<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[notificationFx.js (default alert module) problem]]></title><description><![CDATA[<p dir="auto">I cannot understand this error. I think there would be no problem, but it causes an error.</p>
<p dir="auto">[in my module]</p>
<pre><code>this.sendNotification('SHOW_ALERT', {
   timer:10000,
   title: "test",
   message : "say something"
<p dir="auto">This cause run-time exception error.<br />
<code>DOMException: Failed to execute 'insertBefore' on 'Node': The node before which the new node is to be inserted is not a child of this node.</code><br />
in<br />
[notificationFx.js (line:91)]</p>
<pre><code>90: // append to body or the element specified in options.wrapper
91: this.options.wrapper.insertBefore(this.ntf, this.options.wrapper.nextSibling);
<p dir="auto"><code>this.options.wrapper</code> is <code>&lt; body &gt;</code> .<br />
<code>this.ntf</code> is <code>div.ns-alert.ns-growl.ns-effect-jelly.ns-type-notice</code>.<br />
<code>this.options.wrapper.nextSibling</code> is <code>span.gr__tooltip</code>.</p>
<p dir="auto">Is this <code>notificationFx.js</code> problem? But everybody except me uses this without a problem.<br />
I’m testing this on Mac OSX with Chrome in <code>node serveronly</code> mode.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4690/notificationfx-js-default-alert-module-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 09:32:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4690.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Aug 2017 16:40:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to notificationFx.js (default alert module) problem on Fri, 25 Aug 2017 14:56:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roramirez" aria-label="Profile: roramirez">@<bdi>roramirez</bdi></a><br />
It was 60.0.3112.101 (official) (64bit) on Mac OSX Sierra 10.12.6 (in MBP Late 2013 15" Retina / i7 2.3Ghz 16GB DDR3)</p>
]]></description><link>https://forum.magicmirror.builders/post/27014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27014</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 25 Aug 2017 14:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to notificationFx.js (default alert module) problem on Fri, 25 Aug 2017 14:53:31 GMT]]></title><description><![CDATA[<p dir="auto">@Sean So,  can be there a bug with using that browser. What version of Chrome is?</p>
]]></description><link>https://forum.magicmirror.builders/post/27013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27013</guid><dc:creator><![CDATA[roramirez]]></dc:creator><pubDate>Fri, 25 Aug 2017 14:53:31 GMT</pubDate></item><item><title><![CDATA[Reply to notificationFx.js (default alert module) problem on Wed, 23 Aug 2017 06:29:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roramirez" aria-label="Profile: roramirez">@<bdi>roramirez</bdi></a> Thanks, with <code>npm start dev</code>, it works.</p>
]]></description><link>https://forum.magicmirror.builders/post/26910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26910</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 23 Aug 2017 06:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to notificationFx.js (default alert module) problem on Tue, 22 Aug 2017 18:50:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roramirez" aria-label="Profile: roramirez">@<bdi>roramirez</bdi></a> tomorrow I’ll try it.</p>
]]></description><link>https://forum.magicmirror.builders/post/26891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26891</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 22 Aug 2017 18:50:16 GMT</pubDate></item><item><title><![CDATA[Reply to notificationFx.js (default alert module) problem on Tue, 22 Aug 2017 17:55:18 GMT]]></title><description><![CDATA[<p dir="auto">@Sean If you start with <code>npm start dev</code>, do  you have the same problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/26888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26888</guid><dc:creator><![CDATA[roramirez]]></dc:creator><pubDate>Tue, 22 Aug 2017 17:55:18 GMT</pubDate></item></channel></rss>
