able to check MM’s logs to see if anything went wrong</p>
]]></description><link>https://forum.magicmirror.builders/post/26682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26682</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Fri, 18 Aug 2017 00:57:43 GMT</pubDate></item></channel></rss>
