<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SpotifyConnectUI]]></title><description><![CDATA[<p dir="auto">The <strong>MMM-SpotifyConnectUI</strong> module is for displaying cover, artist and track-information - using Fornoth’s spotify-connect-web project (also available on GitHub).</p>
<p dir="auto"><img src="https://github.com/CatoAntonsen/MMM-SpotifyConnectUI/raw/master/images/Example.png" alt="Examples from MMM-SpotifyConnectUI module" class=" img-fluid img-markdown" /></p>
<p dir="auto">You find it here:</p>
<p dir="auto">[card:CatoAntonsen/MMM-SpotifyConnectUI]</p>
]]></description><link>https://forum.magicmirror.builders/topic/468/mmm-spotifyconnectui</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 04:36:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/468.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Aug 2016 18:28:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Wed, 13 Sep 2017 23:28:29 GMT]]></title><description><![CDATA[<p dir="auto">newer spotify connect app - raspotify works out of the box:<br />
<a href="https://github.com/dtcooper/raspotify" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/dtcooper/raspotify</a><br />
<a href="https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348" target="_blank" rel="noopener noreferrer nofollow ugc">https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348</a></p>
<p dir="auto">but there is no frontend yet</p>
]]></description><link>https://forum.magicmirror.builders/post/28068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28068</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Wed, 13 Sep 2017 23:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 06 Apr 2017 23:09:54 GMT]]></title><description><![CDATA[<p dir="auto">you can use mopidy as a alternative.<br />
pro: you can use also soundcloud, youtube, webradio etc<br />
cons: no spotify conect, you have to use a mpd app or the webpage</p>
]]></description><link>https://forum.magicmirror.builders/post/19165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19165</guid><dc:creator><![CDATA[B4rth]]></dc:creator><pubDate>Thu, 06 Apr 2017 23:09:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 06 Apr 2017 22:38:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello. Is there a workaround to use Spotify on the RPi? Like using the webplayer somehow, vlc, anything. I can’t find anything that works, so I figured I’d ask here.</p>
]]></description><link>https://forum.magicmirror.builders/post/19162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19162</guid><dc:creator><![CDATA[Advokaten]]></dc:creator><pubDate>Thu, 06 Apr 2017 22:38:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Sun, 05 Mar 2017 08:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nex0" aria-label="Profile: nex0">@<bdi>nex0</bdi></a><br />
I had to submit the form twice. I waited several weeks after first key request, then just sent the same request again and received the key one or two days later</p>
]]></description><link>https://forum.magicmirror.builders/post/16485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16485</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 05 Mar 2017 08:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Sun, 05 Mar 2017 07:28:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cato" aria-label="Profile: Cato">@<bdi>Cato</bdi></a> Ok, I understand, thanks!</p>
<p dir="auto">Another question… In spotify I get:</p>
<pre><code>The libspotify key generation and retrieval service has been deprecated, along with libspotify.
You may apply to get a key using our App-key Request Form for private, individual usage. Bear in mind that you should do no new development using libspotify.
<p dir="auto">But when I request the key, they do not send it to me, does anyone have any news of this? Or another solution!</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/16484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16484</guid><dc:creator><![CDATA[nex0]]></dc:creator><pubDate>Sun, 05 Mar 2017 07:28:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 27 Feb 2017 04:41:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nex0" aria-label="Profile: nex0">@<bdi>nex0</bdi></a> Not sure if I understand the question.</p>
<p dir="auto">This module is only a front end for Spotify Connect Web and does not play music.</p>
<p dir="auto">But IF your Raspberry Pi where you have installed<br />
Spotify Connect Web (not the module) have speakers connected and IF you get your hands on a API key from Spotify then you can play music and see what song in my module.</p>
]]></description><link>https://forum.magicmirror.builders/post/15974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15974</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Mon, 27 Feb 2017 04:41:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 27 Feb 2017 02:37:49 GMT]]></title><description><![CDATA[<p dir="auto">Great module!</p>
<p dir="auto">I have a question, can I listening music with him?<br />
Sorry for reliving old post.</p>
]]></description><link>https://forum.magicmirror.builders/post/15970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15970</guid><dc:creator><![CDATA[nex0]]></dc:creator><pubDate>Mon, 27 Feb 2017 02:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 11 Aug 2016 16:59:54 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your answer!</p>
<p dir="auto">I guess this module is better suited for my needs : [<a href="http://Last.FM" target="_blank" rel="noopener noreferrer nofollow ugc">Last.FM</a>] Music Scrobbler</p>
<p dir="auto">LJ</p>
]]></description><link>https://forum.magicmirror.builders/post/3604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3604</guid><dc:creator><![CDATA[luvien]]></dc:creator><pubDate>Thu, 11 Aug 2016 16:59:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 11 Aug 2016 16:27:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luvien" aria-label="Profile: luvien">@<bdi>luvien</bdi></a> No, unfortunately not.</p>
<p dir="auto">Edit: It uses the API provided by <strong>spotify-connect-web</strong>. You can install spotify-connect-web on another device, though…</p>
<p dir="auto">Edit 2: spotify-connect-web is a third party client/API</p>
]]></description><link>https://forum.magicmirror.builders/post/3599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3599</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Thu, 11 Aug 2016 16:27:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 11 Aug 2016 16:19:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">Thanks for this module.  I’m wondering about a usecase.</p>
<p dir="auto">If I install this module, and I’m playing music from another device using my Spotify account, and not playing from the Rpi, will it display the right cover on the mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/3598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3598</guid><dc:creator><![CDATA[luvien]]></dc:creator><pubDate>Thu, 11 Aug 2016 16:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 11 Aug 2016 15:13:12 GMT]]></title><description><![CDATA[<p dir="auto">Updated module to version 1.0.2.</p>
<h1>MMM-SpotifyConnectUI Change Log</h1>
<h2>[1.0.2] - 2016-08-11</h2>
<h3>Documentation</h3>
<ul>
<li>Added instructions on how to run spotify-web-connect as a service</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Fixed styling issues</li>
</ul>
<h2>[1.0.1] - 2016-08-07</h2>
<ul>
<li>Changed correct position-value in the config</li>
<li>Added Spotify dev/key-links</li>
<li>Used same cursor-syntax on all code samples</li>
<li>Some typos…</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/3595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3595</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Thu, 11 Aug 2016 15:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Thu, 11 Aug 2016 13:13:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/onetwankyfive" aria-label="Profile: onetwankyfive">@<bdi>onetwankyfive</bdi></a> Glad you liked the module. I’ve added instructions for running spotify-web-connect as a service in README .md on GitHub. Notice, it’s only in the Dev-branch at the moment…</p>
<p dir="auto">Feel free to submit PR on GitHub if your CSS is better - I’ll gladely add it if I like it too! ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/3587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3587</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Thu, 11 Aug 2016 13:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Wed, 10 Aug 2016 22:17:46 GMT]]></title><description><![CDATA[<p dir="auto">I made the logo bigger and did a little CSS work so the logo was the closer to the same size as the album and text below it… (I also did some css work with the nest module)</p>
<p dir="auto">Love the module… Still trying to figure out the best way to get the spotify-connect-web to load on reboot/startup… Now I run a shell script with an &amp; after it and then start the mirror…</p>
<p dir="auto"><img src="/uploads/files/1470867353570-screenshot2.png" alt="0_1470867352366_screenshot2.png" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1470867358475-screenshot1.png" alt="0_1470867357878_screenshot1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/3565</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3565</guid><dc:creator><![CDATA[onetwankyfive]]></dc:creator><pubDate>Wed, 10 Aug 2016 22:17:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 08 Aug 2016 14:19:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexyak" aria-label="Profile: alexyak">@<bdi>alexyak</bdi></a> Not hard at all!</p>
<p dir="auto">Spotify-Connect-Web do this already… ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/3510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3510</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Mon, 08 Aug 2016 14:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 08 Aug 2016 14:12:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cato" aria-label="Profile: Cato">@<bdi>Cato</bdi></a> How hard it would be to add the code to actually play the music on the RaspPi?</p>
]]></description><link>https://forum.magicmirror.builders/post/3509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3509</guid><dc:creator><![CDATA[alexyak]]></dc:creator><pubDate>Mon, 08 Aug 2016 14:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 08 Aug 2016 11:37:38 GMT]]></title><description><![CDATA[<p dir="auto">yeah i’m using it on a real mirror… looks great :)</p>
]]></description><link>https://forum.magicmirror.builders/post/3507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3507</guid><dc:creator><![CDATA[andr1]]></dc:creator><pubDate>Mon, 08 Aug 2016 11:37:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Mon, 08 Aug 2016 08:22:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andr1" aria-label="Profile: andr1">@<bdi>andr1</bdi></a> Glad you liked it! Are you running on a real mirror? Just wondering how the cover image looks through a mirror. I’m still waiting for my mirror…</p>
<p dir="auto">Nice tips about “screen”! I’ll consider add that to the documentation when I’ve tested it a little more.</p>
]]></description><link>https://forum.magicmirror.builders/post/3504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3504</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Mon, 08 Aug 2016 08:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Sun, 07 Aug 2016 20:45:21 GMT]]></title><description><![CDATA[<p dir="auto">awesome module! exactly what I needed…<br />
running this with “screen -dmS spotify sudo ./spotify-connect-web -n Mirror -o plughw:CARD=ALSA,DEV=0” (just using the mini jack on the raspberry pi at the moment)</p>
]]></description><link>https://forum.magicmirror.builders/post/3493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3493</guid><dc:creator><![CDATA[andr1]]></dc:creator><pubDate>Sun, 07 Aug 2016 20:45:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpotifyConnectUI on Sun, 07 Aug 2016 18:32:24 GMT]]></title><description><![CDATA[<p dir="auto">Please let me know what you think! Do you have suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/3489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3489</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Sun, 07 Aug 2016 18:32:24 GMT</pubDate></item></channel></rss>
